Posts posted by Engelmann
What a year this was!! Life threw one curve ball after the other. There was more hospital time for both my wife and myself. My diabetes took a slight turn for the worse but is fortunately still manageable.
I still do not have any way of ripping the planks for the build, still thinking of building a (very basic) small table saw for it as I simply cannot afford to buy one, If anybody got any sort of drawings/plans for one I would appreciate it.
Cheers
True what you said druxey, but then using a CNC or normal mill does not take any skill out of it, it only moves the required skill to a different arena. One can as easily say "Don't use an electric scroll saw, or chisel, use a carving knife only" :o :P The use of any tool got its own skill set to master
If you look on the original drafts at how these ports were shaped (bevelled) then I believe the guns were place in a more fore and aft orientation (instead of square on to the port as the other guns) where they could be used as chase guns when pursuing. This would also give them a tad more recoil space, especially if the bits were moved 2' aft as the knees would then also be out of the way.
Hi Chuck,
Stunning model!!
I think the model would also be less prone to warp with the garboards fitted. If you look at the contemporary model without the garboards you can see that the keel is pulled into a slight curve by the tension of the top planking. On the other hand, the fact that you planking is pre-spilled might reduce the tension enough for it not to matter
Cheers
Deon
Hi Chuck
I like the way that you did the ropes. Coil those on the deck but keep the ones hanging natural exactly like you have them.
Maybe relax the coiled ones on the deck slightly so that they look more like the third picture of the contempory models, your's is maybe a bit to perfect
Cheers
Deon
Hi, long time no see.
This last month was absolutely crazy, both at home and at work. We finished 2 projects and started another 3 at work and my time for software development on the one project was cut from 6 days to 3, crazeeeee!!!
But fortunately I'm on leave next week so I will finally have some time in the shipyard.
I got all my stuff that I ordered from Chuck and also received my wood from Jason. Thanks guys, it was a pleasure dealing with you two.
I even got a white towel :D :D so my cutter should come out looking good.
I must now just build a small saw to cut my wood but in the meantime I will make a proper start on the keel and bulkheads. I do have a fretsaw as well as a band saw for freehand work but nothing to rip planks with. Also got a lathe and a milling machine so building a small saw should not be too big of a problem.
Cheers
- Canute, Ryland Craze, Chuck and 3 others
- 6
Correct site, you need to find the National Maritime Museum link under the Red Greenwich heading. It is about 2/5ths down the page about where the righthand adds column ends. Click on the link and it is the 5th photo on the new page. I would have simple pasted the link but IE11 does not allow me to copy and paste into these replies.
Hi Tony
I completely agree with you. I'm one of the cases that broke off from modelling after leaving my parent's home and having to make a living for myself. It is only in recent years that I got to the point where I could indulge in my hobbies again to the extent that I want to. It is also only since 35..40 that I gained the patience needed to take on a long duration project like building a ship model.
PS. If I look at my son (now 22) and the amount of practice he puts into training at fighting in the games that he plays on the computer so that he can compete against his friends at LANs then I must say that a lot of the younger generation are as dedicated to what they want to acomplish and to the degree of skill that they want to build/gain. It is just that the things that interests them has changed.
Regards
Deon
- Erebus and Terror, tkay11, GLakie and 1 other
- 4
Hi druxey.
I should have said "in any of the contemporary models that I have seen".
But it is good to know that they do show them on some of the models and plans.
I assume from your post that there is a tube (square?) from the seat to the counter.
Does this mean the discharge hole in the counter have the same shape as the tube?
Nice to see some progress here That dust shows just how long we had to wait and endure withdrawal pains :D :D
Looks good. Question, should there not be two holes in the counter under those seats, or did they use buckets?
I've not seen any corresponding holes in any of the contemporery models, or was it gentlemanly omitted?
Really nice to see you back on this model.
Cheers
Hi, I know I've been quiet here lately. My wife was in hospital for surgery which was successful and she is now back home recovering.
On a lighter note, I received notification this morning from Jason that my wood order has shipped
So hopefully I will be getting some workshop time again and get on with ship building
Cheers
HMS Winchelsea - FINISHED - 1764 - by Chuck (1/4" scale)
in Member Build logs for the HMS Winchelsea
Posted · Edited by Engelmann
Chuck, not so much quiet, more like speechless.
