Posts posted by Old Collingwood
5 hours ago, Canute said:
OC, that Loctite Gel is a good choice; I use it on my resin cars. 👍
Oh, we watched "Napoleon" on AppleTV streaming service. I got the service to follow Masters of the Air; an excellent series on the air war, Anyway, my Admiral said Napoleon was a waste of time. I'm glad I didn't spend the bucks to see it on a theater. They played fast and loose with the battle scenes. Waterloo was a joke. Napleon led a charge, no battle at La Haye Sainte farm or Hougemont, the Prussians attacked from the west(?). Oh and Wellington kept the Alliance forces on the facing side of the hill, rather than on the back side. This movie ranks up there with "Pearl Harbor"
Yes I had heard the new film was very lacking more of a bio just on him, and not very accurate regarding the battle.
OC.
- FriedClams, mtaylor, Egilman and 3 others
- 6
Morning all, so - where I am at right now, I have flat coat varnished about 30 of my French dudes with more to do, I also have some British that need the same treatment - however I have ordered a bottle of Loctite Flexible Gel Super Glue ( I have read a lot of good thngs about this glue) the idea is when it arrives I will cut away what ever figures I have done, that can then be placed on my dio dependent on areas being finished - like the road and orchard.
OC.
This sounds ambitious but good luck, I also part finished this kit, I got the Hull 95% finished then gave up on her.
OC.
So I can confirm - warming up my Acrylic Varnish does help the flow and dulling (with a Matt Varnish) I think our temp being lower over this side of the pond to you guys over there may have something to do with it as at a guess I would have been brushing it on at a temp of roughly 12*C - 53*F but heating it up to around 25*C seems to help - still needs a good shake after warming though.
OC.
Update - I think my trick of warming up the bottle has worked, as the finish seems more flat now - Third time Lucky.
OC.
- FriedClams, Jack12477, robert952 and 4 others
- 7
Evening all, I have been pulling my hair out applying a few coats of my Mig Ammo Lucky Ultra Matt Acrylic varnish, despite shaking it till me arm nearly falls off and brushing it on very thnly - do you thnk I can get the Blues on the jacket arms to go (fabric shade) flat - Nope, they are staying like a slight satin sheen, simply dont know the reason or answer.
OC.
Not about LHS but about the defence of Hougoumont at Waterloo - found an excellent Google Maps walk through inside the courtyard and buildings -
OC.
53 minutes ago, Egilman said:
Well I'm here as I'm sure the brothers will be as well...
There are videos of how to do stippling as well...
Will be following along my friend, I wouldn't miss it...
Thank you kindly brother.
OC.
- Egilman, FriedClams, Canute and 2 others
- 5
26 minutes ago, Egilman said:
Since you already have it masked Brother, Break out the stippling brush.... (just remember when painting the pattern draw the brush away from the masking when painting)
Once you get the pattern down and masking pulled, you stipple the hard edges with a drybrush to give the soft edge...
It's fairly easy, but does take some practice to get it right.... Just remember, stipple dark over light....
Its only masked up for the primer at the moment, I did it in preparation for when I was going to spray on the primer, so the first stage will be to brush all over it my Vallejo Surface Primer with my largest One inch brush.
Will deffo try your Ideas latter down the road when I am ready to have a go at free hand camo brush painting.
OC.
HMS Spiraea and HMS Zinnia by king derelict - Mirage Hobby - 1/350 - PLASTIC - Flower-Class Corvettes
Looking good Alan, PE work is always one of those "Hold your breath" type things.
OC.
