I'm in the same boat with my attempt at Warspite. Doh!
Hey!  Are you going to post up your Warspite build, it would be interesting to follow :)
OC
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Hey greg,  i'm loving the detail in the hull very sharp, what are you going to do with the anti fouling on the bottom, apply a mat varnish or similar?
OC.
Current builds
Completed works.
I'll probably leave it as is. Given there is no detail, there is very little to work with. I don't want to weather it apart from bringing up detail and leave it as a builders model. Weathering is like being a little bit pregnant, you are or you aren't. This would have been a filthy ship given the times, and to do it properly it would be covered in streaks. Your thoughts?
Greg
Just a bit of lightning with almost like a artists powder white - just to catch the high points and details, but if you are like me I want my hull red around a dull satin colour,   best achieved by buffing a mat sheen I think,  ,  thats my approach with my hull and I would think yours is not far off that.
OC
Current builds
Completed works.
Like I said to the wife - its should be like a metal version of a painted surface - although mat in colour still smooth metal.
OC
Current builds
Completed works.
Looking great, photo-etch certainly brings life to these models.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Looking great greg, really tidy detail work  and clean paintwork :)
OC.
Current builds
Completed works.
Next is off to the flying bridge  post-253-0-22082900-1467529618_thumb.jpg. The first of the guns have to be added, namely 10 12 pounders. The unpainted bits are, from left to right, North Star with the Pontos barrels, then the kit supplied with the Flyhawk barrels (which are 3mm longer, then just the kit one. The kit one is not bad, but just not detailed. post-253-0-09061100-1467529605_thumb.jpgpost-253-0-28094200-1467529616_thumb.jpgThe photo shows the real thing and the upper area of the barrel is almost silver, I tried gunmetal but it was just too dark. post-253-0-50448100-1467529623.jpg
Greg
You don't muck around with these builds do you Greg!  This will be a great looking model.
cheers
Pat
Ok, a heap of photo etch cut and painted off hull, .attachicon.gifhull 31.jpgthen added today. The brackets for the torpedo net booms, multiple side hatches (which for some reason Pontos chose to ignore) and a bit of dry brushing
Looking Great mate - the detail really stands out, Im so missing doing mine as she is packed away upstairs while I'm decorating the house :(
OC.
Current builds
Completed works.
A bit of a re think and the deck has to go down so as not to catch on stuff. A simple exercise? No, after laying the thing down painstakingly, after a few hours the thing keeps popping up in sections. Using a sliver of PE and thin CA over the last few days I have been making running repairs to get the thing to sit properly. Still looks good and makes me happy with the guesstimate of the paint colour.
I have now down up all the boat deck and funnels but will now not paint or attach anything until I have done up the deck hatches.
Greg
The wooden deck looks superb.  Really moving along.
Cheers
Slog
The deck has an adhesive backing, so it "should" just stick on. When I placed it on it stuck, then a couple of hours later it popped up in places, which I rubbed down thinking it needed heat, and a few hours after it kept popping up, thus the thin CA as anything else would leave bulges
Greg
Did you file off the original platic deck boards first before laying the wood laminate?
OC.
Current builds
Completed works.
Looking good Greg, that wooden deck really brings her to life.  Hope you don't have to do too much more corrective action with the CA.
cheers
Pat
No, didn't need to, it sits perfectly flush.
Only asked greg as on my warspite build the original plastic decks had raised planks - you could feel the detail with your fingers, thats why i decided to give the laminate planking a good flat keyed area to stick to.
OC.
Current builds
Completed works.
There are a myriad of deck hatches, and Pontos and Flyhawk both have some gaps in their plans. In particular the engine vents post-253-0-62624300-1468131023_thumb.jpg  that Pontos just chose to ignore. There is a LOT more detail to go on top the decks but this will do for now to save snags.
Greg
