Everything posted by alde
I haven't posted to my log for quite a while because I have not had much time to do any work on the Launch but I did manage to make the sails and taper the spars. The instructions show both sewn sails and faked lines with a pencil. I opted to go with the simple method and it turned out ok. The lines are a bit darker then I would have liked but I can live with it. I still have to put the reef points on the sails and the cleats on the spars. I also did the edges of the sails with fray stop. I hope to have them rigged over the weekend but we'll see.
The pumps along with everything else look fantastic Bob. It's been a great learning expierience following your log. Al D.
- 1,477 replies
- essex
- model shipways
Draftsight Question
alde replied to alde's topic in CAD and 3D Modelling/Drafting Plans with Software
Bob, I don't know why I didn't try the shift key. Maybe because It was midnight after a long day. I bought the boxed program for less than $40 and it works fantastic. For what I need it's as good as AutoCAD. Now I need to get a big screen for my tired eyes. For my first project with it I am laying out a Constitution 2 deck battle station section with 2 long guns on the main deck and 1 carronade on the spar deck. It will use the gun kits from Model Expo. Thank you for your help. Al -
I have been using AutoCAD at work for years but needed something for my modeling at home so I got a copy of Draftsight. I have to say that I love the program. It is very much like AutoCAD and pretty easy for me to figure out. I am at a loss on one thing though. When I first loaded the program I was able to select several items such as erasing more than 1 object at a time. Now when I select a second object the first one is un-selected. The same goes for trimming. I can't trim a circle tangent between 2 lines. Also when I try to draw a curve it only lets me select 3 points. I'm pretty sure I messed something up in the settings but for the life of me I can't figure it out. Any help would be very much appreciated. Al D.
Patrick, Just to add more information into the pile here are 2 drawings I came accross from the National Archives Online Resources. They are outboard profile and sail plans drawn in 1817 and is a very high resolution images. They clearly shows no gunports. There are also some other interesting details. If nothing else they are cool period drawings of the ship in high resolution. http://media.nara.gov/social-media/gallery/19-4-43-2011-001.pdf http://media.nara.gov/cartographic/gallery/RG_19_Dash_108_12_2.PDF Al D.
That should keep you busy for a while. Looking forward to the results.
- 625 replies
- bounty launch
- model shipways
Thank you for taking the time to post so much detail on your build log. I will refer to it when I start my AVS. It will be my second build.
- 164 replies
- model shipways
- armed virginia sloop
The book The Sailing Frigate: A History in Ship Models by Robert Gardiner shows models of several frigates (British) of that period with no ports. I understand the Admiralty models did not have them to better show the ship design but the book also shows several fully rigged ships with no ports. If this book shows the actual configuration it looks like the ships with an open waist tended to have no ports. This book is a great reference with really nice photos of period models. Just what you need is another reference to help cloud the issue.
Thanks Bindy, I have been having a great time building my first kit and am looking forward to the next one. I am not as ambitious as you with the Surprise though. I am going for something a bit simpler for my first rigged ship. I am doing Model Shipways Armed Virginia Sloop next. Chucks parts are fantastic. I got some of his rigging blocks and rope too. It's much better that kit parts. Al D.
Steve, Your weathering is all coming together very nicely. The interior looks like some well used boats I have seen on the fishing boat wharves. It might look nice in a partly run up on the beach diorama with just the bow on the sand and the rest in the water. You could deploy the anchor. Just a crazy thought from the peanut gallery.
- 625 replies
- bounty launch
- model shipways
Very impressive work. I love the attention to small details.
- 803 replies
- colonial cutter
- modellers shipyard
Thanks CaptainSteve, It's good to be back. As far as the cannon goes, I have no plans for it. I ordered some rigging line and blocks for the Launch and added a set of barrels and carriages to the order for the fun of it. They are the correct size for my next kit, the Armed Virginia Sloop. The kit parts are fine but Chucks are better. Did you ever find your Brass Black? You can find the Birchwood Casey stuff on-line but the shipping may be way high for you. Al D.
It's been a while since I have been able to work on the Bounty Launch but here is a wee bit of progress. Here is the Rudder Hardware. I enjoyed making these. The soldering went very well and the Birchwood Casey Brass Black worked very well. Here is the Rudder and Tiller. The Rudder needs a bit of touch up in this picture. Here is the Rudder mounted. In between I wanted to do something a bit different so I assembled one of Chuck Passaro's cannons. I made the rings by looping 28 gage wire around a small drill bit and gluing the twisted end into a hole drilled in the wood. Not too bad for the first try. More soon, Al
Great work on your FA. I have this kit in the closet along with the AVS and am trying to decide which one will be my second build. I am leaning AVS but your FA sure is a fine looking ship.
- 455 replies
- fair american
- model shipways
This is a great build log. It's nice to see you make the effort to make sure you do it right even if it means taking it back a couple of steps. This will be my next build and I have the full Bob Hunt Practicum and will follow that and the MSW logs. Al D.
- 129 replies
- model shipways
Something else to try that I have used in 1/12 scale figure painting is gold printers ink. It needs to be mixed with a carrier like boiled linseed oil but it makes for a ver convincing gold leaf. I bought an ounce years ago and have barley used 10%. A little goes a long way. It's also available in silver cooper and bronze. Al D.
Tom, I have never read anything that specifies colors for the gun carriages but would it not be safe to assume they would have followed British convention? Your gun deck details look great. Even though most of the detail will be hidden they will be recorded in pictures at least. Al D.
- 1,354 replies
- constitution
- model shipways
That looks fantastic Augie. The details really pop and enhance the great planking job.
- 2,191 replies
- confederacy
- Model Shipways
