Everything posted by MrBlueJacket
So while the traps are done, the package includes 3 buoy blanks (see post#2). Here's a photo of them finished.
- 24 replies
- lobster trap
- red baron
The final step is to paint the trap. I used some light gray, then dusted it with olive drab to make it look like algae scum. And with that, this comparison is over. We will be phasing this new way in over the next few months.
- 24 replies
- lobster trap
- red baron
After all the slats are on, the remaining steps are the same for either way. Add the netting and opening
- 24 replies
- lobster trap
- red baron
- 24 replies
- lobster trap
- red baron
- 24 replies
- lobster trap
- red baron
New way: Attach the sheet of slats. Much easier, all slats are evenly spaced. Once bent around the hoops and glued in place, it is a simple matter to trim off the edges.
- 24 replies
- lobster trap
- red baron
Next step - old way: individually attach the slats to the hoops. Tedious, and prone to misalignment.
- 24 replies
- lobster trap
- red baron
How about the Charles P. Notman? Or maybe the large Friendship sloop and put a dollhouse figure or two in it. Picnic, maybe?
- 85 replies
- perry
- BlueJacket Shipcrafters
- 24 replies
- lobster trap
- red baron
Next step is to finish the bottom. Old way, add 4 cross braces (carefully fitted) and finally add the strip wood bottom pieces.
- 24 replies
- lobster trap
- red baron
Congratulations Dave! Your customer file now show a 10% discount on the next kit you get from us. Nic
- 21 replies
- Spray
- Bluejacket Shipcrafters
I have decided to build both the old and new traps so people can compare the two. First step old way is to cut the bottom stringers from stripwood, champher the ends and drill holes. Then free the hoops and glue to the stringers. The new way is to again free the hoops, but now you just glue them to the pre-cut holes in a lasered base.
- 24 replies
- lobster trap
- red baron
The new kits have laser cut hoops, base and the slats are pre-done out of laserboard so they will be nice and even. As I build this prototype, I will post updates.
- 24 replies
- lobster trap
- red baron
We are upgrading our lobster trap kits that go in our r/c lobster boat, Maine lobster boat, and Red Baron. The old kit design had laser cut hoops and stick wood construction.
- 24 replies
- lobster trap
- red baron
Math correction here: 1:72 is 1" = 6' 1"=8' is 1/8"=1' equals 1:96
- 3,560 replies
- clipper
- hull model
Hi John, It was Dr Al Ross who you talked to. Nic
- 127 replies
- Bowdoin
- Arctic Exploration
(and 3 more)
Now that it's done, your customer file shows 10% off your next kit from us. Nic
- 127 replies
Well done, Stan! Your customer file now reflects a 10% discount on the next kit you get from us. Love the way you have mounted it on ways, too. Nic
- 85 replies
- perry
Hi Bill, I think you can still get sheets of "plumber's lead" which is about 1/8" thick and pretty easy to cut.
- 41 replies
- muscongus bay lobster smack
I've never seen a model come together so quickly. Do you get any sleep? Nic
- 21 replies
- Spray
Congratulations! Your customer file now reflects a 10% discount on the next kit you buy from us. Nic
- 23 replies
- Spray
