Thanks Robbyn gonna put the keel on after I sand the first plank layer down.
I hope not to oversand Adriaan looks worse than it is I hope lol
Thanks Sjors, not sure i believe you that it's better than yours.........yours really came out great, was an influence in me getting into this :) :)
So more house projects and having to work a few days may set the sanding back a few days....but hope to be back at it soon
All comments welcome :) :)
David     :pirate41:
First Build: Corsair Brigantine
She's looking good David, nice planking work. I'm not very familiar with Occre kits, but I would reckon it would be better to add the keel now to avoid any possible gaps in the second planking.
Best regards,
Aldo
Currently Building:
HMS Pegasus (Victory Models)-Mothballed to give priority to Triton
HMS Triton (first attempt at scratchbuilding)
Past build:
HM Brig Badger (Caldercraft), HM Brig Cruizer, HM Schooner Ballahoo
Kieth I am going to tape down the sandpaper like you did when I do the keel thanks.
Thanks Aldo I am going to put keel on after sanding first layer.
Hello Adam and welcome to my build........I will take any advice you feel like like sharing lol .
David     :pirate41:
I agree with adding the keel plates before starting the second layer. I've done that with all my builds, and it works great!
Adam
Current build : http://modelshipworld.com/index.php?/topic/6891-us-brig-syren-by-spiderpig-model-shipways-scale-164-1803/#entry202979
                       Mare Nostrum
Past builds : Artesania Latina Virginia 1819, Occre Corsair Bridgantine, Constructo HMS Prince
Hi David
As you gave your time to visit me I thought I would have a look to see where you lived
So I came over, found the back door open and wandered in  :piratetongueor4:
I got a seat at the back as the place looks pretty full
If I could just get Adriaan and Sjors to pass some popcorn and beer back to me I will settle in  :cheers:
I have read through your log, agonised over your problems and cheered your successes
As you can see I have built a few OcCre models
Often I have looked at the instructions and thought "Do that NOW!!!!"  or  "Surely I should do that first"  :o
A particular point with the Endeavour was indeed the keel
I was told to stick it on when all the planking was done
I thought "But there's not a lot there to plank to, how am I going to get a nice finish"
So I stuck it on after the first planking so I had something to plank squarely to
Also just to add to the debate about glue, I use PVA wherever possible and only revert to CA medium or thick when absolutely necessary
Thing is with PVA it reacts much less with stain or paint whereas CA just seems to react with everything and does not take kindly to gluing prestained wood
Ok that's my bit for now
I will just sit here at the back and keep an eye on things, although it does look as if you have gotten over your probs and are now doing very well  :D
Keep it up  :10_1_10:
Mick
<p><strong><span style="font-family:'times new roman', times, serif;"><span style="font-size:18px;">Keep it up :10_1_10:</span></span><span style="font-size:18px;font-family:'times new roman', times, serif;"> </span></strong></p>
<p><strong><span style="font-size:18px;font-family:'times new roman', times, serif;">Mick</span></strong></p>
<p> </p>
<p><span style="font-size:12px;"><span style="font-family:'times new roman', times, serif;">Current Build --- Will Everard --- </span><a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/'>http://modelshipworld.com/index.php?/topic/3636-will-everard-by-micklen32-billing-boats-167/</a></span></p>
<p><span style="font-size:12px;">Current Build --- Endeavour --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/'>http://modelshipworld.com/index.php?/topic/2804-hmb-endeavour-by-micklen32-occre-154/</a></span></p>
<p> </p>
<p><span style="font-size:12px;">Completed --- Guitar --- <a data-ipb='nomediaparse' href='http://micksjem.blogspot.co.uk/'>http://micksjem.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- Barcelona Taxi --- <a data-ipb='nomediaparse' href='http://micklen-taxi.blogspot.co.uk/'>http://micklen-taxi.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- London Tram --- <a data-ipb='nomediaparse' href='http://micklen-tram.blogspot.co.uk/'>http://micklen-tram.blogspot.co.uk/</a></span></p>
<p><span style="font-size:12px;">Completed --- OcCre Mississippi --- <a data-ipb='nomediaparse' href='http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/'>http://modelshipworld.com/index.php?/topic/1803-spirit-of-mississippi-by-micklen32-occre-180-a-hopefully-accurate-rendition/</a></span>
No updates as I have been working 6 out of 9 days so far, and since I work 24 hour shifts at the firehouse, that has not left me a lot of time :) :)
And we have to assume that taking the kit with you is not an option  :P  :P  :P
<p> </p>
<p> </p>
I might suggest you take a short break......I usually do this after a major sanding operation.  Then, take one more look and decide if you want to spend a little more time filling/sanding.  Keep 2 things in mind:
Any irregularities in the flow of the hull planks at this point will only be accentuated during the second planking.
Too much sanding and you'll actually sand through the first layer of planking.
Once you make your decision to proceed. either glue will work.  Wood glue, PVA, gives you more time to position your planks and cleans up easily with water or alcohol.  It also sands out well.  But it does take time to set.  CA is fast but can be unforgiving and does NOT sand well so keep it under control.  I actually use both....not trying to confuse you, just being honest.
Whatever you decide, take your time and treat each plank as a mini project.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
On the Endeavour I used contact adhesive for the first time and I found that worked very well indeed
As Augie says there are problems with both PVA and CA
I have to admit I tend to err towards the PVA as it is much easier to keep under control
A mistake can be fairly easily cleaned up
CA is, as Augie says, a pig to get rid of if it gets on a finished surface
Firstly do as Augie says and take a close look at the hull and see if it does need a bit of sanding, filing, scraping in places
Then I would advise giving contact adhesive a go
Use a tube as a can will soon start going stiff with too much exposure to the air as it gets down the can a bit
A very thin coat on the two surfaces
Leave until tackiness goes, anything from 5 to 15 minutes, maybe even more
Press together firmly and roll it if you have a small wallpaper roller or similar
Failing that find a smooth rounded edge of something, knife handle etc, and rub over it to settle it perfectly
It bonds very well but does give you a chance for minor adjustment, also being by far the cleanest of the three as if you are careful it only goes where you put it and as there is no liquid there is nothing to squidge out
But as Augie says, using PVA as the main glue and just a spot or two of CA to hold the plank in place as the PVA goes off is a fair way of proceeding
Have a play with the glues, see which you prefer
The big negative about using purely CA is that it dries very hard and brittle with no give
I hope that helps a bit David
Good luck
P.S.
What Augie says last of all is vitally important
Edited by Micklen32
<p> </p>
<p> </p>
Working again but will look at it closer when I get home.........I have to cut gun ports and put keel parts on before second plank also.
Thanks for advice :) :) :)
Edited by DCIronfist
David     :pirate41:
She's looking good David, looking forward to the second planking, perhaps you could use a very small amount of CA for the tip of the plank to get it to bite initially then use PVA for the rest of the plank  :)
Best regards,
Aldo
Currently Building:
Past build:
Coming along nicely David!!!
-Adam
-Adam
Current Builds
Santa Maria - Artesania Latina (1:65) POB
MayFlower - Model Shipways (5/32"=1') POB
Blue Shadow - Mamoli Revolutionary War Brigantine. (Fict) (1:64) POB (Recommissioned as the Kara June)
On The Shelf Waiting so Patiently
USRC Ranger - Corel (1:50) POB
18th Century Longboat - Model Shipways (1:4) POF
La Nina - Artesania Latina (1:65) POB
U.S Brig Syren - Model Shipways (1:64) POB
Completed Builds
Phantom NY Pilot Boat - Model Shipways (1:96) Solid Hull
Decommissioned Builds
(Time and conditions were not good to these. They have been cancelled =( )
Willie L Bennett - Model Shipways (1:32) POF
USRC Harriet Lane - Model Shipways (1:128) Solid Hull
Ok so cut out the gun ports ( harder than I thought) painted them black on the inside......added the keel...........and lined the stern galleries.......I did get some bleed through wth the paint any ideas to make it look better? My wife says leave and I'm trying o be too perfect with it........thanks for lookingpost-3113-0-92191000-1380903580_thumb.jpgpost-3113-0-97862600-1380903609_thumb.jpg
David     :pirate41:
Hi David,
Nice progress !
And then for the bleed.
For the outside it doesn't matter because you have to plank over it.
For the inner side of the bulwark…get some thin planking, a little darker or the same colour as the hull, and plank the bulwark !
Then you don't see a thing anymore.
If the paint is acrylic you can sometimes clean it up a bit with a q-tip and a little bit of alcohol and a light sand.  If not - Sjors is the man! Dead on... and nice job!!!
-Adam
-Adam
Current Builds
Completed Builds
I agree with Sjors as well David
That's a good way to do it
The gun ports look great
The build is coming along very nicely
<p> </p>
<p> </p>
The bleed through is common, any of the above fixes should do the job for you. Build is progressing well David, the fun stuff is coming!
Robbyn
If you risk nothing, you risk everything!
Current builds
Syren (Model Shipways) version 2.0
AL San Francisco II
Mordaunt (Euro Model)
Completed Builds
18th Century Longboat designed by Chuck Passaro
In the closet
Battle Station
Al Charles Morgan (1980s version)
Bad news........it seems my wife suspects this build is the reason to a reaction she had.....gonna take time off and try to eliminate the problem. If not it may not be good news for finishing........it may be some time before I have an update.........
David     :pirate41:
Sorry to heaer that Dave,  I know some paints and solvents can have wicked effects on some people - so it can be harsh, especially during winter when ventilation gets scarce.
Good luck to you both, hope the reaction is to something easy like that to take care of.
-Adam
Current Builds
Completed Builds
Really sorry to hear that David.  Probably either CA fumes or sanding dust.  Hope you two can work it out.
Augie
Previous Builds :
What a great shame for you both David
I hope you do get it sorted
<p> </p>
<p> </p>
