Welcome aboard Jon. OC.
Stunning work Kevin, those decks look loverly made all the more so by the tennon joints. OC.
- 312 replies
- enterprise
- caf
Having a re-think - if its the last frame causing the problem with it potentialy being too far back creating too sharp an angle, how about adding some more wood behind the last frame/but glued to it, this would enable you to sand a more gentle profile for the tuk, I think that would help a lot and take away such a sharp angle. OC.
Are you using a "Bending Block" with your heat Iron for bending? it should have come with your Iron, it is such a useful tool for getting tight turns with the planks. What I used to do with mine was to soak the plank you want to fix - say one on each corresponding side, then when I t feels wet enough with a bit of bend to it - pit it over the bend in the Bending Block and using the heat from the Iron push down gently in the curve of the block till the heat/steam gently pushes the plank down into the curve. The key heare is not to push too hard - Just go gentle and feel the bend , it takes a bit of getting used to but it does work - I have bent a near circle using the tighter of the bends in the Block. Give it a try. OC.
Now that is looking Nice - sharp details and you was so right to do the decks with the wood - it really sets the ship off against your excellent painting. OC.
- 49 replies
- Lusitania
- Gunze Sangyo
Afternoon all, I'm back - I decided to give my Chinook build a slight rest while I do somemore work here - I decided to have a go at building the chap who was in overall control over the Farm no less than - Major Georg von Baring, as he stayed "sted fast" with his army right through the battle for the farm. Pic off the net showing him on his horse. OC.
Evening all, I made some good progress today - I started on the rear roof area above the ramp, this area in the kit is a little bit bare of any detail, so after looking at some photos online - some scratch building was called for, so some card and a few other pieces later and I had a plate to be glued to the roof, I also added another one slightly smaller - then a few coats of paint and a bit of shading and this is the result. OC.
