Everything posted by druxey
THE 74-GUN SHIP by Jeronimo
druxey replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Superb work, Karl. Is that gold or bronze leaf that you've used on your cannon?- 194 replies
This slim publication by the National Maritime Museum in 1972, reprinted in 1976 is an invaluable primer on the building of clinker open boats. While dealing with full-size construction, this book is of value to the model maker and includes a heavy card cut-out half model of a 10' 0' workboat at ⅜" = 1' 0" scale. There is an extensive glossary of boatbuilding terms, some excellent perspective detail drawings and a clear explanatory text. The only criticism I have is that one needs to flip pages from text to illustration, but this is a small quibble. Eric McKee is an excellent author and illustrator. I thoroughly recommend this book for anyone interested in lapstrake open boat construction.
This may be a naive question, but as you have in effect made a rolling mil, could you have simply formed the bulb iron of brass or copper strip between rollers of suitable profile? You've made a beautiful double-cam action jig there, Gerald.
- 281 replies
- falls of clyde
- tanker
Use the hard bamboo layer from just inside the shiny outer layer. The inside layer is too soft and fuzzy to use.
- 967 replies
- hahn
- oliver cromwell
Caroline's bottom
druxey replied to GrantGoodale's topic in Building, Framing, Planking and plating a ships hull and deck
Nice idea, Dafi. What you show certainly looks like peas! However, the source of my quote says: "NB the Sloop has now a pease Coat bottom upon her, which will last extremely well till the Spring." "till the Spring" implies a temporary rather than permanent measure, and studded nails are unlikely to be called a 'Coat'. So the mystery remains. -
Unless the wood grain of the boxwood is absolutely straight, it will not draw without breaking in smaller sizes. Use split bamboo, as Mike suggests.
- 967 replies
- hahn
- oliver cromwell
Mast Lengths and their above deck heights for HMB Endeavour
druxey replied to dashi's topic in Masting, rigging and sails
Thanks also to you, Dashicat, for an interesting discussion!- 63 replies
- HMB Endeavour mast lengths
- above deck mast heights
- (and 3 more)
Very impressive miniature forging work, Giampiero! I've also had good results by flattening bent copper wire for the 'U' part of the hinge.
You wrote: It would need to keep the diameter proportional to the longer mast of 60' because the stresses from the quarterdeck partners would still be the same regardless of whether hold or lower deck stepped. Stresses would surely be greater if the mast were stepped on the lower deck, as the leverage exerted on it would be greater? (Proportional length of mast above and below the partners, the latter being the fulcrum.)- 63 replies
- (and 3 more)
I can't speak for softwoods, but I've had no issues with isopropanol on Castello or other hardwoods. Heat will speed up the debonding process for sure, but alcohol alone does the trick. All you need is a little patience while it works through the joint.
- 649 replies
- dunbrody
- famine ship
Looks good. However, I've found that one can run into problems by planking from the sheer strake downward. Getting either the garboard in last, or a shutter strake at scale size, is very difficult. I recommend starting at the garboard and working upward.
- 58 replies
- barge
- ships boat
We all make mistakes and makeovers, no matter how experienced. As for raised grain, you don't need water to de-bond white or yellow glue. Use 95% or 99% isopropanol. The lack of water content in it will prevent this.
- 649 replies
- dunbrody
- famine ship
Looking at that close-up of the draught, surely there would be reinforcing carlings and pillars under a mizzen stepped on the lower deck? There is no trace of any that I can see.- 63 replies
- (and 3 more)
Well, for a mizen of 14" diameter, the length should be 60' 0" (naval) or 61' 0" (merchant), according to Steel who is, admittedly a little later than Endeavour. But that give you the 10' 0" differential in length you had mentioned.- 63 replies
- (and 3 more)
What does the mizen diameter at the partners measure on the draughts that you have, Dashicat?- 63 replies
- (and 3 more)
Nice to see you back at the workbench, Siggi! I'm looking forward to see this model progress.
- 58 replies
- barge
- ships boat
One further thought: Measure the diameter of the mizen on the NMM (RMG) draughts. Extrapolating from that, what would be the mizen lower mast length? Perhaps that will settle the question for you.- 63 replies
- (and 3 more)
I'm sure that there were exceptions in 1768, Dashicat. However, if you look at contemporary plans, generally you will only see mizen steps on the lower deck from the mid-1780's onward. Check out ships' plans images on the Royal Museums Greenwich web site.- 63 replies
- (and 3 more)
The mizen mast was stepped on the keelson until late in the 18th century. I suspect Endeavour was stepped in this earlier style. It is irritating that contemporary draughts all omit showing any mast steps!- 63 replies
- (and 3 more)
Nice result, Frank. You might wish to back up the clamp with a scrap of hardwood to prevent tear-out on the drill exiting.
- 649 replies
- dunbrody
- famine ship
