Posts posted by shipaholic
Wow, excellent work Eugenio, you have built it exactly how the instructions describe and it looks great. One small detail, the holes for the belaying pins should be a little larger so they sit down further on the bulge in the middle of them
Cheers
Steve
- usedtosail, clogger and GrandpaPhil
- 3
- chris watton and clogger
- 2
Arrangement of the main course sheets.
I did a bit of research to work out the best way to do the main course sheets. Because I have arranged the rails as depicted on the original 1768 draughts there are no bitts under the quarter deck rails. I looked at pictures of a few different Endeavour models in museums, both with and without those bitts and also checked qite a few reference books for how the sheets are set up. This is how I have set it up, I added a cleat to the bulwark and a block attached to the rail stanchion. Instead of hitching the standing part of the sheet to an eyebolt just forward of the mizzen channel, I hitched it to the fore mizzen chain to get it out from the hull a bit so the sheet line doesn't foul with the main shrouds so much when raised.
- clogger and GrandpaPhil
- 2
- chris watton, clogger, Retired guy and 2 others
- 5
- GrandpaPhil, chris watton, clogger and 2 others
- 5
Welcome to the Endeavour club, I will watch with interest. Don't be afraid to get agressive with the sanding of that first layer of planks, use some fairly course grit on a wooden block and get it free of any bumps, doesn't matter if they get a bit thin in spots, I even used some filler on mine to fill the dips.
Believe me the smoother you get it the better the next layer of planks will go on. The second layer planks are very thin and warp and buckle easily and they won't sit right on an uneven base.
Cheers
Steve
Hi Scott
I think the hole in the deck is for the stairs to the deck below, I think the main hatch behind it is created by placing a frame and grating on top of the deck planks. Trouble is that hole doesn't look far enough forward
Cheers
Steve
Hi Scott
Yes I also built this kit about 30 years ago, and am currently building a bigger 1:51 scale Endeavour. Be careful about using the Marquardt book as reference, it has quite a few errors but mostly its a good reference especially for spar dimensions and some of the finer details not in the kit plans. The AL kit rigging plans are mostly correct, but as I said, lacking detail.
I will follow your build with interest.
Cheers
Steve
- GrandpaPhil, Nirvana, RGL and 2 others
- 5
Hi Helena
Yes I still have all the copies of the magazine, I will email you
Cheers
Steve
15 hours ago, Sabranne28 said:
Hi, I am following your build log which is very informative and beautiful work. I noticed the quarter badges and the windlass with the heads are not of the kit. What is the thickness of the wood for the two items. Many thanks, Sab
Hi Sab
The windlass heads are the ones that came with the kit, they are cast metal. The quarter badges are ones I made and carved myself using 4mm thick boxwood.
There are many parts that I have made myself, such as metal parts and a lot of the rope that I made myself using a rope walk. Also there are many parts I have purchased separately such as blocks, some ropes, cannon barrels, lantern, helm etc. Most of the wood used is what came with the kit except for a few items made with wood I have purchased or left over from previous builds
Today I finished fitting the blocks and attaching the crossjack yard to the mizzen mast. Yard is attached to mast using a sling-parrel, then slings through a large single block on the yard. Also changed the parrel on the gaff. Found some nice 5mm wooden balls in a local craft shop, applied some wood stain/lacquer and they look fine. I noticed that the HMB Endeavour replica uses one double block for the mizzen topsail sheet sheet lead. I have stayed with two single blocks.
- GrandpaPhil, JayCub, gieb8688 and 1 other
- 4
On 3/1/2020 at 1:27 AM, Nirvana said:
Clean and nice look!
How many more hours are you guessing in order to finish her?
Still a long way to go, maybe a couple of hundred hours. I have been building this ship for 9 years now because I don't get to spend much time on it.
On 12/17/2019 at 11:40 AM, Lordkapas said:
Hi all
I'm making the Constructo bounty 1: 50. The anchors are miserable. Cant anyone tell the measurements of the real anchor ?
I am making the Endeavour at 1:51 scale and I purchased a Caldercraft anchor which is 74mm long, about the same length that you need. The Caldercraft anchors are very authentic, they don't come with the hoops for the stock, I had to make them. I got it from Corwall Model Boats in the UK
- JerseyCity Frankie, DaveRow, Cabbie and 4 others
- 7
HMB Endeavour by shipaholic - FINISHED - Eaglemoss - 1/51
Posted · Edited by shipaholic
Funny how I'm nearly finished and I have lost interest a bit, its been 10 long years, but today i did a bit more and I will finish her in the next month or so
