10 hours ago, BANYAN said:
Just found this build Phil, sorry to crash the scene so late - hope you don't mind me tagging along. :)
I am building HMCSS Victoria (1855) which had some common equipment etc to Warrior - see my log at:
I will be very interested to see how you approach a couple of items such as the catheads which have a much sharper than usual angle of rise.
You  have made a great job  on what you have completed on a very interesting build (and large)
cheers
Pat
Welcome along Pat, or should that be aboard :)
Hope you find some useful stuff for your build as things progress.
Cheers,
Philip
great progress...........she looks really good ! :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
painted or coppered.......the filler is no problem.   she's a big beautiful girl ;)   planking looks great!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nice progress Phillip, even at 1:100 she is a might big model (with plenty of planks).
cheers
Pat
Hi All,
Internal gunwales and deck channels added ...
s20170502_101113.thumb.jpg.67edf574ea10a00df36751fc9ee92cb7.jpgs20170502_101101.thumb.jpg.5c6fb38235e6720ad4116965c96b37d1.jpg
Propeller and rudder completed. I modified the hinge of the latter using 5mm brass tube fashioned into faux hinges with the horizontal supports cut from .5mm plasticard and run over with a pounce wheel to simulate rivets. The porthole surrounds are 4mm eyelets painted gunmetal and glued in.
s20170503_102528.thumb.jpg.545767326533cd34e8ce4d1137ccb62e.jpgs20170503_102544.thumb.jpg.34bd025bef00e1679598c451a1a39afd.jpg
And a couple of general views showing the paintwork.
s20170503_102601.thumb.jpg.4edd49266df93ac163149d429f254824.jpgs20170503_102614.thumb.jpg.059043a4aaa14cfdc0c0c31a3ae564cf.jpg
she look awesome.........truly great progress! :)    decking and paint looks great!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nice progress Phil; she is looking great.  Well, your next build will have to be Mary Rose then you would replicate the Portsmouth museum ships :)
cheers
Pat
Hi Philip
Looking really good!
BUT...............
I would make a slight change on the propeller, a prop with that shape will give no speed, but only swirl water. If there is a way to make the change, I would. Sorry for beeing late with that!
Regards
Gerhard
Problems just mean: solutions not yet found
Models in progress
SMS DANZIG
http://modelshipworld.com/index.php/topic/12842-sms-danzig-1851-by-gerhardvienna-radio-150-scale/
USS CAIRO
http://modelshipworld.com/index.php/topic/13282-uss-cairo-by-gerhardvienna-live-steam-radio/
Baby Bootlegger 1/10
http://modelshipworld.com/index.php/topic/13625-baby-bootlegger-110-radio-by-gerhardvienna/
Swiss paddlesteamer RIGI 1848 1:50, after plans from the Verkehrshaus Zürich, rescaled to original length
Anchor tugboat BISON, 1:50, plans from VTH, scratch
Finished models
See-Ewer ELBE, Constructo kit 1:48
German fastboat after plans from german Reichskriegsmarine measure unknown (too ugly to show up!)
German traffic boat for battleships WW2, 1:50, after plans from Jürgen Eichardt, scratch
German Schnellboot TIGER P6141 VTH plans, scratch
1 hour ago, Gerhardvienna said:
Hi Philip
BUT...............
Regards
Gerhard
Thanks Gerhard,
I see what you mean. I think the blades should be mounted at 45% to the shaft. I will try and fix but it may not be doable without damage in which case it will have to stay as it is.
Best,
Philip
Hi Philip
Dont PLEASE do any damage to this beauty! If it`s not able to make the change, keep it as it is, better than a smashed ship!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
Hi Phillip and Gerhard,  I would leave them Phil - I am pretty sure she was fitted with a feathering propeller and the pitch would have been close to zero when not needed (such as in port or when under sail alone) - depends on how you would like to depict her.  I had the same problem to contemplate when fitting the prop to 'Victoria" and ended up going for zero pitch as she will no be modelled with sails or underway.  This is just a suggestion - your model,  so please depict her how you wish.
Nice work with the progress you have made, she is really starting to take shape.
cheers
Pat
cheers
Pat
Hi Pat
This would declare why they made it that way. When there was a pitch control, so the "Zero" position will be allright for sailing! Well seen and explained, thank you!
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
OK, Having checked the reference books I have, there was definitely a pitch on the propeller. So I've modified the blades, thankfully with no damage. As a side note, the propeller pitch wasn't adjustable - when the ship was under sail it would be hauled up into the well in the stern. As the model is in steam mode (because the funnels are up) the representation of the propeller is now correct.
Thanks for the input guys!
Best,
Philip
Hi Philip
Well Done! Now the prop looks much better, good job.
Regards
Gerhard
Models in progress
SMS DANZIG
USS CAIRO
Finished models
wonderful progress Philip,  she's look'in really nice! :)    good you were able to change the prop......looks good'n proper ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Nice recovery Phil.  That is a surprise a ship of this era without feathering props :), great that you have good references to check this detail.
cheers
Pat
Very good! The prop... ! How did you got that blueish colour out of the windows?
 is there to be any type of fastenings done to those brackets?   I'm imagining the dead eyes are attached to them. ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
