Everything posted by druxey
I believe that the cleats are, like everything else, proportional.
- 1,215 replies
- sloop
- kingfisher
Good catch, Toni! Now you can be truly proud of yourself for fixing it.
- 1,449 replies
You are quite correct about the fact that belaying pins were unusual in British ships of this date, Hamilton. It was only after the bulwarks became closed in and the rails no longer available for belaying to that pins and pin racks proliferated. re R.C. Anderson: as a researcher in your field, you'll have no trouble finding your way around his book!
Anderson is good, but it is not for the beginner. One has to sort out the information one needs from the different eras and, depending on the edition, different nations.
Being scared is not helpful, but a healthy respect for any power tool is a good thing. Mark's advice to listen to your intuition is excellent. That applies to life as well as model making!
Cool tool lathe Unimat (moved by admin)
druxey replied to Sjors's topic in Modeling tools and Workshop Equipment
The 'original' Unimats (models DB200 and 1000) are a better bet: no plastic parts. They are available on eBay. My Unimat (from 1970!) is still going strong. It's not quite as accurate as a watchmaker's lathe, but it is just fine for ship modlemaking. You can use it s a mill/drill press and there are many available accessories. I used the miniature circular saw unit for cutting planking on my earlier models. -
Echo by Maury S - FINISHED - Cross-Section
druxey replied to Maury S's topic in - Build logs for subjects built 1751 - 1800
I think most folk remove their models for fairing up. Kind of hard on the knuckles near the keel otherwise, I would think.... Sanding sealer can be used any time. It does not seem to affect glue adhesion later on. Poly finish could be an issue.- 324 replies
Very neat machining! This is a very impressive model for both size and quality.
- 2,215 replies
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
druxey replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
These newer LED grain of wheat bulbs look much more realistic and convincing. Now, how to make them flicker....- 883 replies
- royal caroline
- ship of the line
Greg wraps the area he wants to de-bond with plastic wrap to retain the isopropanol where he wants it. It prevents weakening nearby joints.- 324 replies
Good to see something different being tackled, steam schooner.
- 208 replies
- john cudahy
- finished
Lovely, but don't fix the cleats yet: it's difficult to thread the lashing lines through if they are firmly in place!
- 1,215 replies
- sloop
- kingfisher
Question on use of crowsfeet on ship rigged vessels
druxey replied to Beef Wellington's topic in Masting, rigging and sails
Excellent advice from Blue Ensign and Jim Lad! -
So far, so good. She's looking very nice indeed.
- 43 replies
- lauck street shipyard
- kingfisher
Copper Plating Pattern
druxey replied to capnharv2's topic in Building, Framing, Planking and plating a ships hull and deck
Goring (belts) of copper with parallel to the waterline strakes came in in the 19th century, Before that, as Russ describes, the copper ended up at an angle at the waterline. -
Hull Planking questions
druxey replied to fnkershner's topic in Building, Framing, Planking and plating a ships hull and deck
See the three 'pinned' tutorials at the top of this topic for a full discussion of planking. -
Many thanks for this terrific re-run of your log, Gary. It is an inspiration to all builders of accurately framed and detailed models on this site.
Interesting how Humbrol paint lasts, if the tin is sealed properly. I've had similar experiences with it. Once thoroughly stirred it still is as good as new, as you said.
- 2,215 replies
Ah, the old isopropanol trick.... Works every time. And there seem to be a lot of times!- 324 replies
Sometimes line that is stiff or has 'memory' and loosens can be tamed with a wet brush. Try that on your clove hitches.
- 64 replies
Can anyone recommend a miniature hand plane?
druxey replied to Bettina's topic in Modeling tools and Workshop Equipment
Lee Valley is a good tip for quality planes. However, I find a well-honed chisel, used bevel down, easier to use than a plane. It is especially useful where a mast or spar goes from round to octagonal or square. You can 'get into the corner' nicely with a chisel.
