Everything posted by catopower
Having completed HMS Alert, which is now safely in a case, I'm left with a kind of paper emptiness... I have plenty of projects, but I'm so accustomed to having a paper model project in the works that it just didn't seem right to not have one now. So, I've taken on the 28-gun Enterprize-class 6th rate frigate HMS Mercury. Shipyard (Vessel) makes 2 versions of HMS Mercury. One is a 1/72-scale boxed kit with laser-cut parts and all the fittings, brass cannons, resin figurehead, wooden spars, cloth sails, plus paints, brush and rigging line, etc. However, that version is a lot pricier than the simple 1/96-scale paper model where you have to cut everything out yourself. I got the latter from Ages of Sail for around $40. The kit includes pre-printed parts that you have to cut out, plus laser-cut framework that makes hull-construction very quick and accurate. I've actually had this kit for quite a while, probably at least a year or more. I also started it some time ago so I would have a hull that illustrates how these kits go together. I was going to just do a partial start and give it to Ages of Sail as a demo model. But, that never happened. As I got further along on the Alert, I thought about how interesting a larger ship might be. Also, knowing the complexities of a 3-masted square rigger, I thought I might just build this as a kind of admiralty style model. Possibly building a launch ways and adding pole masts for the launching flags. In fact, right now, that's my plan unless I eventually change my mind and decide to rig this model. The kit includes some 15 pages of printed parts, the laser cut framework, several sheets of drawings and templates, including patterns for making sails. Printed parts are included for two different color schemes. The completed, fully rigged model, measures about 26" long. The hull itself is just about 16" long. I put the hull framework together many months ago. It goes together very easily and takes very little time. More recently, I started putting on the first layer, which basically turns the model into a hollow solid hull model. As you can see, I also added the deck. The parquet floor is a separate piece which sits on top of the wood-pattern floor. Lastly, over this past weekend, I wanted a distraction, so I started working on the cabin partitions. I have to say that this is one advantage that these paper models have over their wood counterparts – there is much more internal arrangement provided in these kits. It even includes furniture for the great cabin. So, there you have it. Another paper model begun. As I said earlier, this isn't a priority project, just something I'll tinker with over time. But, like HMS Alert, it may very well get to the point where it takes on a life of its own and demands more of my time to take her to completion. Clare
ratlines-At what scale do you just use an overhand knot?
catopower replied to bear's topic in Masting, rigging and sails
Like John, I clove hitch down to 1/96 scale. I prefer the way the ratlines hang when tied with a clove hitch. If you use an overhand knot, the line on one side of the knot hangs nicely, but on the other side, it starts with an upward wave. Below 1/96, I would probably just consider gluing. But then, I've never built anything with ratlines smaller than 1/96. Clare -
Thanks again everyone for the kind words. Druxey, I'm like a stealth ship modeler. Nothing... nothing... nothing... then whammo! But, seriously, HMS Alert is officially complete! I just adding a bunch of rope coils and have the case nearly finished. The case is an acrylic box which will be brass trimmed, and it will set on a cherry base. I'm ship modeler, not a woodworker, so don't anybody expect too much. I hate building cases. But, it's necessary to keep the model save. Plus, if properly done, it "frames" the model nicely, and makes it look more valuable. The model will have a home with a fellow ship modeler who's been admiring it and inspired me to take it to completion – it started as just an experiment on paper model making. However, we've made arrangements for me to take it to the NRG Conference in San Diego this October. Having felt a kind of strange separation anxiety from paper model making now, I've decided to move forward on another one to work on in the background, the 1/8" scale HMS Mercury – not the expensive, larger boxed kit, but the smaller CHEAPER paper model. I purchased the kit from Ages of Sail and picked up a "Super Detail Kit" for it from GPM. The detail kit includes gun carriages, capstan, gratings, ships boats, and some other parts in laser-cut cardboard. Most importantly, it provides laser-scribed scrollwork/figurehead so that's not so 2D, plus some nice laser-cut parts for the stern gallery lights, which are just printed paper in the basic kit. I'll start a build log on it in the near future, but I'm focussing my attention to other projects I need to get done. I will probably get far enough along by October to show it off at the Ages of Sail table at the Conference. I'll post the remainder of the HMS Alert photos in the Gallery. Thanks everyone for following my build! Clare
We're VERY close now! I finally finished building up the fashion pieces and boom crutches at the stern. This was the probably the part that took the most creative thinking of the whole model. The paper fashion trim didn't fit due to construction variation in my model – that is, I didn't line up the parts as intended! Also, the drawings weren't very clear as to how the parts fit and just what parts were needed at the rail. This is the reason I'm doing this work after most of the rigging is done. It took me a long time to decide on how to best approach the problem. As it is, it seemed to work out. Luckily at 1/8" scale, the details are too small to really discern any problems. Or rather, if there is a problem, my eyes are worn out enough that I can't see them. Rigging is nearly complete now too. I just added the braces to that topsail spreader yard and just need to secure them once the positioning seems good. Next, I'll need to add braces to the small upper yard. The hardest part of the rigging now is really just how to secure the sheets for the jib. Not that difficult, just requires a little more thought because of how low I have mounted it. Last thing will be to add the flags and their halliards. Should have things wrapped in another week or two! Clare
Some criteria for starting a new group project
catopower replied to Chuck's topic in Group Projects on Model Ship World
Carving is great idea and so is sailmaking. But there is one subject that I would absolutely sign up for on a group build, and that is making figures for ship models. I've tried making figures before, I have a couple books that talk about it, but I haven't been very successful at it. Would love to be able to make figures in 1/8" scale, 1/4" scale, and even 1" scale. Clare -
That's excellent news Daniel! You must now have a HUGE pile of work ahead of you. Are the Mini-Mamoli kits going to continue to use pre-carved hulls? Just curious. I expect to find out that you'll be locked away in a ship model kit designing dungeon for many months to come! Best of luck with the new product line. I'll be looking forward to seeing the new re-releases. Clare
Hobbie, A lot of the mantua kits come that way. It was a very early way of providing etched brass parts. You're going to want to first cut the parts to the outer blue (thick) edge. Don't cut too close – use a file to finish the edges. For some of the larger parts, in particular the ones that have multiple windows, I think you're going to have to cut them further, like to the inside of of that blue border, but check the fit of the part, to make sure first. You're probably going to want to paint instead of leaving it all as plain brass. The blue is, I believe, a residue coating that protected the metal from the acid bath. You can remove it by using a very find sandpaper. Paint the recessed areas as necessary. If you like the coloring of natural brass for the raised areas, just lightly sand away any paint you got on the raised areas. Otherwise, paint the raised areas carefully. Clare
Thanks again all for the nice comments. Sorry, it's taken me so long to come back here. Once I got the model off the workbench and onto the shelf, I got preoccupied by the next piece of business. For one, I just wrote up a piece for the Nautical Research Journal. Hopefully, it will make more people aware of this wonderful kit. In the meantime, I know of two others who will be building the Tosa Wasen kit and I hope to see a build log from one of them soon! mwb?? For the record, I'm tinkering with the construction of a 1/10-scale Japanese traditional boat workshop display. It's really just the framework of the shop with much omitted for visibility. I'm not sure how interesting it will end up. I'm still tinkering with ideas. If you don't know anything about how these boats are/were built, you should visit Douglas Brooks' blog and/or buy his book: http://www.douglasbrooksboatbuilding.com. To get to his blog directly, visit http://blog.douglasbrooksboatbuilding.com. He was just in Japan for a couple month building a rice field boat for a museum up on the Noto peninsula and another boat, from Northern Japan I believe it was, for a museum in down in Kobe. The boat I'm going to piece together for the boat workshop is an Urayasu Bekabune, a small fishing boat used on Tokyo bay. You can find more info about the boat on Brooks' website. The one for the boat workshop display will be only partially built, since the idea is for an "under construction" scene. But, I'll complete another one, since at some point in the project, I'll know how. And, it's a very simple type of boat – much simpler than the Tosa Wasen. Clare
- 51 replies
- wasen
- thermal studio
1/10-scale Japanese Fishing Boat kit from Thermal Studios
catopower replied to catopower's topic in Wood ship model kits
Oh, I DID see that! I don't know what I was thinking. Apparently, I was not. Thanks for the wake-up call wefalck! Clare -
Thanks Wefalk, I actually saw the cover in the last issue of the Nautical Research Journal, so I visited that website and ordered a copy. It took me a while to translate from French, but found it an interesting Part I. I'm looking forward to the other parts of the series. One thing that wasn't clear to me was the name of the author. Do you know who wrote it? Clare -
Hi Mark, I'm glad to hear that you're getting the kit. I'm only just starting to hear from people who are buying the kit. You're the second person in a week that I've heard from. FYI, the other person tried emailing info@thermal-kobo.jp and waited a week with no reply, so he emailed shop@thermal-kobo.jp and got a reply within 24 hours. Here's his post on Model Space: http://forum.us.model-space.com/default.aspx?g=posts&m=189319post189319 The link you provided didn't work for me, but this did http://thermal2.exblog.jp/i65/ without the 1// at the end. If this is the page you're referring to, that's Douglas Brooks sitting next to Masaki Tanimura, who runs Thermal Studio. Douglas had mentioned seeing the Tosa Wasen model, a few years ago, but didn't remember any details about it. I know he stopped in Kochi City a few years back and stayed overnight with a friend who created the drawings that the kit is based on. I think this photo is from that visit. Looking forward to seeing your build log! Clare -
Thanks Cog. I made a bit more progress this past week, though it doesn't really look like it. I finished rigging the lines dealing with the main sail, and added the staysail, halliard and downhaul, added brace pendants to the topsail yard, and then some. Plenty more to do still. I have a lot of bowsprit rigging to deal with, plus the jib and squaresail to add. Also have a little bit of hull details to add and a few small deck details. But, it's getting there. Clare
Hi grsjax, Ages of Sail carries their kits as well as kits they make for other companies like the Nordic Class Boats line. I thought they looked similar in production style and quality to Dusek kits. The Panderma that Thanasis posted a link to (a build) seems pretty popular. The Mariefred (a Nordic Class Boats kit) won some kind of best product award in Germany last year. They do have some unusual subjects, which is really nice. Clare
Tony, What a fantastic job you are doing on this build. The only negative comment I can make on this blog is that there is only a LIKE button, when there should be a LOVE button! A masterfully built model. I hadn't looked in on it before, but now I'm going to have to go back to the beginning of your blog and start learning how to build a ship model the right way. Clare
- 269 replies
- Caldercraft
- First build
(and 3 more)
Thanks for the comment and advice Carl, all. Well, I think I'm able to declare success! Had the quarterly meeting of shipmodelers at our gathering place at the Vallejo Naval and Historical Museum yesterday morning. After nearly 3 hours ship model shop talk about lunch with a fellow shipmodeler afterterwards, I managed to have a marathon session of rattling down the shrouds. All worked out pretty well and I didn't notice the stretching issue as much. So, this morning, I tried spraying the completed work with the fixative. The matte varnish had a bit of sheen, so I used the matte fixative, which dried much faster, so I could use a heavier coat. It didn't really do much to lock the clove hitches in place, so I just brushed on some acrylic matte varnish. I know it works and it's quick to apply. I trimmed off the excess line from the ratlines and the shouds looked okay. But, then... I went ahead and took a thick piece of black rigging line, threaded it under the shrouds and then pulled the line tight. As I did, I could feel it slip tight against the mast head and I could actually see the shrouds tightening up. I know it's cheating, but you will never be able to see this extra piece of line at this scale. And, after all, much of model making is about the art of illusion. Below, you can see the excess line sticking out. So, now, after I secure that piece of line and cut the excess, I can comfortably start rigging the standing rigging on the bowsprit. Clare
Hi Carl, You reminded me that I have a couple cans of artist's matte spray from Prisma Color and from Grumbacher. Do you know how those compare with the hair spray? Grumbacher is a Matt Varnish, Prisma Color just calls theirs "Fixative". I'm guessing that "fixative" is just an expensive can of hair spray. Appreciate the advice! Clare
Hi Cog, I never really considered it. Do you know what kind of chemical is used in hairspray? I assumed it wore off after a short time. But, now that you mention it, I have hit the hull and deck with a little Testor's Flat Lacquer. Hides those tiny glue specks really well. I was thinking about hitting the rigging with it to help seal the line and to secure the knots. So, maybe that's the same idea as what you're suggesting. Clare
Thanks Carl, I appreciate any comment that suggests that I don't have to fix anything! Mark, to answer your earlier question, the Morope is a little shiny in the closeups, as you say. And to answer your question, it's Polyester. Clare
Hi Mark, The need for pre-stretching might be the issue here. Too late for the work done so far. But, it hasn't affected the backstays or the forestays, just the shrouds. The other thing that I started to consider is the perhaps there IS a paper model issue here. I'm wondering if anyone with paper sailing ship model experience has noticed some settling of the mast down into the hull, even a miniscule amount. Just in case, in the future, I thing I would put some reinforcing at the mast step. Thinking on it now, I can't imagine the card stock NOT crushing just a little under the strain of the rigging. But, I could just be imaging excuses for my own shortcomings here. I finished the ratlines on one side, but haven't trimmed or glued the knots in place yet. Still thinking about how to procede. I might have to step away from it for a bit and look at it with a fresh perspective. Tomorrow, there's a ship modeler's gathering I organize at the Vallejo Naval and Historical Museum near Mare Island. I'll probably take it there and see what people think. Again, I may rattle down (?) the starboard side shrouds and then see what I can do to tighten it all up together. Clare
In my last post, I didn't have any photos to illustrate the differences in the rigging line that I was referring to. So, I took a few shots to post here. Above is a coil of Morope on the left and Syren line on the right. They both have good definition and look very nice. I don't recall the difference in pricing, but I don't remember it being a very great difference. Here is a closeup of the Morope line. And a closeup of the Syren line. The above are roughly equivalent sizes. And, of course, for my model in 1/8" scale, I'm only using very small sizes. So, the larger sizes will look a little different in comparison. What's shown is roughly 0.4 mm diameter line. When the Morope is glued so that it doesn't unravel, it doesn't look too different from the Syren line. Except of course, the Syren line looks like this freshly cut, without any special treatment. While this doesn't usually happen to me since I make sure to glue the line before cutting it, here is the Morope and the Syren line both freshly cut with no special treatment of the line. As you can see, the Morope wildly unwinds. It will continue to do so if it's not tied off or treated with glue. It's not necessarily a problem if it's handled properly. But, it's a shame it's like this as the Morope does have very good visual definition, and is available in left and right hand twists. I haven't run into any serious problems with the stuff as far as I can tell, but it is a concern as I work. Also, the Morope does seem stretchier and doesn't hold it's shape as well as the Syren line. For instance, if I make a coil of line, the Syren line is easier to work with, and holds the shape better. I'm not trying to push one or the other. I'm just pointing out the difference and a possible related issue I'm having with the forward most shrouds, which are served Morope line. Clare
Well, just to report that I ran into my first real problem with the Alert. However, it has nothing to do with the fact that this is a paper model. This has to do entirely with the rigging material I chose. I decided that this small model provided a good opportunity to try using a product called MOROPE. This stuff has been around for many years. It's made in Europe and there is a person in the U.S. that handles U.S. sales of the product. The stuff looks really good and is visually stiff competition for Chuck Passaro's rigging line because it is well defined and is available in both Left and Right-Hand Lays (both S and Z laid). The first downside to MOROPE is that it's not really properly turned. If it was, when you cut it, it wouldn't immediately start to unravel. Seems like they don't twist the strands first... or is it yarns or threads? Anyway, when you cut Syren line, nothing bad happens. To keep the MOROPE from unravelling, you need to hit the area you're going to cut with some glue first. Then, it cuts just fine. However, now I'm tying ratlines – yes, lovely ratlines in 1/8" scale, so the rows are only about 5/53" apart. As I'm doing this, I'm finding that the MOROPE shrouds are stretching just a little. It may be a small enough stretch that I can compensate a little. But, this far into the rigging, if I can't work with it, I'm going to have to tear most of it down and re-rig. For the most part, I suppose it wouldn't be TOO terrible to take the rigging down as it's mostly a matter of cutting lanyards, which can be replaced. But I don't look forward to the idea of reworking the shrouds, deadeyes, etc. We'll see. I'm almost half way done with ratlines. There's only one mast – it's really not like I'm having to worry about rigging on a clipper ship. So, I'll get through the ratlines, trim them, and see how it all looks. I'm sure it's something like I hadn't stretched the line properly first. But, the line is stretchy to begin with and it seemed like the springiness would help to keep the shrouds taught. The detail at this scale is so hard to see, that it might be enough to cheat and tie an extra piece of line tight under all the shrouds, forcing them to lift upwards a millimeter, which would probably be enough to do the trick. Nobody would ever be able to see the fix. Anyway, we'll see how it goes. More later. Right now, it's back to clove-hitches... "under, over, through... under, over, through..."
Before putting the main stays in place, I needed to get the shrouds and backstays secured. The problem is that they get in the way of dealing with the mainsail. So, I worked on rigging the mainsail first. The sails came as a set from Shipyard. I originally ordered these direct from Shipyard, but it appears that's no longer possible. I think the company may have blocked U.S. IP addresses, so as to support U.S. dealers, namely Ages of Sail, which sells the Shipyard kits. The problem is that Ages of Sail doesn't currently sell the various accessories. For the moment, if you want those, you can order them from http://www.gpm.pl. Next, I'll be rigging the backstays and then the mainstay. When I want to something a bit repetitive, I will get started on the ratlines. But, that shouldn't take too long, given that there is only the one mast with only lower shrouds. Clare
Quick update. I started the rigging process and added the lower deadeyes using 24 gauge annealed steel wire. The kit provides faux chainplates to glue over the wire, which I added later. First, I served the shrouds where they wrap around the mast head. I decided to go ahead and serve the forward shroud the full length using the finest thread I could find, short of using fly tying monofilament line, which I've had trouble using in the past. I made the shrouds long and used a method for locating the upper deadeyes show in some of the Shipyard kit instructions, which has you tied the ends of each shroud together with it's corresponding shroud under the hull of the ship. I just used clips. Then, glue the deadeyes to the shrouds all at the same height, making sure the deadeyes are all oriented the same. Once the glue has dried, you then loosen the shrouds, cut off the excess and then finish wrapping deadeye in the shroud end and trying things off. Of course, you have to make sure that you end up with the deadeye oriented correctly as your wrapping the shroud around it and tying things off. This seemed to work okay, though the served shroud doesn't stretch like the other shrouds, so I seemed to have more issues with its alignment to the rest when I reeved the deadeyes. I didn't tie off the shroud lanyards yet, as I thought I might need to take the mast off the model to work on adding the mainsail, square topsail and boom, gaff and yards. But, given that there is a fair amount of room to work with the mast in place on this cutter rig, I may go ahead and tie them off. I'll probably add the backstays and mainstays before I start on the ratlines. Sorry, the photos I've been taking lately look terrible. I have been experimenting with lighting and backdrops and such and having really mixed results with everything I've been trying. I have some ideas yet, which I can try another time. Meanwhile, I've started adding more blocks, eyebolts, etc. I think I want to get the mainsail into place next before I add the remaining stays. Clare
