That's looking great Jesse.   Very inventive to use thread for the rails.
Will try to make mini cannons. Cut out tiny wood chips for the bottom & very thin brass wire for the barrels.
Hi Jesse!
Very nice work!
You can try to use thin tubes for guns, such as needle syringe. You can also try to carve the guns out of bamboo.
Best Regards!
Igor.
I decided against the wire staples for channels. As you can see I have removed them & I am carving out notches for wood channels to be glued on.
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
The glue didn't bond the brass wire & wood base on the cannons very well so I cut out card stock bases instead. Glued several layers till it was thick enough, glued the wire on, snipped it off, filed end & painted. This worked pretty well & at this scale looked ok. Added wood channels & cut slots for shroud lines.
Thanks!
Tying yards to masts........
Very nice, very nice,  Love the cannons.
Bob
Current build:  SS_ Mariefred
Thanks Patrick & Bob!
Yes Patrick, that's my Syren in the background
I suspect that once you go back to the Syren, she'll be huge to you.   This is incredible work.  I can't believe those cannons though...  wow.
Test fitted ship in bottle neck. Had to make a few adjustments but it fits in fine now.
Started on all the rigging....
Looking good.
Bob
Brushed the dust & stuff off the inside of the bottle. White painted the wave caps. Didn't trust that glue would hold hull down to putty when the rigging is pulled so I wedged wood sticks down in the putty to have something more solid to glue the ship to. Cut out sails. Stained them with coffee. I always  do a wash or 2 in baking soda if I use tea of coffee to neutralize the acid in them.
Glued thread on sails for a little extra detail.
Glued the sails in position. Running all the rigging....
Wow Jesse!! Coming in to this just a little late but------That's what I call micro-modeling. My eyes ache just from watching you work on this. Very nice man. She'll look great in the bottle.
Cheers
GEORGE
The sails and the flag really pulls things together JesseLee, well done!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Got the ship in the bottle. Glued it down, raised the masts, glued the lines & cut them off.
Well done she's a fine ship.
Bob
