Posts posted by shipaholic
40 minutes ago, allanyed said:
Shipaholic
The rounding (camber) is an extremely valid point, good that you pointed it out. Each deck usually had a different amount of rounding from orlop to the upper most decks, do you know if the other decks on the model have any camber at all or are they flat as well?
Allan
All the decks are flat on this model. When I built mine I only put camber on the weather decks, the others can’t be seen except through the main hatch if you don’t put a cover on it.
Hi KJ now is the time to consider one small modification, that’s if you want to. This Occre model does not have a deck camber, as all ships do. It’s very simple just glue an extra strip of wood on top of the deck supports and sand to a curvature before fitting. Don’t worry about the lower deck because you can’t see that except through the hatches.
Thanks, and feel free to ask anything
- Keith Black and mtaylor
- 2
Welcome KJ, good to see another Aussie on here, I will watch your progress on the Endeavour with interest
- Keith Black, mtaylor and KJackson
- 3
Hi Marty, I will follow your build with interest
Cheers
Steve
Hi Dave
Nice work shaping the masts. But before you go any further check your scale, those masts look too tall in that last picture.
Cheers
Steve
Welcome Peter good stuff so far, I will follow your build with interest. I just checked out that new version of Endeavour on the AL website, its completely different to their old version, with many laser cut wood and metal parts it looks so much better, and I think the hull paper template idea is a great to get everything where it should be
Great to see another Endeavour in the making. Looking good so far.
I based my masts on the drawing in Marquardt's AOTS, I believe he based his drawings on Steel's Elements of Mastmaking, Sailmaking and Rigging. Below is a photo from my copy of Steel. The taper is complex as the masts are narrower at the bottom as well, particularly the mizzen. Steel's drawings show a lot of detail, mostly unecessary in model making but gives you good idea how the masts should look. These drawings are for a larger 36 gun warship, and I don't believe Endeavour had the iron hoops as well as woolding (according to Lees Masting and Rigging of English Ships of War). A PDF of the Steel drawing is available here https://www.hnsa.org/wp-content/uploads/2014/07/mastplate4.jpg
Yes I agree with Druxey. I could not see a way of doing it easily with a lathe or some othe power tool. Its just down to a lot of sanding and filing.
The complex shape of the masts means it needs to be done manually and carefully, see the pic below, the mast is tapered and filed flat on both sides for the cheeks and hounds to sit flat. I used small sanding blocks to do the tapering and flat files to do the square section at the top, which also has to be tapered. Always refer to the plans to make sure the tapers and dimensions are correct.
- Bill Hudson and mtaylor
- 2
5 hours ago, DaveBaxt said:
OOps it looks like I have used the wrong draught as I have indeed set the mizzen channel further aft and have not lined up the front dead eye with the aft of the mast. I now think its possibly too late to change this now. I also asked the question in a previous post regarding the position of the mizzen channel and I think the answer I got was believe to avoid the swivel guns posts. I have now placed the Mizzen channel so that the swivel gun post is in between shrouds 2 and 3 and will hopefully miss the swivel gun when this is mounted.
I also used this draught which someone sent me when I asked the question in a previous post.
This draught is the one showing the Earl of Pembroke before refit with the proposed changes. Notice that the channels are shorter with one less deadeye on the fore and main channels
- AJohnson and SIDEWAYS SAM
- 2
More confirmation that the mizzen channels were the same width as the main channel is indicated on this original draught, which is the one I used to base my model on. The chains are the same length from channel to the hull indicating that the main and mizzen channels are the same width.
There is another draught that everyone tends to use which has a different arrangement of the rails and has shorter chains on the mizzen indicating a narrower mizzen channel, but I believe that draught is not the correct one. That draught was used as a reference by AOTS
In the photo of my model it appears that the mizzen channel sits back from the mast but that is just the camera angle playing tricks with perspective. The front deadeye of each channel is in line with the rear of the mast as in the drawing
Cheers
Yes Dave I made my mizzen channels the same width as the fore and main ones. The mizzen shrouds are the correct distance away from the quarter deck rail. I think Caldercraft are following the drawings in the AOTS book which show much narrower mizzen channels. That book has many mistakes,
Cheers
Steve
Nice looking model, congrats for finishing
Hi Schubbe
The thin planks are okay, as long as you clamp them down at regular intervals. If you notice in my pics I just used pins and scrap pieces of wood. I used PVA glue and a spot of CA glue every 30mm. I marked the position of the main wale by measuring off the original draughts (scaled to 1:52) then started the planking from the lower edge of the wale
Okay Schubbe here are some more pics. The planks are thin and dont like the upward curvature, they tend to want to kink so lots of clamping to keep them flat whilst the glue sets. I used PVA with a spot of CA every 30 cm. Also here are pics of the transom I made instead of using the supplied one and how it should be at the side of the stern, so that the decorations sit properly. I later modified it a bit above the figurine
Your build looks great so far, great attention to detail. I have built this model and like you, I made a new transom because I didn't like the shape of it nor the position of the windows. I made the windows see-through using clear plastic.
HM Bark Endeavour by KJackson - OcCre - 1:54
So if I interpret Allan correctly the centre of the deck is 6” higher than where it meets the gunwales. Which is about 15cm so at the scale of this model (1:54 which I reckon is closer to 1:51) you need to raise the centre of each deck 3mm. Seems right, can’t remember how much mine was (that was 10 years ago) but yeah about 3mm
