Spiff
  • Gender
  • Location
    Maine, US
964 profile views
  1. Thanks Gary Just had a look at the Artesania Latina model - it does look like it has finer details. Oh well - I am not shifting now 😉
  2. Cant believe I havent posted for 2 years. Well, I havnt been completely idle but must admit I (surprisingly) got a bit frustrated with the kit because of how bad the supplied wingtips are. I spent way too much time trying to make them fit before I finally made my own. Here I'm adding all the ribs to the main spars. This to show how the supplied wingtips are just too small. Its not a lot really but enough that it just wont fit. Tried bending them in different ways but was afraid the pewter would eventually snap. So finally I decided to make my own. They are by now means perfect but good enough I think. The main structure of the wings is finally complete and I have been working on painting the braces.
  3. It has been a while, but I have not been completely idle. I have now finished the spars and they sure are a LOT of work! Getting the caps centered on the spar is not as easy as it sounds, even with a jig. Some of mine are, unfortunately, way off but hope it wont be too noticeable. Have converted a ceiling tile to a workspace where I can pin down everything for assembling the wings and was all excited to start that today. However - the spars provided in the kit are not long enough for the entire length of the wings. This is rather annoying/disappointing and the Instruction manual makes no mention that I can see about how to proceed. In fact the manual talks about having to saw the lower wing in half and then reassemble it to get the correct angle on the lower wing. But as it is that is not a problem because it seems you have to build separate wings anyway. But I am concerned that the top wing will not be very strong if it is actually two wings glued together just at the tips of the spars... Might have to see if I can buy some longer pieces of wood for the spars. But here are all my ribs:
  4. After spending 9 years! building my Golden Star I have switched gears and taken on the Model Airways 1/16 Sopwith Camel and I really hope I can spend more time building so it doesnt take me nearly as long to build as the Golden Star 😉 I have finished the engine which is a neat little model in itself. I decided to paint it to give it a bit more 'life' Here it is primed: In order to be able to paint and weather it, I had to build/paint in stages. Here with ignition ring and wires: And here completed with pushrods. I didnt paint the bras. Not sure if its the historically acurate colour, but I just think it looks so good! Then came time for the propeller, which I thought would be harder than it was. Pretty happy with the result and still giving it more coats of varnish to try and give it a deep sheen. Will try and keep this somewhat up to date but I dont get too build all that often. Thoughts, critique and comments are very welcome! Cheers
  5. I used very diluted white wood-glue which I painted on the sails and then shaped and tied them. Fairly happy with the outcome even though the cloth I used is much too thick really. Made a couple of the sails 'billowing' using things to weigh them down while the glue dried. Finished! after more than 9 years on-off building. Farily happy with the result even though I was getting frustrated with the plans/instructions as there were errors that I had not noticed earlier and were too late to try and fix. Wanted furled sails at the bow (Im not into all the names - sorry) but with the thick cloth Im using for sails I could not make them fit very well and thought it would be better without them. Also decided against the plasticy flag that came with the kit and the huge lanterns that were supposed to be at the stern - I felt like they were way out of scale and would just look silly.
  6. Thanks GrandpaPhil. Still working on the sails so havent started mounting them yet.
  7. I am in nearly the same situation. However, I have done all my standing rigging and ready for the running. I am having most sails furled and a few set. My question is - in what order should I add the yards & sails - bottom-up, front-back ??
  8. I have a question for those who have done this thing before though. As I am soon to start adding the spars+sails and all the other running rigging - what is the best order to do it in? Start with the lower or upper sails and which mast first? I plan on having the main sail and mizzen sail set and the rest furled.
  9. Not exactly a consistent builder or updater - but then again it seems Im keeping a two year gap between updates. Sincerely hope to be more frequent. I have done all the standing rigging (can see I need a photo of that) and have started on sails. I have been a bit intimidated of making sails - furled or set and all that but giving it a go. As I reported in last update I was doing a bit of a test run but was so happy with the first attempt that I am going to use that, and have made several more. This was the first attempt: These are the finished ones so far: I can see that the cloth is too thick and out of scale but think it will look pretty good. Might try (silk)paper for next model though.
  10. This looks great. I have just ordered this same model. Will be a while before I start working on it because I want to finish my current build which has taken me years and years to finish.
  11. Wow - its been two years since my last post! Well - have been busy moving across the pond and setting up a new workspace. But here are some pictures of progress - shes moving along slowly but nicely. This is status right now. Booms are still not attached. The yards with blocks. Starting on making sails now. Here im drawing in the sail and seams with pencil. Transfered the seam spacing using tape. And then put it in tea for 10 minutes. Right now its drying off. My plan is to have main sail set and probably the rest furled. Im using the thinnest cloth I could find, but now realizing paper might be better - but will give it a try with cloth.
  12. Hi Boyd Looking good! I will follow your build, as I hope to build the Bounty at some point...
  13. A couple of pictures of current status - finished the shrouds and ratlines and started on Stays. Couldnt get the ratlines completely straight and the lanyards and shrouds would sometimes twist - not sure how to avoid that. But all in all Im pretty happy with the result even if its not perfect - but hey - its my first ship this size...
  14. Hi Homer I'll keep an eye on your build, as I plan on building the Morgan sometime down the line. Looks good, and damn - your fast! It took me a couple of years to plank my Golden Star :-)
