Posts posted by Old Collingwood
We have a preserved one over here RN version -
https://www.fleetairarm.com/exhibit/grumman-avenger-ecm6b-xb446/2-4-13.aspx
OC.
- thibaultron, Canute, mtaylor and 2 others
5
15 minutes ago, mtaylor said:
Off to a great start, OC. Looking good.
Thanks mark, its interior green paint time next followed up with some more washes and a bit of hightlighting then some more additions to add, going to build things in stages like that - painting and weathering them as I go instead of assembling the whole sub sections and trying to paint/weather.
OC.
- popeye the sailor, mtaylor, lmagna and 1 other
4
2 hours ago, SigEp Ziggy said:
Thanks, Denis, I was struggling with the term, if my brain would come out of the fog, I probably have said capstan. Anyhow, I do not like the capstan around the main mast, and this model pre-dates 'Pirates of the Caribbean'. So, I am not sure if any ships were actually built like this.
I think it was put there for space reason (but agreed a very unusual arangement)
OC.
- Canute, SigEp Ziggy, mtaylor and 2 others
5
3 minutes ago, lmagna said:
That was the word/title I was looking for. I feel most comfortable wearing the title Basher! Fits most of my skill level to a T.
A kit "Basher " defines anyone who is prepaired to do their best with a kit and try anything they come up with.
I think its a great title.
OC.
- lmagna, popeye the sailor, Canute and 1 other
4
3 minutes ago, Canute said:
Nice start, OC. The wash makes those tanks "pop".
Thanks mate, trying to keep them natural still need to chase the interior green around then add more washes.
OC.
- popeye the sailor, mtaylor, Canute and 1 other
4
3 minutes ago, Javlin said:
I like the way that came out OC looks like a natural state.
Kevin
Thank you kevin,
OC.
- popeye the sailor, mtaylor and Canute
3
Done a bit more - I decided to fit some pipework - for this I used electrical fuse wire, I put a small smear of ca down then layed some wire, with a hairdryer to set It set in place - I then did the same to a run underneath.
I then painted both fuel tanks the brick Red colour - for this I used Red Ocre, after drying this I added a few coats of dark wash - very watery then dried in between each layer, the main green shade still needs to be applied.
OC.
- popeye the sailor, mtaylor, CDW and 13 others
16
7 hours ago, BLACK VIKING said:
Stunning job OC , love the pirates especially the one who has been on a bit of a diet lol
Martyn
Thank you Martyn, yep those pirates had their ways.
OC.
- mtaylor, popeye the sailor and Canute
3
9 hours ago, Retired guy said:
Very nice build OC 👍
Regards
Richard
Thank you Richard.
OC.
- mtaylor, Canute and popeye the sailor
3
10 hours ago, Kevin said:
lovely build, well gone on completing her
Thank you Kevin.
OC.
3
So! - It begins, I couldn't help it "I had to",
I got the box out - checked the instructions and found the first build section (Bomb bay), so I cut away the first sections needed then put them in a tub and with the aid of washing up liquid/hot water and a tooth brush, I gave the parts a clean to remove the release agent.
Then when dry I assembled the main bomb bay floor containing the fuel tanks, and the two bulkheads, this was set aside to dry.
Here are the first two pics showing the stage so far and the instructions stage.
OC.
- Jack12477, Edwardkenway, CDW and 10 others
13
1 minute ago, CDW said:
I thing the Spitfire Mk IX was their best looking Spitfire of all. Should be a real nice kit.
I was told by my farther they struggled to fit the beafed up engine in the same frame - they could have done with extending the frontal area.
oc.
I can see you and mark doing that Huey ride and posting the vid on here - that would be so cool.
OC.
3
Very nice work, bowsprit deck do you mean Forecastle deck - it meets the front of the ship near the bowsprit and can be flat from the mid ships or raised up.
OC.
2 minutes ago, rafine said:
Congrats OC. Really well done.
Bob
Thank you for having a read through Bob and your kind comments.
OC.
- popeye the sailor, lmagna and mtaylor
3
- popeye the sailor, mtaylor, Nirvana and 4 others
7
23 minutes ago, mtaylor said:
Looking forward to it, OC.
Thanks mark.
OC.
- popeye the sailor, Canute and mtaylor
3
You could do a door gunner mark.
OC.
- popeye the sailor, CDW, mtaylor and 1 other
4
2 minutes ago, marktiedens said:
Super nice OC.
Really looks the part!
Thank you Mark, really pleased you like it.
OC.
- mtaylor, marktiedens, Canute and 1 other
4
26 minutes ago, SigEp Ziggy said:
Same kit as I just finished - some suggestions - use wood dowels where ever you can, inside the two piece masts (lowers) and for the mast higher sections, also make wood dowel yards instead of the plastic ones (they will be far stronger for tying ropes against them) try to fit a wood deck if you can (far more realistic in my opinion) square off the rear cabin front area (thats if you intend to build her as the wicked wench or latter black pearl) also if you can try to use wood deadeyes and blocks - they all help to make a more substancial build.
Just a few ideas for you.
OC.
- lmagna, Landlubber Mike, Kevin and 4 others
7
So! Now the Pearl is finished - I will give myself a couple of days of then - I will make a start on the Mosi, I have all the stuff I need to build her I think so it should be interesting and quite different from the pearl.
OC.
Sikorsky CH-53 by mtaylor - FINISHED - Revell - 1:48 - PLASTIC
in Non-ship/categorised builds
Bring it on fellow basher - bring the bling.
OC.
