pete48
Everything posted by pete48
  1. Hello Michael, Yes the transom does go above the planking once the deck and cockpit coamings are installed it should look like the pics. Best Regards, Pete
  2. Today I started by Building a cradle , while I pre soaked the material to finish the planking. Once the cradle was built I finished up the planking, athen I finished rough Fairing the hull. next it will need to be sanded with 600 grit, to get it ready for epoxy . I am very pleased with this build as it has been a challenge. Here are the results
  3. Thank you Michael, I appreciate it . Hows the Cutter comming along ? Best Regards, Pete
  4. Today, I finished the Cockpit floor , first I cut out Birch ply for the bench supports and stained them cherry . Next was to cut out the Deck hatches on the fish well deck . then I cut out more birch strips for the deck . I installed the bench supports and installed the birch strips on the fish well deck .I sanded the Cabin top to get it ready for a second coat . I like how this has turned out Here are the results
  5. Thank you Bob, I appreciate it , I am happy with the way its turning out Best Regards, Pete
  6. On Keel # 4 Today, I started by shaping the Mast and fitting it. I decided to add a square piece of Birch Ply as a Mast step. I then stained the Birch on the Cockpit face , Cabin entry and the companion way rails a Cherry . On the Cockpit floor I made a new Hatch cover ( I didnt like the first one ) Laid out the Deck for the cut outs ( I will do the Fish well deck the same as the Cockpit floor ) Then Painted the Cabin top a gloss white. Here are the results
  7. Nice work Jack, she is really taking shape . I like your steam box set up. Best Regards, Pete
  8. Looks like you got your work cut out for you . Should be a great build, I look forward to watching your progress Best Regards, Pete
  9. Thank you Steve, I think the same thing ( sexy hull ) I thought the first photo really captures the essence of this boat . I am happy with the way this one is turning out. Best Regards, Pete
  10. Hi Rchard, I can understand about needing a break ( I just had one for about 4 months ) The boats are starting to come together . Thanks for the likes Best Regards, Pete
  11. Today, I thought I would finish Planking the Herreshoff, However I realized that I did not cut in the 1/8" for the Transom. I decided that I would add a 1/8" X 1/8" strip to the stern of the Keel, and move my Rabbet line 1/8" aft. That is somthing that I will remember for the next one ( and there will be a next one ) there are already a few things that I would do differently. ( That will be for the next build log ) Anyway I then started soaking my planking material while I finished shaping the sheer line ( I am pleased with the result ) It matches the Print . the Planking went smooth and all the seams are nice and tight. I did a good amount of Fairing . Next will be to finish the Planking and build a Cradle . I have had alot of fun building this boat ( my favorite so far ) and aside from the transom sticking out an extra 1/8" ( or the boat being 1/8" too long ) the rest of it is right on the money. Here are the results
  12. Looks Good Matti, sounds complicated from your discription, 66 parts wow. I am sure you will do a fantastic job as always Best Regards, Pete
  13. Today I decided to work on the Cockpit Floor for Keel # 4 , I first laid out the Cockpit Floor so that the Bildge could be accessed, Then figured out where the Bench would go . I then cut out strips of 1/64" Birch ply and roughed in the Pieces. Then fine tuned them Painted the edges Black ( I got a little sloppy ) and glued it up . This is the First one I have done like this . I will do the same for the Fish well Deck . I did start to cut out the bench sides and proped them up for the Photo. Here are the results
  14. Thank you Russ and David, The Boat on the left is Keel # 3 , This is the Transom I like the best I love how the Tumblhome rolls over, And I will do this style again Best Regards, Pete
  15. Hi Dan, Very nice work Beautiful job nice detail work Best Regards, Pete
  16. Hello, Amazing work . the details are awesome . Best Regards, Pete
  17. Hi Antony and Alex, This does look like a fun build, I will pull up a chair and watch Best Regards, Pete
  18. After my morning Coffe , I unmasked Keel # 3 and took a couple of shots with Keel # 4 I wanted to show the Tumblehome and the natural curve it makes at the top of the deck. here is what it looks like
  19. Looking good Russ, I agree with Keith the sheer line looks sweet Best Regards, Pete
  20. Hi John, Looks like she is starting to take shape, Nice work Best Regards, Pete
  21. Hi David, Thank you I try to go with what looks good Best Regards, Pete
  22. Hi David, For Keel # 4 I have not decided yet, on Keel # 3 the Cabin / Cockpit Coamings are made from a Birch plywood and I am going to use a Cherry Stain for the brightwork then a varnish , And I am going to use a sand color for the deck, I may make the fish well deck and cockpit floor a teak deck by using strips of Birch with Black paint as Caulking. Best Regards, Pete
