Posts posted by JerryTodd
Will the yards be getting jack-stays? (d)
I just wonder should the jack-stay eyes be turned that way, or are they just drawn so we can see that they are eyes?
- Jack12477, mtaylor and Keith Black
3
I'm contrary and obnoxious, so I'm bound to be around to bother people for a long time.
The launch and 1st cutter got gudgeons on their stern posts, and all the boats got lifting-eyes. Decent paint jobs will have to wait for warmer temps so I can use the air-brush to get into all those nooks-and-crannies.
I guess I'll work on their rigs next. spars are easy, but I don't think I'll make the sails, but just roll some cloth and bundle it onto the spars. I have some little cleats left-over from plastic kits, and some tiny brass belaying pins I'll put on to detail them a bit more.
- mtaylor, yancovitch, GrandpaPhil and 1 other
4
Even a large model at 1:36 scale, and with no permanent rigging up yet, it would be near impossible for me to bend sails to yards without something going terribly wrong.
Mine are lashed at every grommet on the head of each sail to a jack-stay on the yards, which I do with a needle and polyester sail-thread, and a very slight touch of CA to set it.
Doing this before putting the yard on the boat is SOOOO much easier than trying to do it with the yards already on the boat.
Fortunately, there's only 17 sails to deal with.
Gave the boats a coat of primer. After I cleaned up the original boats of shop dust, all but the launch got some white paint inside, and black paint outside. when it gets warm enough, all the paintwork will be fined up with the air-brush, gratings will get painted, etc.
I still haven't found any sort of "official" pattern boat chock, so I just made some simple ones like we had on a boat I worked on long ago. If I ever find something more "authentic" for Constellation I'll replace these with those.
Then I made rudders for the boats, closely followed by tillers. I don't intend to leave the rudders hanging on the boats, but rather stowed safely in the stern sheets, though I may hang them on the 1st cutter and/or launch once I install gudgeons on them. I have some fine copper wire eyes in the parts bins that'll be perfect for this I think.
The whale-boat was ready to print by the 7th. The built a whale-boat to these lines for Constellation and fitted her with bronze oar-locks, but I opted to put in thole-pins instead. I split the model in two, to fit in the printer, and made sure there were no "holes."
The slicer said it would take 5 hours and 25 minutes to print.
Here's the 3D models of all three boats together. As 3D models go, they are very "low poly" so the printed models come out a bit "faceted" but they're still more detailed than the boats I made by hand.
I let it run over-night and in the morning found $.83 worth of resin weighing .83 ounces (23.6 grams), and looking very much like a whale boat...broken in half.
It came off the plate undamaged, and was sloshed about in a tube of denatured alcohol for a bit; then washed in warm water, and finally sat on some paper towels to dry.
Here's all the boats together...
the 25'10" 2nd cutter, on the left, is 8.625" ( 219 mm) long,
the 28'2" whale boat, in the center, is 9.625" ( 245 mm) long,
the two 26' 6" quarter boats, on the right, are each 8.875" ( 226 mm) long. -
The quarter-boat was built a little "heavier," learning from the 2nd cutter. A lot of parts from the cutter were copied into the QB and adjusted to fit, until it was ready to be mirrored into a whole boat and printed.
In the slicer software the blue box outline shows the volume the printer can handle. There was no trouble printing two copies of the boats at once.
Like the cutter, the two halves are bonded together by wetting the seam with resin and zapping it with UV light. The seam needs some clean-up, just like any plastic model.
Here's all three boats on the model where they'll be stationed eventually.
- GrandpaPhil, Ondras71, scrubbyj427 and 2 others
5
I have one of those Harbor Freight belt/disk bench sanders. I needed a lot of tightening and adjustment at first, and is due for some of that again, but it does the job for modeling just fine. It's a bit weak for cabinet work though.
The biggest drawback with these "cheap" sanders is the table in front of the disc - they tend to be weak, unstable, floppy, and inaccurate. Mine would always creep onto the disc until it ate the edge off, no matter how much I tightened it.
Basically, unless you're ready to practically rebuild the tool, stay away from the very "cheap" one, cause they are very cheap.It's to the right in the pic
- Canute, Roger Pellett, Ryland Craze and 2 others
5
Welcome aboard Chuck, from about an hour away from you in Maryland.
- Ryland Craze, mtaylor and Keith Black
3
As with everything I do, this isn't "how to do it" but how I did it. It's not necessarily the right way, best way, or easiest way, just the way I'm doing it; which, by-the-way, is different from how I did the last boat.
That said...
I tossed out the quarter-boat from a couple of posts ago, except for the keel, and started over. I made a wire-frame cross-section of a single plank 4mm wide, 1mm at the thick end, .5mm at the thin end, and the part's rotation point on the inside edge .5mm from the thick end. I copy-and-pasted each profile around each station after adjusting it's length to make 10 of them fit in the length of that station, and rotating it so it's top touched the station line. I wound up with what's in the picture. Once this was set-up, I started making the ribs. Each rib is 1 x 1mm and in 10 segments to match the planks. I set each one up on the keel as it was made. Part of each plank will be buried in the rib giving the impression that the rib is cut to fit the insides of the planking-it's not.
When I had the ribs represented by station lines, and the transom set-up, I started copying some parts of the 2nd cutter over, and adjusting them to fit the quarter-boat; such as stern-seats, gratings, floor-boards, seat-clamp, rub-rail. Some of this will need further adjusting once the inside planking shell is in place.
To make the "planking" or more properly the inner shell of the hull, I traced the planking profiles described above to get a zig-zag wire-frame of the inside of the planking. This is placed at it's station and matched up with it's rib, already in place.
When the second once is placed I can join the two as a single part, and connect the dots making a wire-frame of that section of planking between those two stations. The wire rectangles are made into surfaces which will face the inside of the boat, as this is the inside surface of the planking we're making here.
as you may have noticed, this is all quite tedious, but it's much more precise that how I did the cutter while not being any more work; it's actually a little easier on the brain, which is also helped by my figuring out Anim8or's layers function.
As with the cutter, I only need to make the starboard side of the boat. Once that's all adjusted to fit, I'll mirror them to the port side to get the whole boat.
Meanwhile, I'm trudging along making the the inner planking surface. Then I'll basically repeat all the for the outer planking surface. A lot gets adjusted to the inner surface, and keeping the outer surface as a separate part let's me hide it so I can see things relative to the inner surface. That way there's no little unseen gaps that could mess up the 3D print, like having the end of a seat not connected to anything, or something of that nature. Yes, the planking is flat between each station; once the inner and outer planking shells are done, I'll slice through them creating 1/2 stations which will give me another adjustment point to help smooth the hull. I may even slice it into 1/4 stations, since the more slices, the smoother the hull gets.
- GrandpaPhil and mtaylor
2
I use 4oz cloth I get from DuckWorks, they sell 30" and 60" by the yard
- thibaultron and mtaylor
2
The Elegoo Mars 3, pictured in post #490. It's been really nice, right out of the box, though I've probably jinxed it now
- mtaylor and scrubbyj427
2
So it's printed! I was concerned the planking would be too thin, but it's fine, as long as the model isn't scaled down. Since I plan to share the file, I'll thicken some things up so it'll scale down to 1:96.
I broke off a couple of chips from the bow section trying to get it off the plate, but that's easily repairable at the same time I bond the two halves together. The two halves are just sitting next to each other in these pictures.
Once the halves are stuck together and the seam cleaned up, it's priming and painting time! This boat will sit on top of the 1st cutter, on the main hatch, which means making some chocks for it to print along with the oars, rudder, and other little things that'll go inside it.
Getting the floor boards in was interesting, but in they went, four to each side; each in two parts; fore and aft; then all mirrored to the port side - so technically I only need to make parts for one side and mirror copy them to the other side.
Each seat got knees on either side, and ring-bolts were placed on the transom, two for the rudder pin, and two for the flag.
The inner and outer planking was "joined" and the gaps between them closed off, and it was "done."
As I type this it's just at 50% printed (the pic was at 45%) and the planking is looking a bit thin. I'll see how it turns out, and if need by thicken the planking shell to 2mm and print it again.The slicer says it'll weight 29.9 grams (1.6 ounces), use $1.05 worth of resin, and take 4h 50m 57s to print.
- mtaylor, wefalck and GrandpaPhil
3
- mtaylor and GrandpaPhil
2
Continuing on with making 3D printed details for Constellation,
The plan I'm working from is what I worked up for building the models from the original drawings of Constellation's boats from the National Archives. The launch and 1st cutter were built in wood from these drawings. There' no details shown; rub strakes, seats, decks, oar notches, anything; that I've been looking at manuals, photos (mostly Civil War era), drawings, painting, anything I can find.
The first boat built for "Constellation" was the 1st cutter, back at post #493, and the launch around post #727 in this thread.
Being able to 3D print now, I though to do the rest of the boats this way on the premise that if something happened to them, I could print replacements.
I started fiddling with the 2nd cutter a long time ago, came back to it, and most recently started over almost from scratch. I'm still working in Anim8or because I still haven't managed to wrap my brain around Blender enough to be useful.
I basically made the keel, then a "clinker" wire-frame of each station/form, move that to it's place on the keel and connected them horizontally to form the outside face of the planking. Then I made a duplicate of that, flipped it's facings to the inside of the boat, shrunk it a little, and moved some bits around to make the two parts about 1mm thick. Using a "slicing" tool, I made stations between those on the drawing, and moved those points around to try and get a less faceted, ie, a smoother surface, to the boat.
Once I had a hull, shaped as best I could, I added a rub-rail, thwarts, a seat aft, which was reshaped later, a foredeck, which got a grating, and started making ribs. It's keep getting details, like floor-boards, knees in various places, notches for the oars, etc. Then, since it's too long to fit in the printer, it'll get cut in half to be printed, and glue it together.
As this seems to be moving along, I started on the quarter-boat (that will hang in the davits on each quarter of the ship). I'll need two of these boats, but obviously only need to make one 3D model.December 15th: 22 of 25 ribs installed, grating in the stern sheets, a lot of little adjustments, oar locks, and a check to see if it'll fit in the printer...
December 17th: All the ribs are in, the last two are cant frames, and took a couple of tries to get lined up. Redid the forward grating, and added a breasthook. Seat clamps are in, but there's floorboard yet to do, along with some hardware items like a flag-holder on the transom and gudgeons for the rudder.
The rudder itself, oars, and some other things will be printed separately.
- GrandpaPhil, wefalck, mtaylor and 1 other
4
The lead shot I have is reclaimed material and has a lot of dirt in it. I shook it through a sieve several times today, but I'm not washing it because it takes a very long time to get it dry, and I don't want to seal moisture inside this thing.
So here's both halves mostly filled with lead, and a pic with the fin on it. It was too cold tonight to pour epoxy, but if it gets above 55°f tomorrow, I'll give it a try.
Most of the model's ballast weight will be in a bulb on a fin at the bottom of the boat. The fin slides into a sort of center-board trunk built into the model some years ago, back around post #7 of this log. The fin itself is an aluminum plate measuring about 153mm x 245mm x 4mm.
The fin is placed at the hull's center of lateral plane. Last post I used a brute force method to determine the amount of weight the bulb will need to be (25pds/11kg)
I intended to sand cast the lead bulb in two halves, but that would require getting the tools and equipment for the job; a pot and burner to melt the lead, a ladle, casting sand, gloves and an apron, etc. Simpler yet, is to cast the lead shot in epoxy, but I would still need a form. Years ago, I would put the lead in some sort of container, like a 35mm film can, or in the case of Constellation a PVC pipe. That's got to be the safest way to handle this without requiring special equipment.
Suitable containers that can hold 25 pounds of lead shot aren't readily available, but 3D printing is...
So I started making a 3D model ball with inward facing surfaces, pulled and stretched it into a nice symmetrical ellipsoid, and went surfing for how to determine it's volume. I found a great web site that does just that, and played with the numbers till I got a volume of about 60.62 cubic inches, which multiplied by lead's weigh of .41 pounds per cubic inch, gave me 24.9 pounds.I adjusted my 3D model to those dimensions (a=50mm, b=105mm, c=45mm). I built a model of the fin plate as a reference, then cut the bulb into left and right halves, deleting one of them. I copied the remaining half and pasted it over the original, enlarged it, and flipped the surfaced so it was facing outward. The gaps between the two shells were closed up so it was a solid shell about 4mm thick. I built some structure to seat the fin inside the bulb, them cut the completed half shell into halves again, ie, quarters to wind up with 4 identical quarters , two of which will fit the volume of my 3D printer.
As I write this, the first two pieces are on the printer with just 4 out of 6 hours left to print; then I'll print the other two quarters.
When done, I'll bond two quarters each into a right and left half; fill each half with lead shot; pour in epoxy to solidify everything, then bond the two halves on the fin. -
I adjusting the 3D model to Lavery's chart and printed it. It looks more in scale with the hull now, and the details certainly printed better than the first try.
The grills pulled a bit during printing where they didn't do that on the previous print, because of how it was oriented in the printer. Some of the details are still a little frail, but they're all there and serviceable.
I posted the STL file on Thingiverse though I can't say how well it'll resize to smaller scales.
Here it is with a coat of paint, and with Constellation's crew check the fit.
Before putting more details into the stove, I decided to print it and make sure everything would print....
A lot of the details were too fine; the grab-rail, handles, rotisserie sprockets and chain, etc. The charlie-noble, which is a separate part, fit perfectly though
I went back to the model an beefed up the details; thickened the rail and handles, thickened bots and straps, rotisserie parts, etc, and for kicks, added an iron texture to make the screen shot look good, though it has nothing to do with printing it.
The whole thing seemed a little small to me, and remembering I have a copy of The Arming and Fitting of English Ships of War 1600-1815 by Brian Lavery, which has a great chart of stove dimensions for various gun-rates of ships on page 198 (2006 edition).
On that chart, for a 38 gun ship; the stove's body width should be 56 (48) inches; the length 57 (54) inches, and the height to the top of the flat sides is 48 (37) inches. The height to the top of the pyramid duct is 64 inches. The height of the chimney isn't given for ships of less than 80 guns.
(The numbers in parens are the measurements given in the MSW drawing attached a couple of posts earlier.)
On another note; the book mentions Lamb & Nicholson stoves, but shows no image, diagram, or description of one.
Here's a portion of the "Inner Works" of another Lively class frigate, the Bacchate, launched about a year before Macedonian, with the stove outlined in red.
The MSW dimensions are a little smaller than the dimensions given by Lavery for a 38, mostly in height. Before printing it again, I'm going to adjust the model and check the height of the chimney on the Macedonian model itself.
I'm only going for "implied" details on this model, and that's almost done. I made the top of the chimney a separate part and will size it to be attached after the stoves and the forecastle's installed.
There's a brace for the spit-drive arm to make, and a couple of flanges on the feet, and it'll be pretty much done and ready to take a shot at printing.
2
I'm still trying to figure Blender out enough to make viny ornaments for the bow of Constellation and Macedonian, but when the frustration gets to be too much, I slip back into Anim8or and work on something my simple mind can handle...
This time it's a galley stove for Macedonian. I found decent drawings online, that apparently originated here; and photos of a model from the National Maritime Museum in Greenwich to base my 3D model on.
Unlike Constellation, Macedonian will have her gundeck modeled with guns and other details, such as this stove.
I looking for source material to base a model on, it seems the same year Macedonian was launched (June 1810), a new stove by Lamb & Nicholson was being fitted into British warships, but I haven't been able to find any drawings or images of a L&N stove to model from. Also, I assume the stove would have been requisitioned some time before the ship's launch, and would therefore more likely be a Brodie type. If someone can show Macedonian got an L&N stove and direct me to drawings of such a thing, I'll gladly model that.
So here's my progress after a couple of hours work. All the details will go into the model, but nothing with be "functional," that is doors, lids, chain drive, etc won't open, be removable, or move. It'll barely be visible peering through the gunports or main hatch, but at 1:36 scale, leaving off too many details would be just as noticeable, as I did consider just making a black brick shaped like a stove.
2
I got a new 3D printer (Elegoo Mars 3) that has more print volume (larger prints), more resolution (better detail), and actually cost less than my original printer did.
First thing, I printed a test batch of "draft" screws as above.
They printed perfectly, though the model needs some adjustment; the eyes at the bottom needed to be smaller, and the thimble at the top needed to be bigger around, per the photo of the originals. I also had them print standing almost straight-up, meaning more layers, meaning more more time to print - it took about 5 hours to print these because of that.
I attached a pair to chainplates and put them on the model to see how much tugging they would stand. They seem to be tough enough, especially once they're all connected by a sheer-pole.
The 3D model's updated and I'll print it more one it's side to take less time to print. I enlarged the thimble, reduced the eyes, and thickened the screw a little. I also reshaped the arms a bit.
30 of them printed in 3 hours 20 minutes, and I temporarily put two on the model under tension to see how they hold up.
- yancovitch, Boccherini, Roger Pellett and 5 others
6
2
Copper plate overlapping (< > 1794) - lower overlaps upper or vice versa?
in Building, Framing, Planking and plating a ships hull and deck
Posted · Edited by JerryTodd
More often than not, water moves past a hull from bow to stern, so that sheets forward should overlap the ones aft. The same basic principle as the shingles on the roof of your house.
In the vertical is another matter, as ship's roll, there really isn't a general flow of water. It could be argued that pitching causes higher water pressure moving up the hull, and why you might want to copper top-down. An argument for bottom-up coppering is the sheets closest to the waterline are the most likely to be damaged; over-zealous cleaning, rubbing against the dock, ice, etc. While either format can be repaired, the bottom-up would be a little easier to repair.
Bottom-up coppering also covers the points and narrow ends of cut sheets better than the other way, which leaves them exposed and prone to catch stuff, like seaweed, and get pulled loose.
Every photo of a coppered ship, out of the water, that I've seen, the copper was applied bottom-up. Before photography is anyone's guess, since every source I've seen contradicts every other source I've seen, like Lavery and Longridge.
On that note; copper was nailed with flat headed nails, counter sunk in pre-punched holes, so the nail heads were flush with the sheet's surface. If your coppering looks like they used the Titannic's rivets, it doesn't matter how they overlap.
