Think it's time to start a new build log :)
As usual first thing is a homemade slipway to keep the keel straight
Glue the two halves of the keel together
There are two strengthening parts to fit to the joint but not yet
Built the slipway first
Keel without the strengthening parts fitted
Keel now square to the slipway
Cut a slot in the slipway to allow the strengthening pieces to be fitted
Right, sit back relax, and enjoy the show. This might be another good one ... Thought you couldn't resist another one ...
Edited by cog
Carl
Hey Bob! I've been keeping an eye out for you to start this one. Hope you don't mind me pulling up a chair to join you. Brought plenty of drinks and snacks for everyone! Looking forward to seeing her come together. :)
"It was a stormy sea that made a Captain out of me."
- Derina Harvey, "Captain" Derina Harvey Band
-E.J.
Current Builds - Vasa - Scratch
                               Royal Louis - Mamoli
                    Royal Caroline - Panart
Looking forward to following another Endeavour build.
Cheers
Slog
_______________________________________________________________________________________________________________
HM Bark Endeavour (First Wood, On Hold)
Borodino (1:200 Card, Current Build)
Admiral Nakhimov (card 1/200)
Mazur D-350 Artillery Tractor (1:25 Card)
F-8 Crusader (1:48 Aircraft, Plastic)
Hi EJ and welcome lots of snacks is just the job :)
I'll watch along if you don't mine, I like the Occre brand kits. Should be better instructions than the Panart.....
Is that another Gun deck in the background ?
Paul V
Hi Paul welcome :)
The instructions are far better than the Panart ones
The gun deck in the background is an almost finished one of the two i built before, as i started the slipway for this build a while ago but i have only just started the log
Right on Bob!! This will be great to watch, looking forward to following along
Last part of the slipway build
Placed the keel in the slot in the slipway and dry fitted the bulkheads
Marked out where the bulkheads cross the slipway
Removed keel and cut slots where the bulkhead markings where
Replaced the keel and made sure bulkheads sat in the slots cut out for them
Checked that the bulkheads were clear of the base of the slipway insuring that they sat all the way down in their slots
Long winded way of doing it but by starting with two long strips and then cutting slots in them i know all the pieces are perfectly in line with each other (nothing like piece of mind before continuing)
You seem to have a fair base to start from Bob.
Keeping a ship in line as you work on her is a must I find.
So nice work matey. :piratetongueor4:
Frank  :piratebo5:
Glad to see you back in business!  Show us how it's done.....
Good to see Bob,
Hope the kit comes with plenty of goodies for your build.
Will be watching out for the updates, I like seeing what others do with the Endeavour builds.
Dave R
Dave R
Measure twice, cut once.
Current Build: HMB Sirius 1786 - Flagship of the First Fleet to Australia (Scratch Build in the Shipyard)
Finished Build: HMB Endeavour 1768
Good to see Bob,
Dave R
Thanks Dave :)
Not too many goodies, in fact one little niggle about the kit is most of it is Lime wood and they tell you to paint it the colour of different woods :huh:
I will take a nose through your log later to see how the kits differ :)
Edited by Cobr@
Thanks for all the comments and likes, greatly appreciated :)
All Bulkheads glued into place
All seems to line up length ways too
Used the straight edge on half the lower deck and marked it out for planking
Lined up the other half of the deck against it by sticking them down together with double sided tape and then transfered the markings across
Carefully removed the two halves from the double sided tape then laid a strip of planks along one edge then fitted and glued both halves to the keel and bulkheads
When it's all dried, deck planking will begin
Planks have been cut to 100mm in length and will be laid in a 5 butt system in a 13524 pattern
Edited by Cobr@
The keel and bulkheads on this kit are only 4mm thick and after fitting the deck, the joints were a little bit flimsy, so i fitted some strengthening pieces to the joints
Lower deck planked and cross beams for the next deck fitted
There was no reason to plank this deck at all as none of it will be seen later, so i used some thinner planking and saved the kit supplied planking in case i need it later in the build
Hi Bob,
Are you planning to add some blocking between the frames to the hull(wales line) ?
Dave R
I am not planning on adding any there. I will leave the final decision until after all the decks are fitted and i can see how rigid it is then :)
