Ok, Ok, you lot,calm down. I know that you have been clamouring for another Endeavour build, so I am going to
do one for you. ( with a lot of help from everyone, i hope) Which is lucky for me because thats what I really want to do.
The Syren will have to sit on the shelf a bit longer.
The reason for calling it a kit fiddle is that i don't really know what I am going to do or how to do it.
I will just fiddle with it until i get the look  I want.
One thing that I know I am going to do is cut a lot of my own timbers and planks ect.
I have read that the Replica has used Jarrah on the hull planking below the wales, and and Oregon Pine
used above the waterline. The hull will be left unpainted, I hope, if my planking is good enough.
This is another learning build for me as such i want to try spiling, and bending the hull planks and
just to see what ends up happening.
I have plenty of jarrah, and a lot of Kauri lining boards that I will use for the decks instead of
the oregon.
One look that i do like on some models, is the stripey lines of the bigger ships with the constrast
between the wales and planks, something that I want to do here, if i can.
Something that I do not like at all is the red paint that is used. I really hate it. Therefore, there will not
be much painting done except for the blue that is used. (maybe)
I think that it will be done as what i am calling hybrid planked, double planking for the wales and below  and
single planking above. To get the look of the replica as much as possible.
The kit is 20 yrs old, hence some of the ply is bent and needs some serious blocking, to straighten and
square up.
Enough talk here is a few pics
Kauri and Jarrah
PS it is going to be a slow build, which is good, because i am a master procrastinator.
Hooroo Chris
Hi Chap,
Where did you get your Kauri from?
I think that your build will be EXTREMELY interesting using Native New Zealand timber!!
(I guess you will "Re-Saw" your material? Hull or Deck?)
I am picking Deck? (Close Grained, light color and very Hard!!)
Have been thinking about Native timber selection in the past, but, how to mill it without waste? I have some planks of Kauri but are in my ceiling space to facilitate "Crawl Way" for light maintenance, Etc in between Roof Trusses.
Am now thinking that I should recover and mill.
Most of my timber is Rimu/Matai, good for cabinet work and I also have a few planks of Teak, given to me a few years ago.
I am thinking that the Kauri that you are in possession of is not the 6,000 - 10,000 year old variety, (Swamp Kauri), but more of the 200 year old timber. (Kauri takes a very long time to grow.)
Logging of Kauri is now prohibited, as is most NZ timber, you are very lucky to have this in your possession, as am I!! :) )
(I think that Cook had a bit of a "Chop" regarding NZ Trees with Endeavor repairs, so, appropriate that you choose NZ Native timber.)
I am very interested in how you will mill you Timber without undue waste.
Cheers....HOF.
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
Sergal/Mantua Cutty Sark
A/L Pen Duick
A/L Fulgaro
Amati/Partworks 1/200 Bismarck
A/L Sanson
Good Morning Hof
Yes I am hoping that the 2 timbers look good together, something a bit different I hope.
Am I correct Hof, in saying that it is Kauri, the lighter one?.
Interesting to hear that Cook might have put some into the Endeavour
It is left over from kitchen jobs from 20 yrs ago, it was a trend back then to use recycled timbers in kitchens,
The timber was machined to make lining boards 12mm thick to use as door panels in cupboard doors.
It is amazing to see the size and quality of timbers that were used to construct buildings in the early days.
Some of the Oregan that has been reused, was, as my machinist mate says it, "its like cheese you could eat it".
It was very fine, straight grained, and no knots
The Kauri is going to be used for the decks, and the hull planking above the wales, which I am hoping
to do as single planking. I might use some below the wales to get the stripy look I like.
Mostly below the wales will be the Jarrah as 2nd planking, and I am going to try and use
radiata pine for the 1st planking there. I have about 15 1.5 metre lengths of the Kauri LBs
I have a sliding table panel saw to break it down a little bit, but i am going to buy a proxxon
mini saw to cut into planks, after i thickness it to varying widths .
Only time will tell if I am capable of doing what I want.
Hooroo Chris
Edited by Cabbie
PS Its going to be a slow build between here and Christmas, work is busy, I am still getting organized.
I am waiting for the new AOTS to come out early October to see what they are saying
And after Christmas I have to do a kitchen reno for myself.
BUT there will be some time for modelling.
Chris
Thanks Chris,
Have just started my A/L Endeavour as well and follow yours with interest.
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi Chris
Welcome to the endeavour club.
I built this kit twenty something years ago, your box looks identical to mine, so same age I reckon. When I built it I left everything natural wood except for some blue on the upper part of the sides and stern. I wanted it to be an ornament more than a scale model, and it still holds pride of place on the shelf in my living room. There are pics of it in the gallery on here if you want to check out the finish etc.
Cheers
Steve
Edited by shipaholic
Current Build: HMB Endeavour 1:51 (Eaglemoss part work)
Previous Builds: USS Constitution (Revell plastic) HMS Victory 1:96 (Corel) HMB Endeavour 1:60 (AL)
Geez and I thought I had an original idea. That's all the painting i was thinking of.
I want to be as scale model correct as i can, but have the look with the timbers i want.
The first planking in this kit looks to be be a bending ply about 2mm thick. It bends easy enough.
But i think it would be tricky to taper the edges. Hooroo Chris
Edited by Cabbie
Good Evening
A little update, Some of the ply was warped, and bent and it needed a serious build board to
put it in the right shape. I cut the slots for the masts and a rebate for the planks to fit in
along the false keel.
Can any show me how the ship is bolted to a base board through the keel.
I have seen some examples but they don't show totally what is happening.
Can hollow pedestals be bought?
I am getting ready to start glueing bulheads and blocks in place.
A few pics
Thanks Chris
Edited by Cabbie
Hi Chap,
I can't comment on the warped stuff other than your "Blocks" will most probably  straighten things out. (Clamp and glue your Bulkheads/Keel. Your "Jig looks really robust.)
Pedestals will come much later in your build, after Planking.
So, my thoughts, get everything straight, Blocks inc. to real;ly lock things in and install and Glue your Bulkheads.
Think of this stage as a miniature Joinery project.
Wot comes later is also a miniature joinery project, no straight lines!!
Pedestals are available, pre-drilled`but expensive, (For me anyway. Have to import), in NZ
Any Help?
Edited by hof00
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Good Evening All
Time for an update, not that there is much more to see.
I have blocked in most of the sides of the ship, and have done a lot of the fairing.
And I have nailed the decks in place.
Can anyone tell me about the gunwales. The pieces supplied are 5mm x 5mm,and if I fix them to
the decks, they will lean out from the ship due to the slope of the deck. So I assume that I should
plane an angle on the bottom so that they lean in as per the replica. And I suppose that they should
be faired as well like the rest of the ship?
All comments and advice will be much appreciated. Thanks Chris
A few pics
Edited by Cabbie
Hi Chris,
Just came across your build here and wanted to offer you words of encouragement, mainly so that I might be so inspired to get off my duff and start back on my Endeavor.  Started the bloody thing back in 03 and kinda hit a mental block on what to do next. Like you,  I have been fighting what to do with the gunwales midships.  I planed at a angle the quarter deck but the waist is still an issue. So your question is a common one.
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
Hi Chap,
If I am correct these are bits of 5.0mm X 5.0mm along the edge of the Decks?
From what I get from the instructions is that these are sanded to fair in with the upper Bulkheads.
After the first layer of planking, they get tapered lengthways.
I Laminated mine from 2.0mm X 2.0mm Walnut as this I thought would be easier to form around the edges of the Decks.
Any help?
Cheers....HOF.
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Hi Hof, Your right,  with later reading the instructions do say to fair the gunwales with the line of the ship.
And I have decided that i will angle the bottom of the 5 x 5 so that the inside of the gunwales is parallel to
the outside after fairing.
Hi Scott the model is looking good ,but i don't know how you will find time to restart it, as well as start
the Sea Witch, and finish the other one, and do more house renos, but good luck.
From looking at photos I have seen that the top of the gunwales slowly tapers up at the start of the poop deck,
and rises a bit sharper at the bow, and it does the opposite in the other direction to give a long slow curve.
But with a step in the middle. And the wales and planking run parallel to that curve.
I have made the poop deck a bit wider midships so that the gunwales, balusters, and handrails
will all run in the same line along the ship as per the replica. My kit has the waist deck handrail outside the line of
the poop deck handrail.  I hope all this makes sense to people, this is all totally new to me.
For anyone wanting photos to look at here is a few links
http://www.modelships.de/Museums_and_replicas/Endeavour/Photos%20HMB%20Endeavor.htm
https://www.flickr.com/search/?tags=endeavourreplica
https://www.flickr.com/photos/endeavourvoyages/6814873270/in/photostream/
This last album has some clearer pics without so many humans in the way sometimes.
Edited by Cabbie
Hi All,
I think of the Gunwales as a little "Sacrificial" at best as there is a 1.5mm X 8.0mm Walnut "Finishing" that goes over the first layer of planking and the Gunwales/Bulwarks, so, the Gunwale material might get a little thin but will be covered up.
In saying so, the "Bevel/Tape"r is important and the Bulwarks get level when they are tapered. (File across the Deck.)
If you chamfer to the Bulkheads, I reckon you can't go too wrong, it seems to "Flow" a bit.
Anyway, I'll post some photos of my efforts soonish.
(Have had to re-do the Fore Deck Planking as cut through the 0.5mm material, might be a blessing in disguise.)
Completed Builds:
A/L Bluenose II
A/L Mare Nostrum
A/L Pen Duick
A/L Fulgaro
A/L Sanson
Good evening all
Time for a little update, Poop deck is planked but not finished.
I couldn't help myself, I had to put some poly on to get a better idea on how it was looking.
I think that the colors and caulking have come up pretty good. I don't like the caulking looking too obvious.
Waterways will go on next, then do the other two decks.
I have tried to copy the replica deck, just going by  photos. I think that it is
reasonably close to it.
Now to see if i can put some photos up to show.
Edited by Cabbie
Great looking deck. The caulking is perfect. For this item -caulking - less is more. What wood are you using for the decking and waterways?
Thanks
Michael
Good morning Andrew, Michael and Canute, thanks for the likes and comments.
The decking is recycled Kauri, a New Zealand wood, and the waterways are to be Jarrah 2mm wide strips, a West Aussie wood.
The caulking was supplied courtesy of a Neocolor ll water soluble, wax pastel, applied to one edge. Which
actually looks better than it does in the photos.
Thanks Chris
Edited by Cabbie
Man, it takes time doing anything on this build.
It has taken a week, to take photos, to show the waist deck planked,
But in the mean time the fore-castle deck has been planked, and the waterways
have had the hot water treatment, and bent into place. I will
glue them in tomorrow.
Thanks Chris
Yes Ok I will admit it the water ways are fake, they don't have any shape
to them. But they look the part.
Edited by Cabbie
Deck is looking fantastic Chris.  Your waterways, is that one piece or multiple pieces that are being bent?
Hi Scott thanks for looking in.
No heroics around here, that is 2 pieces each side being bent.
I tried to cut them from wider pieces, and put a couple of joins in,
but it needed a scroll saw to cut, which I don't have yet.
And thanks for the like. Chris
Good Evening All
A little bit more progress, forecastle deck is planked, and has been
given a coat of poly.
It has been fudged a little bit, so don't look to close.
And I have started fitting the gunwales
I thought that the gunwales would have been relatively quick to do.
Well ha ha ha ha ha, HA, should have known better, very fiddly little things.
Getting angles machined on the bottoms, so that they lean into the ship, and fitting them around the planking.
But I think that I am doing them the hard way.
Oh well good fun anyway.
Here is a pic of me over killing it a bit, using the panel saw to cut an angle on the bottom
of the gunwales.
Hooroo Chris
Edited by Cabbie
Good Evening everyone
Big day today spent a few hours doing a final fairing, and trueing up the ganwales.
And I marked out the top of the wales. I think that they are close to the right position.
They mostly seem to be parallel to the top of the gunwales.
One good thing I discovered about doing a lot of blocking was that
it makes it easier to hold the ship by putting it in the bench vice.
Lastly this evening I have given a few planks the hot water treatment,
fitted them to the hull, and clamped in place to see what they bend like
Hooroo Chris
Edited by Cabbie
Help needed please
I am just starting to sort out the first planking below the wales, which I am
hoping to spile? and do as well as I can. Does the garbord plank, and the cardboard template look to be right?
Or do i have the curve too sharp?
All comments welcome
Thanks Chris
Or am I going about it the wrong way?
Also what would be the normal width plank that would have
been used to cut a curved one from.
Thanks Again
Edited by Cabbie
looks to me like you have the wrong side of your garboard strake tapered. I believe you want the other side tapered, the way you have yours tapered you are going to create a downward sweep, which you don't want. Looking at your picture, you should  taper the top edge of the plank, in your case you have tapered the bottom edge. I hope this explains it clear enough.
 Your decking looks great.
Hi Steve
Thanks for looking in. I really want to have a go at spiling and try it here,
where it was going to be covered up.
I have Chuck's Syren coming up next and wanted to improve my skills.
I have to do a good job of the Syren or people might talk.
Before i get going i just wanted to know if i was starting out right.
Thanks Chris
HI Chris,
I agree with Steve, plank from the main wale down.
The first plank to the keel is the Garboard plank.
Are you planning to have a rabbet on the stem ? where the planks run into ?
I only did this on the 2nd planking layer.
Let the planks lay(go) where they want to wrap on the hull, otherwise they will twist and (I) got into a bit of problem in this area until I got them back on track.
Good that you want to practice the spiling and steelers ?
On the second layer, it will look a treat.
Dave R
Dave R
Measure twice, cut once.
Current Build: HMB Sirius 1786 - Flagship of the First Fleet to Australia (Scratch Build in the Shipyard)
Finished Build: HMB Endeavour 1768
Hi Dave Thank You
I am waiting until i get my copy of AOTS before i do anything up top.
I want to see how, what I have done, compares to it. My first planking is actually radiata pine,
and it is flexible stuff especially when wet. So I am thinking
that it will bend, along with some spiling, to where I want it to go.
Its a learning exercise, just to see what happens when i do something.
Cheers Chris
And yes Dave I faired back the whole of the bow blocking, to leave the
narrow strip sticking out that will form the rabbet.
I will fine tune its shape after the first planking.
Edited by Cabbie
