Oh, just clicking the "like" button just isn't enough for this.  I am mightily impressed with your craftsmanship.  I would be so proud if I were able to do this kind of work!  Looking forward to your next updates...  :)
And, stay healthy!
Rob
She looks perfect from here, Jack.   I don't blame you on leaving the supports in place as sometimes our worst fears come true.  Better safe than sorry.
Friday & Saturday, March 17-18, 2017
Some few progress after nearly a month's absence . . A lot of work will be hidden with the bottom timbers :angry:
y4mio-UQ2P0cZzDKdyoYAYsPS0sYLIkbAGZ_ItCI
y4mT4avS70grDSkLDvVQNVZnuTHAz11XMKxuzDPN
y4mnEPtSav05n1WUhZtvfNMBmT-BIuGvzjIabYxv
y4m0joS5rvsamsFbsE-K80GdnuChhmXJ-93ZJVcX
y4mDyNV1V9DjhXc4lt6lRdmTlsjOFzfF_fGfELil
y4mbKhy50Vr-CvHlPQPBvJ-uhgitRrH3dGicTqeL
See you soon, Jack.
Nice work Jack, it's almost sad to see all that beautiful framing being hid
Hello Mr. Jack ... this is a very beautifull build ... When we do with things like this, we just remove the flooring from its positions... So You could do the same... make the flooring and when the model is finished, just put them in the boat, but not at the correct position, this is the way the frames will be exposed. The model will look much more complicated ...
Regards, Zoran
Monday, March 20, 2017
I finished the floor timbers installation . .
In the first three images you can see how all the work done during the installation of the ribs is almost completely hidden. The two numbered floor timbers that you see must be redone because I put the numbering on the wrong side. Just stuff.
y4m9CHzC2_CgF2WjzywhJJjHywBGbiv6PTa-omPu
y4mwCyuS0m5029zCmdc3N7Qfeh-NEjjckw63wXVI
y4mx5-JpiqvFTQJCpmCfQULq5niBXoZeEg6Gbe5q
But I arranged that some timbers of the boat flooring can be removed; in this way it's possible to show, even if in a small way, the underlying work. The removable parts should be, once finished the model, spread properly on the boat bottom.
y4m83GIpQLOCtiXU-2pQgWqcMYae-ONHRIT1s6gc
y4mnQ1p8F9Jp95vaAREzsIyh03A7IBGGBCc-zTA0
y4ml_uZ9smADRmGnvkKF2aEQI-u2hspPBCHqBI0S
y4mFDjZk1lucTyKxpzVv5MYqBgQpHMpoJsvZWSWd
I'm considering whether to treat the bottom with vinegar and iron wool, to make it aged. Similarly I made for the Gokstad viking ship model. I honestly do not know what to do because the only two, maybe three, Gajeta Falkusa existing today are recent replicas and, from their photos, they are beautiful new without any slightest aged area.
What would you think?
Finally a sincere agreement with the comments from Don and Zoran. I really appreciate.
Greetings, Jack.
Looks fantastic from where I sit - I wouldn't change a thing - you have done this great little kit no small amount of justice, but that being said, you are not only the captain but also the owner of the vessel, so do as you wish, and from what I've seen of your work I'm sure it will turn out great...........Steve
I myself would never cover that beautiful wood with anything but a clear finish, but how Steve has said you are the captain.
one idea would be to use transparent wood tint, which would allow all the wood detail to be seen.  But as the other modellers said, you are at the steering wheel.  I'm so glad I signed in to this build log! (this is where I wanted to put a happy emoticon, but did not find them (sad emoticon!))
Wednesday, March 22, 2017
As anticipated, I selected a solution for the floor timbers not requiring aging. So I decided to dye lightly the limewood timbers, in my opinion too white. Accidentally happened that the dye was not uniformly absorbed by the wood and therefore has assumed a barely lived look.
Below I then begun to install additional decks at bow and stern, which are slightly raised above the main one. When finished they will be obviously dyed.
y4mM38Di59VjQA41MDwl9iswrZzn4PpWw-JXTM0F
y4mftUf8luW2Vsqi_QMudSQiALBcEY3qvecHwXsK
y4mfD-SgijDjjoFO52Q-E9_RHbZLWYKg5asI0nBR
y4mzpNL7mdKYS1TSGPn2rySF3bpV0gUaw6t8xC8p
Regards, Jack.
Friday, March 24, 2017
I completed the installation of the prow and poop floor timbers. Here I've also left some timbers removable in order to show the underlying parts.
I've also installed two side stringers.
y4m7dfDioLA13RR4Cjp8s48-uasQRy1McU3MXUYZ
y4mhszu0fcd6JnCzzmQv4P-KuHhbqlF2KZcN_2a3
y4mD83_w2bCspKFYhxZiaCPezsayfwO8DN8lEdcH
Regards, Jack.
Tuesday, March 28, 2017
A new small step forward: I have corrected a blunder that I discovered in the execution of the two floor decks at bow and stern. Now these two "decks" have the right length, 'cause before were too long, although on the plans there aren't the two small lateral extensions which unfortunately I could not totally eliminate.
I hope that the replica shipbuilders will forgive me. For me this detail introduces an aesthetically improved element [cursing] [cursing] [cursing]
Previously I installed, not without some difficulty, the two side counterwales. Unlike the stringer, the engravings on the counterwale are two. Now I became a master in its execution. When the boat will be completed with the so-called "falke", there will be three wales/counterwales per side, two outside of the hull, one inside.
Now it's time to study in deep the assembly instructions in cojunction with the plans to setup a proper planning for the next steps.
They are not so obvious . .
Salutoni, Jack.
y4mhjszw-Tc-o2sBs7hUvWBAOQk0vnKPhotNGgf0
y4mHKTA3fJSMz5p6RldB6sbArK5wci1CScvnzFCg
y4mk83UgI9Mb6pxhIwecuPrYsErsNMbU0BOMDcb9
y4mVvCGfIJFvQ52GMNV5Xz7z4cw5l6EKihnNcyaS
Thursday, March 30, 2017
More details, the job begins to get interesting and fun. Now I'm back for 4/5 days in Milan, I plan to return to Pisa next Tuesday. So do not expect news soon.
y4m34HcmjwTZJ2c6bqEQe5JPFwnF9FiCQlPCuwPH
y4my53eydRcTZAD97dDGHHL7yahP_zyLlE_5pFH0
y4mIMBPtV3M_Flw_0tcVIlgt98L_zU_8CsYLLRQN
y4m_eiFL-8-a9db2XNl9_YHqoo9-LqowD4h5U2iq
y4mmYIg9ex7Gfb_PAoYhXtqOkh0TPRGnPzqkwPPM
y4mIw9pjNdAlBKSF7b1mZ-jR140GuADpbBx7F91G
Hi Jack.
Just stunning work. A pleasure to watch.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Tuesday, April 11, 2017
The work is progressing well, not at high speed, but it goes well and I'm having fun.
Today I finished the two decks at bow and stern and then I better refined the gunwale. I'm glad I guessed the suitable wood for decks. When I was back to Cinisello I did a little research in my personal timber store and found these light walnut strips that make a good contrast with the color of the other boat elements. Those supplied by the kit seemed me too dark for these task.
y4mgqQe_wsZBFI8Mqq23b1-kyvOmikgfBfIG_9yu
y4mvZvKUOEHp-dDqOcxOB0gXHrWhuX44-LFMs8CM
y4m3BZwgb8HF3ZVnRs3CdEwE1G0p3ICukBmYgexE
y4mRvASIcTFymvsnRsPCPaAZH8ApnNrdI5PING9h
y4mbeBnbPqjpMPm1HEOOLOznS-Qvx1mF5IYaGgDa
y4mrLmt6XIOzMOeppsrj1EHH6IorJ1kAurjiBB79
Now I must understand what are the next steps, so I have to study the plans/instructions to decide the correct sequence for installing the other details. However, the date of my return to Cinisello approaches and I definitely will not be able to finish this model in time. I must then decide whether to let him in Pisa waiting to complete it on my return next fall or bring it with me in Cinisello and finish it there, similarly as I did with the Viking ship model.
Should I decide for the latter, of course the other model (Brick de 24) I have in the shipyard at home would still remain idle.
Sincerely yours, Jack.
Thursday and Friday, April 13-14, 2017
At the end I decided to install the seats . . .
There were some difficulties to solve, so I decided to do a test with some unused material. The first difficulty was to bend the strip which constitutes the seat, giving it a humpbacked curvature that was stable and, above all, reproducible in four equal pieces. At the end I opted for bonding two strips held to dry in a jig having per proper shape which gives it, once the glue is dried, an right curve.
Then I had to solve the problem of how to insert the seat in the right place. The following photo shows the solution I found.
y4m19xDQXx_Of12qCfJae8T-LQ5FPC8O4XNWvkVs
Picture 02 shows the method I used to obtain the required shape for the seat.
y4mCp_NfD6H8xyxozlVDyvMTF7Yurftfe4GwqM3H
The remaining images show the final result. I think it's a good achievement . .
y4m-1MEHHHt_VoJvzW-STR7X8_Ksd2x5g__q-b5U
y4ms4J-uw2f4tBQyXI8mWRiCwrasZeYE1rJlV-Cz
y4mInxwm3ZPVQvo8FPvp1QAD2h04yowqIs4pclgY
More significant images will follow soon. Salutoni, Jack.
Monday and Tuesday, April 17/18 2017
It 's time to get myself dirty with brushes and colors . .
More precisely I painted with a matt acrylic white part of the gunwales.
For the first time I experienced the suggestion I received sometime ago from a friend modeler (expert in plastic modelling) that explained me the trick to prevent paint managing to sneak under the masking tape. The trick is to apply a coat of transparent (and matt in this case) paint on the border area between the masking tape and the part to be painted before using the final color paint. This clear paint seals the microscopic cracks that inevitably form . . It works great, thank you rudyf-104.
y4mFE6C5k99zjIN1XQhesr7qbVITX-tuXnLMEaSq
y4movNMBFYSfvx9tKB8tsZ33iY4tZl3NpJcG1Ovy
I have also painted two wood strips in white: these are the wales to be applied immediately below the gunwale. My only problem: I do not know why but the acrylic white covering was poor and I had to apply many coats before obtaining a proper color. Luckily with the hairdryer trick I did not have to wait the paint getting dry between coats.
y4mO6JKWcmNJ2Nw7pxhFI8E6wa7kiEBMhg1PUzRf
Finally I proceeded to color with black acrylic the outer part of the hull, leaving for the moment unpainted the part where the wales will be installed, still to be completed and glued. I will do this task in the coming days.
y4m1rb78g4nf-MUbtoTDFQpJ0AzIKRZ5T4GA8Cls
y4mU67dJHepU-uP2Y4RsVjWxIhC9KzmoUvip3glf
Greetings, Jack.
Wednesday 19 April 2017
I installed the wales on top of the hull, just below the gunwales. Then I had to do some minor adjustments to cover the small damages caused during the gluing of these strips and, finally, a coat of matt transparent paint, or rather, slightly satin.
The real boat is completely polished black, but in a model I think a polished finish is not much suitable, so I opted for a compromise: a satin matt finish.
y4m1lZwHm8K_fODjwD6FzlqRusMV_UIiE94EaFRe
y4mEYyDZ_ui9A-DH9pLBMk7cEfqXW8U9FmPul1Br
y4m9PL5P-vmlZr9s1y55cko0YMJN06WJMEwtEYN1
y4mjF2BRHUNUQLkBXyTVJKj75aqdBUkHWRJ1tuqe
y4mUzq1WdhkzMWnD7XDwahK_ji5Yoi-A87jFm3Ms
y4mlu4rMmFxEq1OpGwwIG0D1Q3koWmkVYPwMjE6Z
y4mQxKPTzZ82IEQuf90A1yL19GZPbzkEK6OQm52p
Regards, Jack.
Thursday 20 April 2017
My stay in Tuscany is now approaching the end: next week I will be to the island of Elba for a short vacation that will allow me to see the island in the spring; people say it's very beautiful. Then again another 15 days and then I will return to Cinisello.
The next important step for completing this model is the construction of the so-called "falke" (I think it is translated in frisate), but for me this is an activity that is still to be understood, so I prefer to delay it when I'll resume work on this model.
So now I'm carrying on small "integrative" activities like the one described below with images. These are tables that are positioned fairly freely, between seats and having different functions . .
y4mKrTwDpjOd_63h-tzxGxED2_c9RDI1XybLoLyU
y4mjWpYXiOPFuKy0bc1svw4cXPGIOMr-Io7pZgvn
Surely an important function is to serve as a table for the food, which is necessary to bring on board as these boats were in the sea from early morning to late evening . .
y4miMBwKS49w8h55dLCPEOVbszQ1IKLsyOF2TIsb
Another usage was to make life a little more comfortable on board, adding more seats . .
y4m0Z_ZlELHFISIANVk2ytcC2g_G9dSAaZOcS0Ar
But, I think, the main function is to allow rowers to do their job, the picture below shows how the rowers work and we can understand that these boards put them in the most suitable position for rowing effectively . .
y4mAccArsAPnyngxpLk4bM_cJJ09rgc-DAtcSwZg
These are details not provided in the kit, but can be seen in the photographs of the real boats, so why  omit them ?
y4mFuPG3B4q2pxuK7BoWU-4NMWTYVg1xWppKzpSc
y4miHiC-7p8qFRNJYmZ1Eizdm4tWr7L93Oz93PiP
To next time, Jack.
