Everything posted by druxey
Can anyone recommend a miniature hand plane?
druxey replied to Bettina's topic in Modeling tools and Workshop Equipment
Lee Valley is a good tip for quality planes. However, I find a well-honed chisel, used bevel down, easier to use than a plane. It is especially useful where a mast or spar goes from round to octagonal or square. You can 'get into the corner' nicely with a chisel. -
Echo by Maury S - FINISHED - Cross-Section
druxey replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
Those scupper support timbers are better placed once the level of the deck is established, as Greg suggests.- 324 replies
Oh...my.... I really feel for you. I'm so sorry that you are back to Square One. Next round, if you still have a cat, may I suggest you either close the door or, if you don't have a separate workshop, clamp the building board down between sessions? On the plus side, you will find that your work will go quicker and more accurately than the first time. Best wishes, Cap'n Rat Fink.
1545 Rigging – help needed – what are these?
druxey replied to Louie da fly's topic in Masting, rigging and sails
I suspect Anthony Anthony represents 1 and 2 as pendants and tackle for raising rigging to the lower tops. (The pendant portion is later termed a Burton pendant.) There was one on port and starboard side. Usually these were taken to the rails inboard of the shrouds of their respective mast. The rather Rube-Goldberg style arrangement at 3 is interesting. Could it be a tackle to tension the fore topmast stay? -
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
druxey replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
I really like your artistry in softening the gold finish to your carvings and giving it a patinated look. Outstanding.- 883 replies
- royal caroline
- ship of the line
Grant's method works very well for avoiding that concave look!
- 64 replies
That Pegasus figure was beautifully modelled, Doris. With a fully-round figure, would you make it in two halves, or model it completely in the round?- 883 replies
- royal caroline
- ship of the line
Good save, Ed. It's been my experience that problems of this nature always occur at the cant frames, not the square ones - of course!
I like your frame 'hold-down' device. Are the larger cross-pieces above and below the frame fixed or are they movable?- 324 replies
A serving machine that serves you well
druxey replied to dafi's topic in Modeling tools and Workshop Equipment
Your mention of Munchausen's ducks made me smile. Nice examples of serving you have there as well. -
How to harden scale rope
druxey replied to Geoff Matson's topic in Rope Making/Ropewalks's Discussions about Rope Making
It's better not to harden line (rope) if you are then going to spin it up into cable. -
ancre LE BONHOMME RICHARD by Jeronimo - FINISHED
druxey replied to Jeronimo's topic in - Build logs for subjects built 1751 - 1800
Nice to see the replay of your progress!- 662 replies
- bonhomme richard
- frigate
I assume that the extensions are there only for long pieces of stock, Gaetan? Nice microphotographs, too. Is there anything that you are not expert at?
- 728 replies
- le fleuron
- 64 gun
Those really are lovely looking blocks, Remco.
- 1,207 replies
- sloop
- kingfisher
The Planking Inside
druxey replied to Thom's topic in Building, Framing, Planking and plating a ships hull and deck
The 'right answer' would take up several chapters of a book! Probably the best short answer is to look a Ed T's build log of Naiad. You will see how complex this is. The only short answer is to the question of plank length. Standard lengths in the 18th century British yards were either 24' 0", 26' 0" or 28' 0". The butts were staggered or offset from the outside planking for maximum strength. -
Scrapers and scraping.
druxey replied to mikeaidanh's topic in Building, Framing, Planking and plating a ships hull and deck
A proper 'hook' on the scraper's edge is critical to using this tool. I also file off the corners of my scrapers so that 'dig in' is avoided. Check the url that Richard has kindly provided. -
Properly laid line, hardened, should not unravel when cut. The opposing torque in the strands/threads/rope should cancel each other out and provide a 'balanced' line. -
The crossjack is indeed a yard, but one not set with a sail.
I absolutely agree, Patrick!
And don't forget, these old-time model makers had no power saws, mills or other machine tools to produce these masterpieces!
