DBorgens
1 Follower
About DBorgens
  • Birthday 01/20/1957
  • Gender
  • Location
    Seattle, WA
2,530 profile views
  1. The Skippercraft factory is a 23830 Vashon HWY SW. We have several Skippercraft models in storage.
    Harry T Larsen
    Skippercraft LLC
    harrylarsen@comcast.net
  2. Wyapa, Welcome to MSW. You’re asking the right question. A good place to start is here http://modelshipworldforum.com/ship-model-plans-and-research.php A common starter is Model Shipways Bluenose. It is a good starter with many build logs on this site. Dave B
  3. Darius, Just found your log. I like the work you’re doing, she looks good. I’m also building Pegasus and have not updated my own log in a long time. Love the blue paint, it will look sharp. regards, Dave B
  4. Just found your log and will pull up a chair and follow. You’re doing a great job, especially the transom. I wouldn’t worry about the number of stanchions, the ship will look just as nice. First builds are like school, every task is a learning experience so don’t beat yourself up (BN was my first build as well). I found Bob Herman’s log very helpful.
  5. When I eventually finish Pegasus, I plan to build Speedwell. Your kit will be perfect as I don’t have the machine tools. Dave B
  6. Wow, awesome build. I’m glad I came across your build. Dave B
  7. Quoin handles. I started by using my Dremmel to turn these but had a few problems. The Dremmel is fast even on low speed and I tended to make them too small (if that is possible at 1/64). I also discovered my Dremmel does not run true. I switched to a pin vice and it worked much better. It "only" took 25 pins to get 15 usable on the model. And I still have one spare. Dave B
  8. Your first build and you’re giving us a master class in miniature machining and assembly. I still wish I had some of your machining equipment, maybe someday if I can get away with the expense. Keep up the good work and photos to inspire us. Dave B
  9. Boats are certainly welcome. Mine hasn’t been kicked out yet. Dave B
  10. Beautiful and inspiring. I look forward to your masking and rigging. Dave B
  11. Unfortunately I don't have the proper tools now to for these good ideas. I did file another set using a lighted magnifier and a magnifying visor. Was able to make the axles round by working slowly. Found it somewhat relaxing which is good as I have a few dozen axles to file. 🙂 Dave B
  12. Allan, Great solution! Sure beats trying to make them round with a flat file. Thanks, Dave B
  13. Switching to guns. As other Pegasus builders have mentioned the canons and carriages are out of scale and not the most pleasing. I broke down and bought canons and carriages from Syren. My first freehand attempt had too much taper, I can do better. As I considered making a jig to assemble the carriages, a group member pointed out Chuck's jig for carriages on his Winchelsea log. His is similar to what I considered. So I started measuring calculating and making jigs. My second one was a success. See my description in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings The Syren mini-kit is well made and of high quality. The only drawback is that these are the smallest size and the parts are fiddly little things. With a bit of care and they turn out well. There is no comparison between the kit and Syren parts. Dave B
  14. Welcome aboard Matey, You're in the right place. Look around the build logs and search for a San Francisco log. I have learned a great deal simply reading logs and looking at pictures. Don't be afraid to ask questions and pick our brains, at least those who still have some. Dave B
