Old Collingwood
  1. Yep I have done similar - the top of the sail is open at the moment, so I managed to find one of my brushes where the handle fitted inside with a quite tight fit, I ran some gaitor pva down inside around the handle, with any luck it will hold the brush handle enough tomorrow so I can hold it to spray with. Then when dry I should be able to cut away the handle to allow the top of the sail to be fitted. OC.
  2. I have it now mate, it turned up in the post today, I just need to find a way of holding the sub that gives me an easy way of spraying it with the rattle can. OC.
  3. More progress today - I seperated some of the pe parts and managed to loose one of them (as you do) these were the hatches, so I managed to fix in place two hatches and two accessnt hatches, these needed a slight bend to fit them to the profile of the top/side of the hull, I also fitted the top device infrot of the sail (not sute what it does), then two side hull covers were fitted - these have a slight opening at the rear. After finishing off the hull details I worked on the rear section containing the Stern Planes, water propeller system and cover. After fitting these components I gave the inside of the cover and prop blades a coat of brass paint. So this is the stage I am at sofar - next will be to crate a handle(stick) to hold the sub while I giver her and overall spray as my Nato Black has arrived. Thank you for all the views/likes and of course everyones imput. OC.
  4. You should do an early warspite to go with your seydlitz, they were both against each other at Jutland. OC.
  5. The chinese make it look easy at Pontos - must be thier small fingers. OC.
  6. Stunning Work, there is no way you would guess these are not high level plastic or wood projects. OC.
  7. I decided to give her a "out of refit" condition with some slight weathering but a general overall color condition. The Nato Black have ordered is a Grey-Black color so it should look a lot better, and a rattle can to give a nice smooth finish. OC.
  8. I gave her a rub down with some fine wet and dry and running water, I just need to fit the rear horiz stabs and a few bits on the hull, then the PE I received, all in preperation for the rattle can I am expecting in the post. OC.
  9. Look what turned up in the post today - funny thing is I never ordered it (must have a farther god mother) OC.
  10. Very interesting build, I may need to pinch someones seat.......but the usual lot will be along soon so I will pinch one from them (they wont mind) OC.
  11. She was on sea trials lou, thought I better try something shallow incase she sank, all the crew are still on shore leave and quite drunk too much rum. OC.
  12. I have ordered my paint - Tamiya Acrylic rattle can. Also we had a day in the sun on the patio, so I brought my HMS Greyhound out for a swim. Thank You sincerley for all the comments and likes - it sure makes building this tube more enjoyable. OC.
