Javlin
Everything posted by Javlin
  1. Titled renamed the West was fun while it lasted Kevin
  2. You know OC they make a canopy glue almost like a white glue maybe like Gator Glue that goes on thick and have a q-tip ready(pointy ones Tamyia I like) damp it on the tongue and wipe.The glue fills those gaps for you you do not need it often but bombers seem to have more problems. Kevin Oh and a good save!
  3. Thks OC Last pics for the night engine done and L/LG together the parts box is getting empty Kevin
  4. The engine should be done tonight wanted to show a pic of the ignition wires as they go in only 14 more to do and 14 pipes out the back. Kevin
  5. Correct,the defects look to be from a mould that needs to be replaced and to many seriously and can bend and straighten them. Kevin
  6. Thks Lou,even though it's viral they gave me a big shot of steroids and antibiotics then on top of that pollen galore right now eyes feel buggy.What do think about the hand props look good enough to your eyes? Kevin
  7. Well I have not stopped working I seem to feel better later in the day so I have been working on props.What we have here is the kit prop,aftermarket which I do not care for and kit prop re-shaped.I think a little more shaping on the backside of the prop and it will be good to go still alittle fat.The after market props have defects in the face and are so frigg'in thin I can bend them so I cannot sand out the defects.The other problem if they go to rotate the blades will begin to move and flatten out possibly.I am about 50% through engine #2. So I paid $30 for some templates Kevin
  8. https://www.kitlinx.com/cgi/display.cgi?item_num=SQT9600&title=Mosquito-Standard-and-Bulged-Crystal-Clear-Canopies
  9. Something to think about Jack this was done by Jerry Rutman I luv his work http://www.armorama.com/modules.php?op=modload&name=features&file=view&artid=6837
  10. Thks Fellas tested and no #19 but I do have pneumonia in the R/lung I was really concerned about the 19 for the mother in law @ 86 she is around the house to often.I am tried been all day time for nap Kevin
  11. I will be out of pocket it looks for a few days a week #19 got me maybe being admitted to a hospital later today looks like pneumonia may of already started in the r/lung and I started feeling ruff Sunday.This is the second time this build has been stopped due to illness last was in 2015.
  12. That and the thought process CD thinking the rubberized stuff for wiring once in the wheel and out.I stop here today I think I wish now I would of took a pic before the gear hit the WW for the rubber hose part at least I know it's there I will take a pic of the L/LG.The motor works had to turn the plastic shaft into it's own lathe for a moment or two with a sanding stick then a touch of white lithium all's good now.I have some paint touch-ups nothing major and clear to blend.Oh I used a flat silver on the LG with SNJ rubbed in for the shock I am using this technique more and more. Kevin
  13. I started building the other line and I found out the malleability of the wire I was using was very very low for a single strand so back to wire box.I had some commercial grade stuff about a foot long maybe a hundred strands together tried breaking it I couldn't but it's not insulated I will continue to think on that.So,what you see here is about 1/2 hrs of trial and error green painters tape and then thin CA applied to it I am about to paint this LG.
  14. Thanks for all the likes fellas I hope to get some more done today all the relatives have left town always nice to see family but I do like my time in the shop. Kevin
  15. I have the same putty like it over toothpaste tube products a bit hard to squeeze out.The Mitchell was the first plane I have used it on spreads easy and clean up is easy. Kevin
  16. Splendid Job CD!There aren't any touchups Kevin
  17. Nice work thus far so small hat is off to ya. Kevin
  18. I was surprised the same thing about the Mitchell CD very few. I am sure you will Sir! Kevin
  19. Moving along with the right wing I have for the most part am finished with the engine and have moved onto the LG.I had heard of another fella using the wire as the hydraulic lines so I settled on that with a slight in provision I skinned back the wire some and ran it through some brass tubing then slid the sheathing back over the wire and a slightly bigger brass piece cut and used as the coupler between the rubber/metal.I have another tubing to attach to the other side also of the LG as was in real life. Kevin PS;the wire goes into the wheel hub out the bottom of the tire and under the platform
  20. I must be lucky 1.0 for me but I have no hearing @59 yrs
  21. Well CD this is the pics of the ICM figures for this build and the little Dio is ICM figures pre-molded in 1/48 Kevin
