I think you are from outer space.  You have some insane skills.  Very proud to know where to find these pics so I can show others.
 Simply beautiful, man...holy crap.
Hi Patrick!
You made this day for me! I laughed for a long time )))
My alibi - the photos of my childhood ))
But seriously, these small details are quite simple to manufacture/
Best Regards!
Igor.
Igor,
I am always impressed that your rigging doesn't end up in a tangle - one look from me and thread puts itself in a knot.
In your last photos of the ship standing on a block of wood I can see a thin white layer. Is that a piece of double sided tape?
Ian M.
Current build: HMS Unicorn  (1748) - Corel Kit
Advice from my Grandfather to me. The only people who don't make mistakes are those who stand back and watch. The trick is not to repeat the error.
Yes Ian, in this case, I used double-sided tape for fixing of the ship.
Sometimes a kind of tangle thread scares me too, but in the end everything falls into place. )
Hi everione!
Small update. Over the weekend, I have prepared the cloth for the manufacture of sails and the blanks for gaffs.
Best Regards!
Igor.
Hello Igor,
The photos of the cloth make it appear to be rather heavy.  How thin is it?  When I am going to make a Dutch fishing boat in a lamp then I will need very fine cloth.
To answer your question about what boat I plan to put inside a lamp, that'll be a Botter.  I plan to put it inside a 6 inch or 152.4 mm with a 18 mm opening.  I like the old working boats that were used on the former Zuider Zee.  It could also be an other type out of a choice of 6.  I have the drawings of only a few though.
The model will have to be done in pieces because of the small opening.  These boats are rather wide on the beam.
This model is from about 1920 at a scale of 1:20
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Hi Piet!
This boat is a great choice! I like it!
Regarding the fabric ... I think it would be easier if I just send you a small piece of tissue in the letter.
You can write your post address in PM and I'll send it to you.
I have used this fabric a few times for my models:
11059416_494932657325523_223213203716661
10407945_464682243683898_185268168994259
11891220_521528211332634_111494507949174
Best Regards!
Igor.
Thanks Igor, yes, I like these Dutch working boats, especially the Botter as shown or Kotter.  They are not too complex for a bottle or lamp when compared with a Staen Jacht or VOC Jacht.
Also thanks for your very generous offer to send some fabric to me.  I'll PM you.
Cheers,
                       VOC Ship Surabaya
Hi everyone!
Many thanks for your interest to this project!
Here is the little update per last weekend.
Best Regards!
Igor.
Igor,
That is an interesting way to make tiny brass rings. It produces a great result.
Can you clear up a few things for me?
Is that brass rod (not tube) that you are annealing in the 2nd photo?
If so in the 4th photo are you reaming out a hollow in the rod with a broach? I can see that it would be tricky to stop it wandering off centre.
Thanks.
Edited by ianmajor
Ian M.
Igor,
Thanks.
Hi Ian!
In this case, I used the medical steel needle with a diameter of about 0.5 mm. In fact I could not find a brass tube diameter is less than 0.8 mm, but the needle may has a diameter of 0.3 mm.
This is no rod )) I use a conventional needle to handle edge of the tube. So I rule out the sharp edges of the tube, which can cut the thread.
I often use medical needles of different diameters for my models. I did portholes, davits, gears for winches, mast's elements, etc.
Best REgards!
Igor.
Edited by IgorSky
Ingenious!  I'm learning and making notes Igor.
Cheers,
                       VOC Ship Surabaya
Thank you Piet!
I am sure that you easily can place your ship in a bottle.
So, the next small update here:
Best Regards!
Igor.
Edited by IgorSky
Are you sure about the scale? She looks much larger.  Like 1:96 or so.
Bob
Current build:  SS_ Mariefred
Hi Bob!
I will find my special match and I will do the photo a little later ))
Best Regards!
Igor.
Edited by IgorSky
You mean you've got to find a bigger match to keep it at scale ... ;-) Superb job Igor, never mind the scale!!!
Cheers
Carl
Hi everyone!
Small update was made yesterday. In during one evening was made only one sail ))
Best Regards!
Igor.
P.S. And of course, I again did the photo with my special match ))
Igor,
You should take care not to crush your build with such a hughe matchstick!!! One sail an evening ... better then none!!! looks pretty darn good ... can't wai for the remaining sails
Cheers
Carl
Your build is great.  I hope you never lose that special match.
Bob
Hi to all!
Now I have a little vacation and I continue to build AMERICA )
Here is the process making of the next sail:
Best Regards!
Igor.
