Old Collingwood
  1. Hi Jeff long time no see hope you are well. OC.
  2. Thanks mate, yep its not always easy to make a round smooth object detailed and interesting, but I will give it a go. OC.
  3. Hiya mate, I will continue to buile up the base color first and attack the bow area where there is a gap, then I will look at simulating some tiles with tape masks. "note to self - look on flee bay for that flast coay rattle can carl mentioned" OC.
  4. Right I decided to attack the sub (no pun intended) by closing up the hull, this was quite a tidy job but needs a bit of filling near the bow, any way I also put the two halves of the sail together, then glued this to the hull, when set I lightly sanded the hull to create a key, but also masked off the top section, then I started to apply the first few brush coats of dark navy grey. It will need quite a few coats (all thin coats) to build up a smooth finish. Here are a few pics. OC.
  5. That is some service beneath the waves, I spent a day at Dolphin in 81 school work experience based at Collingwood for the week, facinating experience taht led me into applying to be a WEM the year after (didn't make the grade though). OC.
  6. Some other T boats appear not to have the channels on both sides, just want to work out if I can paint them in the same dark greay color as the tiles. OC.
  7. Change of plan for my next stage as I am not happy with the finish so far - I decided I will join the bottom and close the hull, and possibly construct the sail and fit it, then I will be able to work on the join seam and sand as needed, then I will mask to where the generic waterline would be be and give below it a few fresh coats of paint by hand as I dont have a sprayer. The sail will give me something to hold onto while hand painting and the masking will help with even brush strokes, then I will polish with soapy water and a sponge as before to smooth out any brush marks (well thats the idea) OC.
  8. Im not sure about replicating the tiles and missing ones, I might be able to tape up a few bit by bit. OC.
  9. I have this pic (again not one of mine) It shows more detail including the pattern on the sides that is completely without any tiles - but looks intended that way. OC.
  10. Great work kevin nice and tidy brings back so many memories when I went over Devonshire it was the only ship my late farther would pay to take us over. OC.
  11. Thanks kevin, wonder if that is red oxide paint they paint where the tiles are missing - cant imagine it being rust, also what are this two zig zag panels where there are no tiles on Trafalgar. OC.
  12. A little more progress just picking out some deck details with my brush(its easier to do this while the hull is still in two halves) as Lou said its brings the details out on what would be just a cigar. OC.
  13. Thanks lou, I thought the same as subs do tend to be slightly detail shy, she has a few bits and pieces to go on her yet. OC.
  14. What matt top coat medium will you be using - your own sprayer or rattle can? I am interested as I will be seeking to do a flat top coat on mt sub when its all finnished. OC.
