Everything posted by druxey
One way of protecting the stern timbering is to attach one (or more) battens across them as a temporary measure. Also don't make any sudden reaching over moves and wear short sleeves!
- 525 replies
- anchor hoy
- hoy
And you have another follower here, Clare! Looks like a great start to your build. Small point: the chequerboard was a painted canvas floorcloth, not actual parquet. Looking forward to seeing your progress.
Steamboats and other rivercraft - general discussion
druxey replied to Cathead's topic in Nautical/Naval History
Mark: We are discussing fixed buckets or blades here, rather than the feathering type. And yes, the trapping of air in the sponson is what I was speculating on.- 281 replies
- Steamboats
- riverboats
(and 3 more)
Anyone care to comment on the air pressure idea?- 281 replies
- Steamboats
- riverboats
(and 3 more)
I use 1000 and 4000. If an edge should get a nick, I might use something coarser to get the worst ground off. If you sharpen properly with a micro-bevel on the edge, all you need to do is a few strokes on the 4000 grit to get the tool back to A1 shape.
- 525 replies
- anchor hoy
- hoy
Thinking things through: Some bits about the bitts
druxey replied to dafi's topic in Masting, rigging and sails
Uh...sure, Jud! Usually the height of the crosspiece above the deck (plank) was in the order of 19" to 20"(mizen) 21" (main) to the underside. The height of the bitt pins above deck: 2' 11" (mizen), 3' 7" (main). Hope this is a helpful guide. -
Ya gotta keep them tools well sharpened, Maurys! You'll regret it when they are blunt, so you push hard and the tool slips....
- 525 replies
- anchor hoy
- hoy
Unfortunately the images, as interesting as they are, do not solve the issue.- 281 replies
- Steamboats
- riverboats
(and 3 more)
My (limited) understanding is that, as the paddlewheel turns, it creates some pressure in the paddlebox. The large space provided inside the box would ameliorate this effect, as did the later fancy perforated boxes seen on side paddle steamers. Can someone confirm or correct me?
Post script: The book on this model and making other open boats, both clinker and carvel, is now on the press! Look for an announcement from SeaWatchBooks soon. Thank you again everyone, for your encouragement and support on this log.
- 641 replies
- greenwich hospital
- barge
If you continue to be as meticulous in your cross-measurements as you have been, all should work out well, Maurys. I find re-measurung and checking constantly the only way to avoid reaching for the isopropanol!
- 525 replies
- anchor hoy
- hoy
Exquisite work, Gerald. Is the multi-arm soldering station your own creation or a commercially available unit?
- 281 replies
- falls of clyde
- tanker
Drilling with a pin chuck is very time consuming - been there, done that! I hope you can mini-mechanize the process. Look forward to seeing your home-made drill for small spaces.
- 969 replies
- hahn
- oliver cromwell
Lovely detail work on the door/hatch there.
- 184 replies
- ruby & arthur reed
- lifeboat
I've just discovered your log: what fascinating 'inside-out' way to construct a model! I've never seen this done before and it looks like an excellent method. However, it would require a lot of very careful planning and extremely accurate craftsmanship. Obviously you possess both skills, Amalio.
If you have more time on your hands, Chuck, why not put in the rest of the 'nails'? Seriously, that looks very nice indeed.
- 269 replies
- Queen Anne Barge
- Syren Ship Model Company
The swivel mounts (generally) were vertical, or nearly so. The portion of hull forward above the knuckle should be vertical, so that the mount ought to automatically be positioned this way. Hope this helps.
- 1,449 replies
Those bluff bows make life interesting, don't they? Looks like you've mastered it, Maurys.
- 525 replies
- anchor hoy
- hoy
Echo by davec - FINISHED - cross-section
druxey replied to davec's topic in - Build logs for subjects built 1751 - 1800
Slow and steady wins, you know! Looking good, Dave.- 127 replies
Lovely, Toni. However, has that top piece of moulding been knocked out of line? Should be an easy fix.
- 1,449 replies
34ft Danish Cutter by adamdt
druxey replied to adamdt's topic in - Build logs for subjects built 1901 - Present Day
Welcome back, Adam! I've just come across your log. Those are pretty impressive freehand curves but, as someone else mentioned, a flexible curve may ease your job.
