Old Collingwood
  1. Thanks Ken, indeed without both I would be in trouble - I put my glasses down the other day and I couldn't find my laptop let alone see to use it, but with my readers and magnifiers I seen to be doing ok, but when I have both on and at the table if the admiral calls me I go - "What what - who's there"? OC.
  2. Evening all, more work again this evening - I have made a start on Two officers from the French regiments, both are assembled and awaiting painting. One of the pics shows them against a small tin of paint to show what scale I am working with. OC.
  3. I also built this for my Admiral - have a look as I did some different things with the build. OC.
  4. I think that wood (pontos simulted decks) or proper decking as we use in our wood kits can look simply superb, I have used both at different scales. Scribing especially for planes can be really useful to open up panel lines that have been lost with sanding - or just plain missing. OC.
  5. I can't see most of them also - just lots of picture code. OC.
  6. Welcome aboard Jon. OC.
  7. Nice clean workbench mate🙃👍 OC.
  8. Stunning work Kevin, those decks look loverly made all the more so by the tennon joints. OC.
  9. Evening all, right then Major Baring and his steed is painted just needs flat coating - but I need to wait for the weather to dry before I can sprey outdoors. OC.
  10. This photo might help - again its not mine I got it off the net, but it does show a (slightly more gentle tuck round to the back that would help with the planks) I had a similar problem when I was working on tha same kit about 10 years ago - it was a real nightmare to get right. OC.
  11. Having a re-think - if its the last frame causing the problem with it potentialy being too far back creating too sharp an angle, how about adding some more wood behind the last frame/but glued to it, this would enable you to sand a more gentle profile for the tuk, I think that would help a lot and take away such a sharp angle. OC.
  12. Does it look like this - you could use the half moon shape part to get a tighter turn, its what I used to use for some really tight turns. Pic not mine. OC.
  13. Evening all, right Major Baring has recieved some paint - just need to paint his boots and styrups. OC.
  14. Are you using a "Bending Block" with your heat Iron for bending? it should have come with your Iron, it is such a useful tool for getting tight turns with the planks. What I used to do with mine was to soak the plank you want to fix - say one on each corresponding side, then when I t feels wet enough with a bit of bend to it - pit it over the bend in the Bending Block and using the heat from the Iron push down gently in the curve of the block till the heat/steam gently pushes the plank down into the curve. The key heare is not to push too hard - Just go gentle and feel the bend , it takes a bit of getting used to but it does work - I have bent a near circle using the tighter of the bends in the Block. Give it a try. OC.
  15. I know, thats why I cheated on my Pearl build - tried but said to myself "nah too much hassle" but enjoyed the ratline -ish (tiny ish) OC.
  16. Now that is looking Nice - sharp details and you was so right to do the decks with the wood - it really sets the ship off against your excellent painting. OC.
  17. So I have made another start - here is Major Baring on his horse un painted. He is not glued in the saddle yet so I can fiddle around with his position. OC.
  18. You need to invest in Ten pairs of hands so you can "multi-multi-multi-multi task and build many"😁 OC.
  19. Afternoon all, I'm back - I decided to give my Chinook build a slight rest while I do somemore work here - I decided to have a go at building the chap who was in overall control over the Farm no less than - Major Georg von Baring, as he stayed "sted fast" with his army right through the battle for the farm. Pic off the net showing him on his horse. OC.
  20. Right then everyone, I'm going to put a little hold on this - Just when it was getting interesting, as I want to do somemore work on my Waterloo project - see you over there😉 OC.
