I just finished the first and only layer of planking on my Fair American.  This being my first attempt at hull planking, I am very happy with the outcome.  I used the 3/16" x 1/16"  basswood strips supplied with the kit. The results can be seen here:
http://modelshipworld.com/index.php/topic/10334-fair-american-by-captainjerry-model-shipways/page-3
This hull has a lot of sheer and a fair amount of drag.  The distance from the keel to the wales is much greater at the stern than it is at the stem so it is clear that the planking will need to taper toward the bow,  There are a few rules to follow. Too my eye, one of the most important is that a plank should not taper to less than half of it's maximum width. Pointy little planks at the bow look funny.  My personal opinion is that while a plank may taper towards both ends, it should not then flair out at the end.  To do so seems to indicate a narrowing of the hull in a kind of wasp waist shape.  That might be done in modern high speed vessels but not on an 18th century vessel.  Such a recurve line might also indicate an improperly tapered adjoining plank.
I used steelers ( 2 at the stern ), and drop planks ( 2 at the bow ).  I have always admired a well fitted steeler or drop plank and while my efforts are just that, a first effort, and not an example of the best, I don't understand the may posts that seem to indicate that a steeler is evidence of poor planning.  Were steelers and drops not used on real ships? Was it a sign of poor design or a sloppy shipyard?
Jerry
(edit note) Link corrected, Try again if you got redirected to the wrong thread.
Edited by captain.jerry
You will never know if you can do something until you try... and even then you may not be sure.
Greetings Cap...
Nothing at all is wrong with stealers. To me, it looks as though you have generally crafted them properly. Further, your overall planking job is pretty damned good. As you know, stealers insure that planks will not terminate in a point, which would prevent the plank ends from being properly fastened to the framing. I think, you use them as appropriate for the application, and I don't believe there are hard and fast rules for their usage. I can't imagine anyone using stealers unless they were necessary. Nice job.
wq3296
Hi Jerry,
I like the way steelers and drop planks look. B)
Have you seen this picture?
http://modelshipworldforum.com/resources/Framing_and_Planking/bluff_bow_planking_primer.pdf
Now that is a great picture.  A great view of a real plank job.  It also shows a number of planks that are dropped into hooked planks that ate then let into the wales before reaching the stem post.  I have never seen that detail before.  It will be a long time before I am ready to attempt a bluff bowed hull.
The example you cite, Captain Jerry, is a rather excessive one. It is the result of allowing the garboard strake run too high up the stem, forcing the other strakes to be too crowded into the stem. This could easily have been avoided by an experienced shipwright. Take a look at the example in 'A primer on planking' by David Antscherl pinned on this site. The bow is just as bluff as the one in your photo, but compare the run of planking in both examples.
Interesting.  I've not seen the strakes hooked in like that before, Druxey.   I learn something (sometimes 2 somethings :) ) every day around here.
Druxey
It is indeed an extreme example but that sometimes helps by eliminating the subtleties that may be overlooked.  Four normal drop planks and ten more hooked or tapered into the wales is certainly extreme.  If I understand your analysis,  all but four planks hooked into the wales could have been avoided if only the rise of the garboard into the stem had been eliminated and a more qualified builder would have done better.
Oh! If only the designer and builder of this full size replica had only taken a little time to understand the complexities of wooden ship building before investing the several hundred thousand dollars needed to complete their project, a disaster could have been easily avoided.  And to think, that all of the answers were there in the planking tutorial of an experienced model builder.
By the way, the example is not mine but was reference to me by another forum member and is in fact a link to another tutorial on this forum.
Here is a photo of that bluff bow completely planked. Two hooked strakes under the main wale was all that was needed!
Superb planking job!!! Hats off!!!
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
Chris: it's very similar to Endeavour. However, I'm sure every shipyard had slightly different methods of planking. I'm also sure that no more stealers or drop planks were arranged than were absolutely necessary, saving much work.
You see this technique on 18th century museum models such as seen in Annapolis or (formerly) Greenwich, Mark.
I've got to get out more and make a trip to the east coast, I guess.
Druxey
My tongue was firmly in my cheek.
If and when a ship received any damage to the hull in which they had to make repairs. It was cheaper and faster to insert a stealer or drop plank, and on occasion simply adding a scarf would mean less time in the shipyard.
Much in the same way autos use bondo to make it lookgood and get it out of the shop faster and cheaper, compareD to replacing a whole fender or such.
Time is money, even in those days.
La Nina, Latina - Wood / 1:65
On The Shelf:
San Francisco II, Latina - Wood 1/90,     U.S.S. Constitution, Revell - Plastic  / 1:96 (Remake),     H.M.S. Bounty, Latina - Wood / 1:48,     H.M.S. /Mayflower, Latina - Wood / 1:64,     La Pinta, Latina, Latina - Wood / 1:65,     La Santa Maria, Latina - Wood / 1:65,
Completed:
San Francisco / Cross Section, Latina - Wood / 1:50,     Coastal Submarine, Revell - Plastic / 1:144,     Cutty Sark Wall Plaque, Revell - Plastic / 1:50,     H.M.S. Victory, Revell - Plastic / 1:146,
H.M.S. Bounty, Constructo - Wood / 1:50,     Oseberg, Billings Boats - Wood / 1:25,     Clipper Ship (Sea Witch), Unknown - Wood / 1:46,     U.S.S. Constitution, Revell - Plastic / 1:96,
Man Of War, Scientific - Wood / 1:50,     Robert E. Lee, Scientific - Wood / 1:45,     PT-109, Revell - Plastic / 1:72,     U.S.S. Enterprise, Revell - Plastic / 1:720,
R.M.S. Titanic, Revell - Plastic / 1:720,     Numerous other wooded tall ships and boats from companies named: Ideal, Dumas, Pyro.
