making a round stick, making deadeyes.
to give them the same thickness, made ​​a useful similar to the gratings.
to make the stays, I put out a supplement to, and glued it would mess up the thread, and not as do the knot.
violon pulleys, and Capon, they put the plate and the hook below.
dictionaries naval encounter come in Spanish, French, and English.
but I can not put first French, and translate it to Spanish.
Does anyone know how this is achieved?
thanks
a view of the pulleys.
I'm going crazy with ropes. I'ma big hands and I'm not used to handling such small stuff.
I managed networks sewing thread, which looks very good. but the color is very dark.
the staying put
I start again with other shrouds.
This time I have prepared a useful, to come out the same.
this string, it is much more difficult than the woodwork.
June 2011.
put the mizzenmast.
although in the book are sketches of the rigging, I just do not see it clearly.
I am placing the ends, where I imagine it can be.
I prepared a box compAugust 2011.
Today my father has given me back the gun. because the weld, polish got no good.
I also did a mason.
I the first plaster mold, since it takes much silicone me.letely disassembled to try to melt the lead cannon
the first guns came out holes and splashed a lot.
I think the cast was not dry enough, until warmed it, it started running better.
I made a new mold, with additional cast as the first, was beginning to burn.
After many attempts, I got a way to make the lantern.
methacrylate sheets stick, until a taco. given the shape of the lantern, and nailed directly brass rods, needless to paste.
Finally, we pay brass rings around.
was not happy with the lantern, as I did by eye, and their faces were not symmetrical.
so I made a new one.
the system to do so, has improved greatly.
Now, I make a small notch where the rod is inserted and if the nail tip (previous drill) in methacrylate.
no need to stick almost anything too tight as it enters and costs of out with pliers.
imajen in 4334, it is still not to channel.
are very small pieces (such as clips)
next time, I'll put the thread through notches, and will give full circle, nailing just the tips. is much easier and less work.
September 2011.
to place the leaves, I almost went crazy.
Finally after a thousand tries, I saw the light.
I make notches to the piece, so that between the leaf.
go through the piece with a brass rod.
I put the leaves by the stem and press it against the workpiece tightly with pliers.
tin salary.
at the end, I put a ring of brass.
I like the reultado.
Ah I remembered right. You did a full hull model. Really beautyful.
Regards Christian
  • 5 months later...
superb workmanship Cabrapente
This build log is a real delight to watch, every Detail special tackled for getting real satisfying results
Keep those amazing pics coming in
Nils
Current builds
-Lightship Elbe 1
Completed
  • 1 year later...
  • 1 year later...
