Old Collingwood
  1. Evening all, I have been slowly working on my Two cavalry figures - my Life Guard and my Kings Dragoon Guard starting with my Kings Dragoon Guard, pictures are a bit pixalated and fuzzy as I zoomed in a bit to far with my iphone. OC.
  2. Excellent designing work brother CAD design is something I never did get my head around. OC.
  3. Tim this is looking really sharp and tidy, love the detail you are putting into this. OC.
  4. I would one day love to do soemthing like this in 1/56 scale as part of a dio. OC.
  5. Evening all, some more progress - while flat coating my figures I decided to do the same to my little pile of causalities. OC.
  6. Yes indeed - if you can build this kit - I think you can build any. OC.
  7. Just a quick update on my next move on this - I am still working on the figures that can be placed on the dio sections done, so that will be my Two Laife Guards they still need painting and weathering before being cut away and glued down on the roadway near to the Two 95th Rifles, then I really need to think about doing some more scenery as there is the back end that needs my grass - some headge near the cottage garden and groundworks in the garden (grass - soil beds). So still quite a bit to do yet (I also think it needs more French as there was loads in real life) these I need to get as I have used what I have. OC.
  8. Yep that will do nicely Craig - really impressive. OC.
  9. Just to add another angle - I think I sanded and shaped by bulkheads to run flush with the deck - but we all tackle the same situation from a different way. OC.
  10. The general way to do it is to glue the hull planking onto the face of the frames after they have been faired to take off the hard edges especially towards the bow and stern, if you dont do this the planks will not follow a smooth line where they need to bend up and around to the bow and stern. OC.
  11. Agreed mate - think I started from the deck level as well, was trying to express the need to plank the hull from the deck level up to the top of the frames before planking the deck. OC.
  12. Do you mean my rows of first hull planking? I sat the hull planking on top of the frames but to help secure the planks at the bow I did cut a slight groove into the head, but as long as you achieve a good curvature by soaking the planks in hot water (or even using a plank bending tool) then you might not need to put a grove in the head. OC.
  13. I faired the frames first then starting from the poop deck I started fittting the first planking keeping them level with the tops of the frames, I continued from the stern to the bow, working both sides then i worked my way down till my planks where just below the level of the main deck, then I cut the frames from the inside at the same height as the deck before planking it. OC.
  14. Follow the line and tops of the frames first, if there is a slight gap between the sub deck and the line of outer planks - it wont matter as your deck planks will cover that, you need to remove the frames level with the sub deck to get the correct inner beam, I have seen some builders leave the frames in place and plank the inside walls attaching the planks to the frames making the inner width from wall to wall to narrow. OC.
  15. I built up the outer planking first after fairing the bulkheads (to get a nice smooth natural line of planks) you could do this starting from the top from the Poop deck Frames and work down till you are just below the main deck height. Then you could cut the inner frame flat with the deck and plank the deck from the planks both sides (not forgetting you will need some inner wall planks to go on) that would save you trying to fit the deck planks around the bulkhead frames that would still need cutting back to your outer planking. Hope that helps. OC.
