What is the best spindle sander for ship modelling?  I'm talking bout a dedicate sander, not a set-up for a driil press or mototool.
            Thanks, Walt Haynes
There are several that can suit your needs.  The choice will probably come down to the space that is available in your bench or work space. I prefer this one because it is more versatile, and has a large table that allows for construction of fixtures and jigs.  But for small work, a benchtop drill press is also a versatile machine that shouldn't be discounted.
Ridgid ZREB4424 3/8 HP Oscillating Edge Belt/Spindle Sander
https://www.cpooutlets.com/factory-reconditioned-ridgid-zreb4424-3-8-hp-oscillating-edge-belt-spindle-sander/rgdrzreb4424,default,pd.html?ref=pla&zmam=31282435&zmas=47&zmac=722&zmap=rgdrzreb4424&gclid=EAIaIQobChMIqbOgwLbO2QIVibXACh3WAQMiEAQYASABEgIHtvD_BwE
Grizzly tools has a small oscillating sander for hand or bench use.   I was thinking of making a thickness sander with it.  Seems to be well made (not a toy).  Reasonable price and doesn't take up much space.
Grizzly Tools;Oscillating-Spindle-Sander/T27961
Bruce
Stay Sharp - Stay Safe
Judgement comes from experience:  experience comes from poor judgement.
  • USS Constitution: Scratch build solid hull 1:96 scale
That's an interesting tool for modelers who have with limited work space.  You could stack up some MDF pieces to make use of the entire length of the cylinder.
Edited by Bob Blarney
First, an editorial comment on Net inquiry for the "Best" of anything. I don't know about best, since the best of all poor choices is still poor.
I think "excellent" and "quality" would be better goals.
As for a spindle sander, I made my own.  It is not the less expensive option since the motor
came dear, but to get the features I wanted, it was required.
There is no oscillation - but I see no advantage to that action.  The zero bend is the only one where
the table can be used for a finished shape - the bevels require a tilt of the work piece and that
angle changes continuously.  A drum moving up/down would make that more difficult to control.
Dayton 1/3 HP,  1700 rpm   - powerful enough and the right speed for sanding.
ball bearing - there is a lot of lateral force on the shaft doing this.
closed case internal cooling fan  -  a lot of wood dust produced  -  but I have mitigated that with a 1/8" hard board barrier right above the motor.
Reversible motor -  the upper ends of frames respond better to pulling sanding than pushing  - figuring out the wiring for the switch was interesting.
The maintained reversible drum switch was not cheap either.
1/2" shaft -- I prefer sleeveless drums - the Norton sheets 9 x 11 are not expensive and are easy to get.  Compressible sleeve drums sometimes get out of round.
The drums are generally 3" high in a variety of diameters -  After I friction melted the rubber substrate on the smallest one - the steel base makes that one ~ 3/8" dia.
The widest diameter is 3", but that one also has 4 1/2" high ( which was a waste - out of round- and not different enough from 3" ) and a 6" high version ( great -
especially for the frames of the 1:60 first rate I am working on.
With a bare 1/2" shaft,  Other tools can be mounted.
Another part of the design - the base mounting the motor and holding the table is open on the front and back has large rubber stoppers for feet - both for vibration
mitigation and for air flow since I cut a hole about the diameter of the motor in the bottom piece.  If you work for a while, there is heat with the motor.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
-no oscillation means that the sanding drum will wear in a small fraction of the drum
moving up, down or stationary  are all the same to control; easy
  • 4 months later...
I realize the inquiry was about a "dedicated spindle sander, not a drill press or moto tool," but I have to say that IMHO a "dedicated spindle sander" for modeling is really one of those things (if such truly exists) that is overkill. I agree with Jager that there's no point to oscillation. This is primarily because nobody is going to be hogging off large blocks of wood when modeling and, if one operates the sander properly, there should be little or no wood clogging or undue abrasive wear. (I.e.: let the sander do the work and don't press the work hard into the drum.)
I have used a Delta drum sanding kit designed for use in a drill press for years and have been entirely satisfied with it. (Again, the Morse taper of a drill press chuck isn't designed to take lateral force, but this isn't a problem if little lateral force is applied with the work piece, as is proper.) A used bench top drill press is easy to come by on Craigslist or a garage sale for relatively little money and if used as a dedicated drum sander, it can always double as a back-up drill press. If you already have a drill press, so much the better.
Using hole saws, I have cut a selection of holes to match the size of the drums from 1" plywood. I've also cut a couple extra with holes to fit the largest drum. By stacking up these "zero clearance inserts" (the big ones beneath the smaller holed ones, as needed) clamped to the table and adjusting the quill and setting that as convenient, I can always move the abrasive area exposed as needed to always have an unworn section of abrasive presented to the work piece. A crepe rubber abrasive cleaner used as needed ensures that the abrasive doesn't wear prematurely.
I have a plastic tube that fits my shop-vac hose and has a rare earth magnet epoxied onto it.  This tube holds the hose beneath the center of the drill press table top and pretty much sucks most of the sawdust away from down below.
It's really no more trouble than chucking a drill bit into the chuck and sticking my shop-vac hose to the bottom of the drill press table, so my drill press not being "dedicated" to sanding has never been an issue for me.
It's a stock Home Despot item for forty bucks: https://www.homedepot.com/p/Delta-Sanding-Drum-Set-25-Pieces-17-940/203293688  Harbor Freight has them for twenty-seven bucks less the abrasive sleeves: https://www.harborfreight.com/4-piece-quick-change-sanding-drum-set-35455.html  Horror Fright has the crepe abrasive cleaners for eight bucks, too: https://www.harborfreight.com/sanding-belt-cleaner-30766.html
Just sayin'. Your mileage may vary.
delta-bench-stationary-tool-accessories-
Edited by Bob Cleek
  • 4 years later...
1 hour ago, No Idea said:
I’m waiting for Jim Byrnes to make one
I emailed him with the suggestion several years ago.  There was no response.  His stock 1/3 HP CW/CCW motor was my inspiration for my contraption.
2 hours ago, modeller_masa said:
The variable speed dial is from 1 to 6. It seems solid enough for a scratch building.
A steady 1700 RPM is probably all that we need.
The portable has a few downsides from my perspective.
The motor looks to be a bit under powered.  I would bet on a burn up if worked hard and frequent stalling if the job is significant.
The media is sleeves - which is more monopoly as far as source and a limited choice of grit.
The mount is proprietary.
A significant length of the media surface is sequestered.  You can flip the sleeve, but in any case, the length available is less than the whole.
A 3" diameter drum is my favorite.  The 6" length surface unit works best for larger scale and big vessels.
As far as the dust collection setup,  I would expect more dust will be thrown than will drop.
Edited by Jaager
NRG member 50 years
Current:
NMS
Other
No table to hold the wood being sanded?
My Proxxon mill does a nice job impersonating a spindle sander. The variable speed is necessary from my perspective.
Regards,
Glenn
Current Build: HM Flirt
For jobs where the surface being worked is 90 degrees - like the easy way to do deck beams or a stem - a table is good to have.   For sanding a group of 6-8 frames between any two stations - a table just gets in the way.
Where wanting to go slower than 1700 RPM may be an impulse, I find using a finer grit works better.
NRG member 50 years
Current:
NMS
Other
I don't know the RPM at the maximum speed. According to the manual, the maximum power consumption is 650W and it is quite loud at 6 speed level.
I found replacement sanding sleeves at 60, 80, 120, 240 grits. There are more grit choices at 1/8 shank, but it is useless for the spindle sander that oscillates sanding drum.
I'll make a zero insert plate and hold it with two M5 screws. Someone may make a work table like the trimmer table.
Probably the best tool , which has a 6" oscillating drum, starts at $150, so the $55 miniature spindle sander attracted me. I may need to buy 240 grit sleeves for a better result.
