The model is made in 1/65 scale so I have adopted a full hull system.
Glue the ordinateho filled with foam and then grouted with fiberglass filler
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
La Jacinthe French Schooner
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Bisquine La Granvillaise
Fishing-boat
English pinnace
18th Century Longboat
I covered with thin planking in walnut for the painted part, and in boxwood for the visible part
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Stern details and sculptures
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Support for the base.
Made the wooden columns on the lathe, I created a silicone mold, and then made with liquid metal the final columns
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Construction of the lifeboat
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Copper sheet cover:
I took the 8 mm adhesive copper, I made a brass shape with guides to cut the shape of the rivets.
The rivets are engraved with two toothed wheels of different sizes for the edges and for the central part.
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Aging of copper.
I wanted to give an antique effect with the copper green patina, treating the surface with a product to create the green patina.
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Kitchen and other details of the bridge
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Base of the model
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Before tree mounting
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
  • 2 months later...
Construction of the bowsprit
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
Almost over .....
Next week the Plexiglas case arrives and the flags are mounted
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
5 hours ago, Landlubber Mike said:
Really beautiful work!  I like how your copper plating came out.  Can I ask what you used to achieve that effect?
I used this product purchased on e-bay:
Green / White (Tiffany Green) Patina Solution, Copper, Brass
https://www.ebay.it/itm/Green-White-Tiffany-Green-Patina-Solution-Copper-Brass-etc-15-30-45ml-/262953186904
I did some pieces of copper before testing.
You have to do different applications with the brush and when it is still wet, clean the surface with a damp cloth.
The liquid is a bit irritating, you must use a mask and use it in an airy environment.
Current build
Enterprize
Schifetto
Completed builds:
LA BELLE
Cherful
Tartana Gemma
Carmenia
Salvatore Padre
Tartana Gemma
Fishing-boat
English pinnace
  • 2 years later...
On 1/4/2018 at 4:51 PM, iosto said:
Aging of copper.
Your patina is looking tremendous. What did you used to get this effect?
Cheers,
Daniel
In dockyard: HM Colonial Schooner for Port Jackson (scratch), HM Armed Vessel Bounty, HM Cutter Sherbourne
Next builds: HMS Victor 1797 & Gannet 1814 Cruiser class sloops, ship and brig rigged (scratch)
