was thinking of building a ship for winter project haveing built airplanes by kit or scratch . This will be a scratch built USS Essex
            History as follows a thirty-two-gun frigate built in Salem, Massachusetts, in 1799, was not the most glorious vessel in the history of the American navy, yet she was unique. Sailors throughout the world remarked on her speed and beauty of line, and the list of men who commanded her—Edward Preble, William Bainbridge, James Barron, and David Porter—reads like a who's who of the early American navy.
         She was the first U.S. warship to round the Cape of Good Hope into the Indian Ocean. Thirteen years later, she became the first American man-of-war to round the Horn into the Pacific, where her crew fought and lost one of the bloodiest sea battles in U.S. history.
        I intend to use wood possibly some resin / casting  . Epoxy home/made jigs the whole ball of wax . As i work my models i get ideas for tools . The plan's i found online a search of the title may just turn up the site! A pm for tip on plan resource ? question
        I suppose i will cut a few corners in order to speed results i will be making some comparisons to(relying) other models on forum but i am flexible with conventional methods/ as you will see" posting first pic will try to keep em comeing will be about 5 days for lite ply to get here see you soon.. by the way way too much rake(set) on my copeing saw  blade for oak lol,spelling ? olde english' thanks
worth mentioning traced pics after finding plans"...  Did screen shot then pasted to paint" i used the 2 x times magnifying tools (size 3 would be better to ships models of this type slightly more wood to build and easier to shape) . I placed a glass pain from photo frame over screen then traced the plans from pc paint to note paper"(tape to edge with tape, from the paper, cut and traced to wood .(in case you wanted to do it this way )once did a mustang p51 this way if you got printer just hit print but its not all in the eye most is dune with the hand so traceing seems  crude
   12-31-15 also ordered some mahogany veneer thinking' about some tiger wood veneer, some hemp string ,&dead eyes downloaded a bunch of .jpgs. of several great essex models so i have reference  haven't found a mast yet.
Edited by spongbob
are they called ship bows /frames? Also working on cannons trying different" idea's from wood ,to bondo molding,getting some wood together. Get back in a few with some pics ...also found essex build on this site.Can i mention currently a nice essex model kit on EE baay for around 350.00 . There are so many online to say the least a lot of work" .Nothing is cemented yet', so some alignment you see ?...thanks
Edited by spongbob
Nice start Bob.  She certainly was a very handsome ship.  Good luck with your build.
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
building some on project ".... have mockup of cannon close to scale made with simple plaster mold and auto bondo .Made the tiny wheel by sliceing off a little roll  The cannon is bondo  also just make one make it then cut flash off and sand to size i glued the pinion's onto the cannon. and paint !
   a picture with a cardboard deck template might prove necessary' to figure deck / galley and hardware" positions also determining plank length /width mark's for mast position ect Obviously il put some small piece of wood under deck side tmast hole soon...no glue yet to many alignments left more frames to cut & sand
Edited by spongbob
almost dune cuttin frames will try to stack them on keel upside down and compare the level of the deck to pics of models .I think thare's some concavitie to it(2 degrees ?). Must decide precise position before gluing frames to keel. Then on to final sand and plank steps "plans show frame bottoms 3 to 10 are parallel to each other at keel (need pic later)the end frames to trail deck ward dirctn.
Edited by spongbob
first time to build a scratch ship and taking sometime to follow plans .will line up frames to bottom cement with balsa wood on one side', if some prove to be misaligned i can get them cut loose later ...Floor seems to be the spot to deck it from .Trying to keep a straight piece underside then scrouge frames to depth stick the balsa shim
Edited by spongbob
Spent all day on Essex sanding /glueing "culmination of questions and careful fitting of parts everything is twice as hard as i thought it might be ....
       Plans proved to be off im certain if  anyone' see's any thing out... it may be that i will have to adjust it presently . In order or work 0.determined most frame alignment and maked side for glue'
                                           1. Rough leveled frames to keel piece .
                                           2. Cemented frames to keel with one peice of balsa
                                           3. Sanded high spots
                                           4. found low spots on frames and built them up then re sanded"
                                           5. Replace a couple frames that were to out of shape
                                           6. cut /shaped balsa wood to make filler for front planking assembly
                                           7. made some more template's for deck sections"
                                           8. triangulated mast positions and double checked
          Overall" a lot or eyeballing of outlines plenty of sanding and checking fit of each part. making templates " helped to get feel for the layout .Frames 2 is not in the picture below it fell off (so little epoxy.
      Thanks to the other posted ,projects for some helpful ', posts getting some ideas is about where im at."
Edited by spongbob
Back with a with a couple pic's of what little i have accomplished'.  Comparing with other Essex" build's ,and "add libbing" a little .The windows are supposed to be inner shadow windows will have to have opening in plank also! And hopefully will put tiny led lights in ",and on ship' with switch, and small battery/circuit somewhere eventually " I noticed spots will need a little adjustment here and thar '....
Edited by spongbob
Bob,
Usually, the area that you have labeled "shadow" is solid except for a door.   The quarter galleries are the Captain's and senior officer's seats of ease.  One on each side. There would be the three windows on the outside of it however.  Other than that, everything is looking sharp.
hello and good day or afternoon " some things about scratch buildin can make one scratch his head never mind a workaround can be had .... After adding some piece' to the side of my project "  Obviously" that there where low areas that had to be filled and the high areas just sanding .
       I had been considering using bondo," sparingly on the side if necessary ,...of course it will hinder the epoxy bond and prohibit water  wood glues . im" using "it anyways , as to much wood filler "isnt to good either ...
       Posting some pics of the results ..Thanks"' for reads and posts!. Further more" I sanded bottom' of frame,...I found some more sanding needed to be dune ,.... applied" a little  bondo on the side's  ! ..Top picture has the bondo the lower picture has the (on) bottom side already" sanded / bondo-ed and its true-er then the unfinished half'...
Edited by spongbob
You are starting well Bob.  Your bulkheads look pretty good.  If you have any questions just ask.
David B
filled the space in between 1 and 2 with balsa wood surface to bond planks ignoring the fact that the keel is out of scale...camera is takeing fuzzi pics other cam was better but needs google fixed ...oh well"
Edited by spongbob
                                                         working at back
While my title states" with plan's ...it dosnt always mean there will be no revisions . Currently cut strips of 1/32 plywood and strips of the mentioned veneer"(mahogany) & laminated (wood glue),only thing is scale to cut them down to scale may be tedious,maybe grooving' each plank' strip to appear to be  2  il' have to decide!
I cut the strips easily with a frame square and a box knife after marking width with paper jig.....3 to 4 passes..
         Cut and attached  some deadwood for cannon ports ,added some balsa filler in cabin area .The rudiment square window ports(may need elongating) along cabin area are for the led light's i intend to wire in cabin they are orange",.. hope to install at later stage.. stay tuned nothings in chiseled in stone" at current.This part should be more interesting .
To mention a few thought the scale ect has some basis for concerns like slight cracks between planks wherewith it may be i can paint some wood glue to the inside, and coat it with black paint.
For cabin lighting whether to place some tiny mirrors inside to throw light out windows .locating the ships lantern anyone who knows where lanterns were placed please  inform me.... as i haven't locations of such .
   Should i make a mix match template dummy" sheet
           to find out a good plank pattern or simply place them for
                least material loss with simple staggering
                    ignoring any copper clad effects"
Edited by spongbob
building with epoxy has its drawbacks but much of the time allows for several small items to be applied or one item to be glued and dry enough in say 7 minits to be stuck safely together ,
      On the other hand it seems like when you mix a tiny dab like 4 to 8 drops it may take longer to harden then you expect therefor the epoxy creep sets in,...>parts you thought were set" have sprung loose <.then this is NOT"GOOD!...
          You may be able to re position' them in time other wise" you may just as well get an Exacto knife' and cut the glue out ,and away from the part, for re gluing " wasting" more time then using slower drying glues some time i put white wood glue in the middle and epoxy at ends but this you have to leave space between the two glues.
       Either way clamps or some pressure at points is necessary. i put a picture of the planking from inside ",where i put small 1/32" plywood scabs as the old creep was playing with my position i can tell you i super glued them for fast support just common sense as they will be invisible and provide a lot of strength, you may have better idea's but for speed it works for me ...
         Tried" splitting a plank to get it to contour to a tight turn this will not work for more then say a 30 degree bend it seems fine at shallow contours'..  I am happy with the result of the veneer planking the photo makes it look bad but it really is fine'. Its taking a lot of time and if you' See anything" in the wrong place.. it presently may be moved"....thanks for sharing'
          after thought maybe i should be cutting the veneer in two to place on one strip for better    scale effect instead", of the grooving il try a couple planks that way next"!
Edited by spongbob
Planking bends :  at bow or any tight curvature planking', especially glued with > epoxy < it is possible to cut relief cuts across planks grain as to physically improve flexibility; results" conformity ! (bends easier) .
       Cut too deep /bend to much ? it will cause cracks" . Im going to suggest circular bends of say imagined perimeter 3.75 to 4 i would use 1/4" cut spacing  then open the cut a smidgen on the inside by turning the saw to 70 degrees .Still not flexible enough ? simply make more relief cuts. No steam is required thereby leaving a dry surface  to apply glue.Make sure glue' gets into the cut's you made ...allow surface for re-sanding to round ...as you  can get micro flats lol. a coping saw "makes proper width cut ',  it can be managed with a razor 'also...
PS: i had some of my laminate veneer to loosen up after bending the plank i simply reglued with wood glue     while   strip positioned partially bent as it would be on model
Edited by spongbob
working on sides makes for many measurements . Im telling anyone who uses the lite ply as planking befor glueing veneer to the ply sand the bow planks inside top', and outside bottom or you will have a clapboard effect thats going to cause yer veneer" its self "to have to be sanded to thin"..
           This bow sanding of bow' areas of ply strips only necessary in the bow bends area, and is a good suggestion, and fit improvementresulting ",.. before gluing to frames or dead wood .
            Actually the whole plywood process may be less then simple 'at this stage"...i picked ply because this scale is small
                             top picture of trim piece  made from maple  and long  trim pieces (TO THIN TO BE BENT) also for sides ...Made the round piece using strip of maple sawed from no#1 maple sawed in pieces 3/4" x 20" then lengthwise ect ...Used only a drill ''drum sander and hand sanding ,&cope saw. The rest of the maple im trying to make deck planks with!
Edited by spongbob
Can anyone here tell me if thare is something wrong with the mast pictured,In pic labeled Question? ..I have never built a frigate mast ,...my plans seem to show 2 board's, are attached to the top half of the mast', in this case: under the  first crows nest . Plans being what they are im wondering if i need to flatten the round sides not under the boards for the last inch or so or should the mast  remain rounded?
                > i flattened the mast under the boards only.<   plans call for some bands ect in not worried about that but haveing  a hard time finding a picture that follows what i have dune on mainmast so far>>>>thanks for any info
Edited by spongbob
this evening found me planking a few strakes "is it ?.....pictures a little rough but im satisfied with progress .A few days ago i notice the topographical deck plan did not match the side views or frame bulwarks ect ,im puzzled "... makes me hope my model isn't grossly out of scale .The in conclusion" i was presented with, seemed to show a 20% longer deck with same width and that isn't likely , i see some epoxy  cracks that look bad i think i can match paint them thanks for views have a great day"...
Edited by spongbob
A few days since i posted what ive been doing '!...well the front bow area i have sawed the bulwark stubs off in favor of making my own safety handrail"?.. I had to add some dead wood to achieve what looks like the correct top deck hull height' .This after much measuring" and comparing photos of various essex models "  found online "...
              I used (made)paper templates throughout various part making most from my plans plans didnt include modified deadwood shown,lol"...Those two handrails in front are maple the cap plate is ply....no staunchen rails yet or tie off stubs..
            some rough areas will clean up", some unfinished areas will be hidden", some few estimated parts seem to be working as hoped ! .what more can i say"...il have some more(pics) in a couple days.
Edited by spongbob
2 pics top bow plank ...but the plank below it' that has the little groove to simulate 2planks.  Stern dead with wood filler over it" 18 ..its probably good enough to glue to.
   this' may seem like small changes .."but you should try the work..lol"  ....
       Im going to say something about this one plank ply with veneer over it ".. since im faking 2 planks on one ',and at this scale one should sand the ply to some convex or con cave in other words for that plank below i should have took the corner of a sanding block and sanded long lengthwise to form a dent shaped center there (prior to veneer")for allowing the plank veneer to seem to follow the roll (bend)of the hull.(i didn't  its a little flat as a result')..hopefully il get a little roll on the next plank down especially if i sand the center of plank (siight crease )
Edited by spongbob
while again i found myself pondering the  curvature of the bow and the simplicity of my options i had already thought that i needed to allow for lateral (isnt it) curviture
       Well whatever it is to get my plywood planks to flex in at the bottom more then the top edges (actually vise versa) i  decided" relief's where the option. Especially using epoxy under the strips," but still using white glue", to mount the veneer or remount
      > at least the bow area' < as the side shan't" require such a twist', neither do (would) regular wood  solid wood strakes .Using the lite ply requested whats in picture 19.....BOW  PLY PLANK PREP....lol i guess you can see why my saw is a hak !.........    at least il know tomorrow going to bed its 12:30 AM
    I had better say after the first strip you had better' start crowding the front bow planks, i mean make the front smaller" either sand the sides or cut planks slimmer at front near total bow area now much skinnier 25%off should do it at bow end the same will be said with stern bowed area (not ther yet) also maybe leave the veneer unglued and work with the ply strip its self until you manage the sharp bend twist and glue you can always forget the plywood', and just use natural wood strips much easier to sand to shape after shape the ply's great for the sides though"!
Edited by spongbob
Simple idea' center deck section:  Put together with some maple planks glued cross ways" to some plywood strip's ...on what is the underside ,...plywood centering in the area between /on the frames so planks will rest on top of the floor frame's .
     The decks not perfect ,some defects visible", but making the planks was taking day's of time ...just what you see" dune .I have to cut hatches" out ', and make a mast hole',...as i have reinforced the mast mount boss" from 1/8" ply' ...not putting the last plank in until its glued in ...might' cut a little false stagger' pattern' ,have to decide".. LOL..so much for now ...BBL...
Edited by spongbob
Back tonight with a couple hours worth of crafting top deck' indexed plank pieces ? maple wood" a little thicker then the planks .Il need to put a little strip of lite ply under these to lay the plank glue " on .(later) .
Edited by spongbob
Today i made some more planks that still need sanded but i had found a pliable type of wood that looked like maple .I made a false plank panel to mount inside hull ,level with the gun deck" .I traced the cannon port's to the  sized piece"
of wood after which i drilled small holes at the traced gun port's corners" then i cut between the drilled holes"from both side's and sanded the gun port's to size with a scrap piece of wood just smaller than the ports ,.. i had super glued a strip" of 100 sandpaper to.
    Added some length to the center gun deck and cut the square grate holes  .
      Debating what to do with the deck area not readily visible under the top fore and aft decks" i could use a softer wood 'and make them soon... as an option ..Its march and the weathers breaking will try and keep something coming !
Edited by spongbob
Making the gun deck areas used a softer wood and simulated the planks with line cuts .They are simply pear wood panel's cross biased"glued to strips of plywood', attached a little lap piece of ply to edge of front and rear section for level.
    Type of wood ? (for the covered' part of gun deck) im' going to guess" might be pear", its very light easy to cut or sand" but hold's a good shape' when working ".....
    I can see into / through the cannon port's and the deck/ panels seem to be the right height just sitting on frames .Il" put some poplar joist's when i get to upper main deck and rear quarter deck...even though you can see some difference from the top those differences visible though ports /levels are  minimized...
    You can see Ive' cut the main mast' deck hole precisely so not as to seem sloppy. this post finds some compromises present  so that i can hopefully get on to some better external details " If i had to do this over i would make the center deck panel longer by 20% and stagger the planks to interface the two end deck sections .feel free to learn from my mistakes" lol. If my ship 'had been to dry dock with 2 broken mast it might have resembled this, i said might have lol..............that front hatch port had to be lengthened" after pic.
            going to mention that i have found tif diagram plan sheets since i started even though custom is ok!
Edited by spongbob
Trying fillers to fill the deck wall gun port's  with bondo and wood filler. Neither one is faster no im not applying them over each other its rough looking but it will be between planks and i have to sand it down yet .I cant find the piece of balsa i used to began making spacers with its late again singing off for today.
  Ive got to get a nail spike to grind down into a mini wood chisel if im" going to make plywood spacer,s"
Edited by spongbob
