Family issues have kept me out of the shop but I may be able to sneak in a couple of hours tomorrow morning. Since I already have the strake laid out I'm going to un-clamp them half at a time and glue and clamp one end then the other. That way I never loose it's position. At least that's my plan. We'll see how it works in practice.
Edited by alde
The heart is happiest when the head and the hands work together.
Al
Current Builds:
HMS Halifax 1/48 POF Lumberyard Kit
Model Shipways Glad Tidings
Acoustic Guitar Build FINISHED
I nearing the end of the external planking and it’s ok except for one error. I started the planking too far away from the keel so it’s all about 1/4” or so too high. I don’t think it will cause any major problems but the stern carving won’t be able to go on until it’s off the building jig. I’ll do the obligatory aircraft carrier picture soon. That’s seems to be a requirement of a Hahn style build.
Al
Current Builds:
Nice progress and looking very nice Al
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Looking good Al.
Able bodied seaman, subject to the requirements of the service.
"I may very well sink, but I'm damned if I'll Strike!" JPJ
My Pacific Northwest Discovery Series:
On the slipways in the lumberyard
Union, 1792 - 1:48 scale - POF Scratch build
18th Century Longboat - circa 1790 as used in the PNW fur trade - FINISHED
Future Builds (Wish List)
Columbia Redidiva, 1787
HM Armed Tender Chatham, 1788
HMS Discovery, 1789 Captain Vancouver
Santiago, 1775 - Spanish Frigate of Explorer Bruno de Hezeta
Lady Washington, 1787 - Original Sloop Rig
35 minutes ago, rafine said:
She's looking great Al. Almost ready to cut her loose from the jig.
Bob
Thanks Bob. It's gonna be a little stressful but I'm looking forward to cutting it loose
Al
Current Builds:
2 hours ago, alde said:
measure twice cut once is so true
Alde,
It's going to be a thing of beauty! Sadly I still have to cut twice because I only measured once. Have the pile of miscues to prove it.
John Allen
Current builds HMS Victory-Mamoli
On deck
USS Tecumseh, CSS Hunley scratch build, Double hull Polynesian canoe (Holakea) scratch build
Finished
Waka Taua Maori War Canoe, Armed Launch-Panart, Diligence English Revenue Cutter-Marine  Model Co.
Some of the mistakes will be easy to avoid next time.
You are probably better than me. I am perfectly able to make the same mistake over and over again.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Looks good from here, Al.  It was (to me anyway) a very tense time cutting the hull loose, keeping it supported so not to break the frames and generally not making a mess of things.  One bit of advice given to me was "cut long" and adjust the frame heights after it's free as it's hard to cut accurately in the position it's in
Bob
Al
Current Builds:
I appreciate that Mark. I think the camera hides some of the flaws. I think I should be able to compensate for starting the planking too far from the keel with no problems. The only thing that may cause trouble is where the bowsprite exists the hull. Everything else should be fine.
I think I'll build some of the internal structure before I cut it loose. I really don't want it to fall apart though it seems pretty strong.
Edited by alde
Al
Current Builds:
Al, I think it would be better and certainly easier to work on the interior after the hull is free of the jig. The hull should be quite strong with all of the planking on. I didn't even fair the interior until after I cut it loose. There was no problem.
Bob
Bob
Thanks Bob. I'll plank up the stern and cut her loose.
Al
Current Builds:
6 hours ago, Sjors said:
Your a brave man Al when you are try something like this....
But it looks great !
Sjors
Thank you Sjors. I wish my abilities were more up to it. Maybe after a few more years of practice the quality will improve a bit.
Al
Current Builds:
Alde,
You have to have the faith my brother, with something that looks that good Karma is on your side. Close one eye, turn your head slightly to the side squint threw the other eye and slowly cut away!
Not that I am all knowledgeable but it looks like you have enough planking in place to hold all together.
John Allen
On deck
Finished
If a Dremel counts as a chainsaw, then “yes” :D
What size chainsaw?
Do you think that might be a bit of overkill?
Might need a 24". Looks like a lot of lumber to get through to me!
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Sorry Al, the best I can do on short notice is a little dog that chews on anything!
Edited by lmagna
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
I told you guys about my problem with starting the planking too far from the keel or maybe using planks that are too wide. In any case my biggest problem is the stern. The picture shows where the casting should go but the as you can see the planking is much too high.
The way I see it there are two things I can do. First is redo the planking by ripping it all off and starting over. The second is to build my own stern decorations and windows with elongated windows or more empty space between the windows and carvings. Do you guys see any other choices or have any suggestions?
Al
Current Builds:
Al,
I guess I don't understand the issue.  Here's a pic of the stern of the Halifax
Under the windows are some decorative molding strips and counter planking.  Also, look at where the stern post enters under the windows on the counter.  It looks fairly close to what you have.  The wales seem to end in about the same place as well.  What am I missing?
If you are talking about the planking above the decorative stern, it looks like the model has an open rail aft on the quarterdeck and you planked the rail.  Is that it?
The more I look at your planking, the more I think you have your sheer rail in the wrong spot along with your planks too wide.  Look at where the planks and rails terminate at the transom compared to yours.  The Wales look OK and the decorative resin stern piece could possibly move up towards the taffrail slightly but the other planking and rails seem to be out of place.
I'd get some more opinions first, but if that is the case you will need to remove the planking above the wales and reset the sheer and re-plank with correct width planking.
Edited by Dowmer
17 minutes ago, Dowmer said:
Al,
You are seeing what I'm seeing. The more I look at it and think about it I will have to take everything off down to the wales as you suggest. I am taking this model as a learning tool anyway so may as well make corrections and do it as best I can.
Al
Current Builds:
I went ahead and did it. I ripped off the planking to the wales. I could have faked it and made it look OK but it just would not have been right. This time I'll think a few moves ahead before I redo it and lay it out correctly. I know I would never be happy with it the way it was. It will probably take a couple of days before it's cleaned up enough to lay in some planks. It was a tough decision but I know I'll be glad I did it.
Al
Current Builds:
