The subject of this build comes from the book “The Sloops of the Hudson River” by Paul E. Fontenoy.
Plan 4 from the book will be used.  It is “Sloop Robert Wiltsie, built by William Dickey at Nyack,
New York, in 1836.  Lines taken off original half model by Charles G. Davis;  head, stern,
and deck details reconstructed.  (YACTHING, FEBRUARY 1933)”
I have decided to build this ship out of Bamboo.  I have a small grove in the back yard which will
provide the material.  I splits easy using a pair of wire cutters.  A finishing plane and sandpaper
are used to square up planks and timbers.
Walter
The Hudson river sloops were interesting as is your making it with bamboo.
Bob
Current build:  SS_ Mariefred
Bob,
Thank you.  So far so good with the bamboo. I sure have enough of it.  We'll see where it goes.
Tom.
Thank you.  I'll definitely check it out.  Studying the details will sure help when I get further on.
Walter
This is going to be interesting! Will you paint the ship, or leave the bamboo showing?
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
The Nautical Research Guild
Hi,
I would like to thank everybody for their likes and comments.
The keel, stem post, stern post and dead wood have been created and glued.
I’ve now started working on the frames.  I have to take care to prevent unwanted splits also
I’m finding carving tools (chisels, finishing plane, cooping saw) are working out better than
more conventional hobby tools (number 11 blades etc.).
Walter
This should prove to be an interesting build.  I have rarely seen bamboo used for model building.
.David B
Hi,
Thank you Bensid54 and David.  The type of Bamboo I'm using is Yellow Grove.
So far so good.  This type has a nice flat spot which is allowing me to make some nice wide planks which will come in handy for spiling.
Walter
Bensid54,
Cutting the lengths are easy, I use a pair of wire cutters.  A good crimp will cause a nice split down the length.  Once the split has started just pull it apart.
A finishing plane and sand paper are use to complete the plank.
From my bamboo I can get 9 inch (230 mm) lengths.
Walter
Thanks for the explanation Walter. From what I can gather you could laminate the bamboo to make your own beams, lumber and even plywood. Beams and plywood made from bamboo would be incredibly strong, I find this very interesting. The keel you made Walter is likely tougher than anything out there, warping would likely be kept to a minimum.
SawdustDave uses bamboo for his builds lately.  As I recall, he buys the bamboo cutting boards from Wal-Mart, etc. especially when they go on sale and cuts the planks, etc. from those.
I like it.   But then, I like anything that bends easier than ebony so your milage may vary.     On the serious side, most of the scratch builder (or maybe many?) use boxwood planking.   I use swiss pear on my build and it worked a treat.
I'm looking to bring in some wood or go to the local building store and maybe cut my own planks. The wood I have to choose from is cedar, fir, oak, basswood and Cherry. The cheapest would be fir or cedar so I think I will be leaning in that direction.
Nice framing Walter! I look forward to your next update.
-Elijah
Current build(s):
Completed build(s):
Member of:
And you did a little happy dance singing, "She floats, She floats".   Looking good, Walter, looking good.
Bob
Edited by Cap'n'Bob
