You have the patience of a saint - then some, Fantastic. OC.
- 322 replies
- enterprise
- caf
Just sorted my pics out of my current stage - I have started working on the fabric bench seats in the cabin, these are plastic and are painted flat Red and Alum - I will place a few rows and leave the end sections in the up position (just for a bit of variety). The inner hull section is just leaned against the seat to show how it will go. OC.
Evening all, so - more work has been done (you know me I don't like to rush things) anyway I finished off the cockpit by painting the seat cushions a nice mid Grey colour, then when Dry I fiited the decal seat belts (no fuss to these - not as good as pe ones) then I brushed on a few coats of flat clear to blend them in - then I fitted the pedals (Four part buddies they were). Then after painting and weathering these I gave the whole area another coat or Two of top coat, then the cockpit bulkhead was glued in. OC.
I'm "abit" late to the party but it came to me - Isn't the Marry Rose similar? could you not use her plans to help with your hull planking? OC.
- 740 replies
- Tudor
- restoration
(and 4 more)
Kaiyuan Temple by RichieG - CAF Model - 1/75 - WOOD
Old Collingwood replied to RichieG's topic in Non-ship/categorised builds
One can really see the Inter- locking nature of it - wonderful stuff. OC. -
Amazing work you have put so much effort into this amazing build you should be so Proud. Congratulations. OC.
Keep an eye on your wood decks - mine had a habbit of trying to lift slightly around fittings - just a case of making sure its all pressed down. Looking really good. OC.
- 49 replies
- Lusitania
- Gunze Sangyo
Not sure if this might be of use - its decribes and shows the main RN colours - scroll down till you see POW (Ita alphabetical) OC. https://www.sovereignhobbies.co.uk/pages/british-royal-navy-colour-schemes
- 211 replies
- prince of wales
- tamiya
Just found your build - the hull planking with the first planking (I assume you will be laying a second layer of planks over the top as its normal procedure) is always a tricky/fiddly/nerve racking procedure - even the pro's like to get it out of the way. With your deck You have done a fine job - its neat and tidy and as others have said its easily sanded even with pencil in between the planks as the sanding action cleans as you are going. Keep at it you are doing fine. OC.
- 26 replies
- First Build
- lady nelson
I don't want to tie up EG's log with my rambling but I had to reply to Jack - I had the same about 9 years ago, went in for a pre arranged Hiatus Hernia op the surgeon debated doing it as a "Key Hole" job but in the end I was just sliced open (about a 6 Inch cut in my groin) same as your self no lifting for so many weeks but I was lucky I was out the same day, all is fine now apart from ocassional sensations from the wire gause they put in. Take good care of yourself. OC.
I would imagine that extra strengthening will add strength to the join, I remember my late farther building an R/C boat for me - he basicaly over engineered the hull - strengthening the hull and applying coat after coat of dope to the inside and outside hull followed by about 100 layers of paint. OC.
