Hello Paul Carruthers,
god luck with your build and enjoy it.
Some years ago I also have modeled this kit. And I must say that it had been a long and very good time to model Pegasus. And if there are question in details its best to look into blue ensigns  build log. It's absolutely perfect.
Cheers Angarfather
Edited by Angarfather
on the : Staatenjacht Utrech
At last finished:
Gianna a Pinco Genovese
HMS Agamemnon
Looks good, those stern extensions caught me until it was pointed out to me. Luckily I only used white glue and ca glue to attach them(real easy to get off :angry:  ;) ). Look forward to seeing more, supports for that plywood decking is a real good idea.
The ply so far is good,
I used the rear deck ply to align the stern extensions.
The mdf is also very easy to work.
Commenced planking of the deck, still to scrape and tidy up
My first model was Cruiser by Caldercraft, a bigger model, I hope I can get my hands in to Pegasus as it gets more complex.
Is there a good source for strip wood in the UK?
Edited by paul carruthers
Thanks, yes the strip for both primary and secondary planking looks good..
Re the deck, I'm just doing straight planking, my next one might get more ambitious.
Will need the exchange rate to improve before branching out to replacing kit wood supplied.
the tops of bulkheads 5, 6, and 7 are removed after the plywood side pieces  are installed and first planking is finished. You may want to remove the planking around these bulkhead tops now and finish it after these bulkhead tops are cut off. Other than that it looks good
Nice work Paul, and welcome to the Swan Class brotherhood :)  The Pegasus is a really wonderful kit as I'm sure you're finding.  BE's log is the gold standard that we all follow.
For my gunport patterns, I soaked and pinned only twice.  I found that it reverted a lot after the first soaking.  The key is just to relax the fibers and make sure that everything lines up properly.  Spy has some really good notes and suggestions on placement - particularly regarding the jigsaw connection.  I forget if it's forward or behind where the kit diagrams show it.  Don't worry too because you can sand back the ply, and since the hull is double planked, you can use filler, etc.  It's a pain, but not too bad in the end (the patterns do make things easier than had the kit required you to actually frame the bulwarks, which is what I'm going through on my Morgan).  Just take your time and you'll be fine.
Just bought a few extra clamps, first one being glued up today after dry fitting and matching port and stbrd . Fingers crossed the good advice and prep wins the day. Pics to follow as I've my 4 year old grandson until the weekend
