druxey
Everything posted by druxey
  1. Nice progress and good photos, Bill! Am I seeing this correctly, or is it an optical illusion: is the upper part of the beakhead straight and the lower part slightly curved as seen from above?
  2. Thanks, Karl. Looks great.
  3. That's for lengthening the boat, Maurys! Just kidding.
  4. You are making life unduly complicated for yourself, I think. When building the model (or the real boat) that stern post was left over-wide and then dubbed fair with the hull after planking.
  5. Well, Siggi, I wondered how you would manage the last shutter plank! That is an interesting solution. Well done.
  6. Thank you for this mega-progress instalment, E&T! It's interesting how, during construction, things that were not clear on drawings suddenly become 'ah-ha!' moments. I've found this very satisfying. I see you had one of these nice moments with the configuration of the lower hull planking layers at the stern. I'm certain that you are correct, as this makes perfect constructional sense in terms of strength. Well done!
  7. Thanks for the explanation, Gerald. My local jeweller has a rolling machine to reduce precious metal strip in thickness, which is what I was thinking of. I suppose, from its rugged construction, that it could exert the kind of pressure you describe. I did understand your earlier explanation of the fabrication process for your 'bulb iron'.
  8. Superb work, Karl. Is that gold or bronze leaf that you've used on your cannon?
  9. If the gangway were continuous in level with the quarter and forecastle decking, it would make sense to have the planking continuous. There would be no reason for an athwartship seam fore and aft of the gangway.
  10. This slim publication by the National Maritime Museum in 1972, reprinted in 1976 is an invaluable primer on the building of clinker open boats. While dealing with full-size construction, this book is of value to the model maker and includes a heavy card cut-out half model of a 10' 0' workboat at ⅜" = 1' 0" scale. There is an extensive glossary of boatbuilding terms, some excellent perspective detail drawings and a clear explanatory text. The only criticism I have is that one needs to flip pages from text to illustration, but this is a small quibble. Eric McKee is an excellent author and illustrator. I thoroughly recommend this book for anyone interested in lapstrake open boat construction.
  11. This may be a naive question, but as you have in effect made a rolling mil, could you have simply formed the bulb iron of brass or copper strip between rollers of suitable profile? You've made a beautiful double-cam action jig there, Gerald.
  12. Use the hard bamboo layer from just inside the shiny outer layer. The inside layer is too soft and fuzzy to use.
  13. Nice idea, Dafi. What you show certainly looks like peas! However, the source of my quote says: "NB the Sloop has now a pease Coat bottom upon her, which will last extremely well till the Spring." "till the Spring" implies a temporary rather than permanent measure, and studded nails are unlikely to be called a 'Coat'. So the mystery remains.
  14. Unless the wood grain of the boxwood is absolutely straight, it will not draw without breaking in smaller sizes. Use split bamboo, as Mike suggests.
  15. Very impressive miniature forging work, Giampiero! I've also had good results by flattening bent copper wire for the 'U' part of the hinge.
  16. You wrote: It would need to keep the diameter proportional to the longer mast of 60' because the stresses from the quarterdeck partners would still be the same regardless of whether hold or lower deck stepped. ​Stresses would surely be greater if the mast were stepped on the lower deck, as the leverage exerted on it would be greater? (Proportional length of mast above and below the partners, the latter being the fulcrum.)
  17. I can't speak for softwoods, but I've had no issues with isopropanol on Castello or other hardwoods. Heat will speed up the debonding process for sure, but alcohol alone does the trick. All you need is a little patience while it works through the joint.
  18. Looks good. However, I've found that one can run into problems by planking from the sheer strake downward. Getting either the garboard in last, or a shutter strake at scale size, is very difficult. I recommend starting at the garboard and working upward.
  19. We all make mistakes and makeovers, no matter how experienced. As for raised grain, you don't need water to de-bond white or yellow glue. Use 95% or 99% isopropanol. The lack of water content in it will prevent this.
  20. Looking at that close-up of the draught, surely there would be reinforcing carlings and pillars under a mizzen stepped on the lower deck? There is no trace of any that I can see.
  21. You might want to read the planking tutorials pinned on this site.
  22. Well, for a mizen of 14" diameter, the length should be 60' 0" (naval) or 61' 0" (merchant), according to Steel who is, admittedly a little later than Endeavour. But that give you the 10' 0" differential in length you had mentioned.
