Just a quick post - This is what I intend to place over my hatches - Its from the PE fret and shows the rough size compared to one of the hatches, the hatch layout is Two across with an equal gap, so after measuring the plate it should fit nicely with a slight overhang.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
And these are what I might use for side plates to support the plate, again from the PE  fret.
OC.
Current builds
Completed works.
I  managed to tare  myself away from aircraft spotting  and did some more work on the build, I got hold of the PE fret, and found the Catapult frame that I am using for the armour cover plate over the rear hatches,  this frame is flat and has perferations at set distances, I chose the section that is closest to the size I needed then scored a line and bent it till it seperated.
A bit of sanding and it was the required length,  next off was the two edge supports that also needed a bit of shortening,  then a gauged a channel in the decking to fit the frame edges, and after a bit of dry fitting I went ahead and glued them in place with a bit of CA, next was the top plate - again with a light application of CA.
Here are a few pics of the result folks.
OC.
Current builds
Completed works.
Nice OC, something to remember for a future build (if my memories holds on to it ...)
Thanks Carl,  I did install my own artistic license as there is no proof that this happened - just me being a bit imaginative.
OC.
Current builds
Completed works.
Another bit of progress folks - I created another piece of plating and two side supports, and  after using a small amount of CA I glued them in place,  I was them able to apply a few coats of paint - this is the result folks.
OC.
Current builds
Completed works.
Lovely work OC. No details overlooked it seems
Thanks Carl.
OC.
Current builds
Completed works.
good to see your moving ahead.........your progress looks really good.   nice overall shots of the decks!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Just to show my way of thinking with the additional armor I added to the rear Hatches  -  I had seen somewhere that she had some additional plates fitted at times - then I saw this pic - ;)
OC.
Current builds
Completed works.
More plates ... on the turret ?
I think they were just placed there early years before the 20mm Orks where fitted to the tops of the turrets,  It just got the idea that they may have done a similar thing to the rear hatches - like in my build.
OC.
Current builds
Completed works.
A bit more progress today folks (I will post some pics tomorrow in the light)  I found out a way to scribe some armor plate details - starting with the drop down deck (where the 6 inch casemates where) this had a quite destinct line along the edge about half way down, I made a guide for the line with a wooden block taped in position, and ran a needle attached to a handle along the top of the wood to gouge a narrow line, then i ran a pencil along the line to make it stand out a bit.
It went well but will need a bit more tidying up as the pencil line is to wide,  I did a similar thing in the mid ships area to the side hull, again with a wood block - same tech, and it turned out fine just about noticable,  next i formed a box area by gauging/pencil to the extreme bow end near the flagstaff, I finnished it off by adding a couple of small holes in the area.
OC.
Current builds
Completed works.
Reactive armour, I like it.
Imagin if they had covered the whole ship in ERA  - she would have weighted about 60.000 tons but would have been as tough as old boots ;):D
OC.
Current builds
Completed works.
A bit more progress folks including the pictures I promised,  I have also fixed down the rear deck so as decks and hull go its all as one now :dancetl6:
OC.
Current builds
Completed works.
Proper job OC.
Like it, like it a lot
Frank  :piratebo5:
Thanks Frank,    yep  she is getting there :)
OC.
Current builds
Completed works.
Looks magnificent, OC. Didn't realise she had such a wide beam at the rear ...
Thanks Carl,  its only taken me a year and a half to get to this stage so i guess give it another year and a half and she will be built and in a case.
OC.
Current builds
Completed works.
She does have a big bum! You'll be surprised how quickly you go now, the hull is always hard work, everything should flow from here.
Thanks greg,  yep the old girl did have an unusual profile,   I will still be some time I feel as I will be concentrating on each small section as a build in thier own. and painting small sub assemblies befor assembley, that way I should be able to get more detail on them - and in an easier fashion.
OC.
Current builds
Completed works.
This will be my first stage of rectifying the two rear deck sections -
OC.
Current builds
Completed works.
Another picture of what I need to do -
OC.
Current builds
Completed works.
Just took a flit through your build OC and the level of detail you are adding is impressive - very nice model developing here.
cheers
Pat
cheers
Pat
Thank you so much Pat,  its steady work but getting there :)
OC.
Current builds
Completed works.
I got an hour or two on the bench this evening and started work on the rear side wall, I cut it from the kit fret, and sanded the edges abit, I then fashioned a piece of plastic strip that was lerking in the kit - but not needed,    this was glued on the top edge with Revell Glue - then when set i sanded the face to get a smooth join, next I needed to reduce the hight with a sanding stick and micro flat file.
Next will be a strip of PE to fill the gap between the wall and the turret.
Oh - and i drilled out the port holes.
Just the one pic of it folks.
OC.
Edited by Old Collingwood
Current builds
Completed works.
Last shot on the roll was it now OC ;) Nice work. Did you drill them out from the in- or outside?
Hi Carl,   I did both but started from the front then just a bit of front-back-front-back type of action just to clear up any bur on the back.
OC.
Current builds
Completed works.
