druxey
Everything posted by druxey
  1. What does the mizen diameter at the partners measure on the draughts that you have, Dashicat?
  2. Nice to see you back at the workbench, Siggi! I'm looking forward to see this model progress.
  3. One further thought: Measure the diameter of the mizen on the NMM (RMG) draughts. Extrapolating from that, what would be the mizen lower mast length? Perhaps that will settle the question for you.
  4. I'm sure that there were exceptions in 1768, Dashicat. However, if you look at contemporary plans, generally you will only see mizen steps on the lower deck from the mid-1780's onward. Check out ships' plans images on the Royal Museums Greenwich web site.
  5. The mizen mast was stepped on the keelson until late in the 18th century. I suspect Endeavour was stepped in this earlier style. It is irritating that contemporary draughts all omit showing any mast steps!
  6. Nice result, Frank. You might wish to back up the clamp with a scrap of hardwood to prevent tear-out on the drill exiting.
  7. Lovely looking and great progress, Albert. If you are planning on planking the lower counter, it's easier to do this before adding the wale planking.
  8. To stiffen SilkSpan, dilute acrylic paint or matt medium - no need for nasty organic volatiles!
  9. Well, I hope that the charges are inert! Neat solution to the problem of unscrewing the fuses without damaging them. Well done.
  10. I am reminded of an anecdote about Oscar Wilde. In company one evening, he made one of his witty remarks. Someone laughed and said "I wish I'd thought of that!" Oscar replied, "Oh, you will, you will!" I'll think of cutting bands to exact length that way soon, Ed.
  11. Cutting the bands to length using your method is a brilliant idea, Ed! Thank you.
  12. SilkSpan is very flexible and strong when wetted for shaping, Dick.
  13. I've used SilkSpan for sails and flags. There is a booklet on this technique from SeaWatchBooks: Swan, Volume IV, Sailmaking Supplement that may help.
  14. I think, while you are correct, Michael, in saying the damp towel will expand the wood; once the humidity level returns to ambient, the wood will shrink back again. This treatment is only a temporary fix, unfortunately.
  15. Interesting conundrum, Bill. Two out of three sources don't show this port. The VdV and Boston images look more accurately rendered than the Payne.... The more forward-pointing catheads of that era look as if they would be almost immediately above such a port, if it existed. My inclination would be to omit it. However, its's your model, your call! Beautiful work again, Bill. It's nice to see the head of your model finally being populated!
  16. Lovely metalwork, as always, Ed. You could always make another one for blackening....
  17. Very nice monograms indeed, Marsala. How did you make and apply them?
  18. I'm sure that this is a disappointment to you. However, none of us reach perfection. Somewhere in every model, lurks an 'oops'. One possible (non-destructive) solution might be this: the actual scarph will be hidden under the mast step. As the bolting pattern is regular, could you scribe a scarph in the correct position and slightly darken this with a fine pencil point?
  19. Yup, building one of these framed vessels is an education indeed!
  20. I'm sure that much is salvageable, Ben. Just get out the isopropanol bath!
  21. Impressively researched and well modelled, Dick. Just catching up with your last few posts.
  22. That is a lot of machining! Well done, Marsalv.
