Evening all,   I decided to use a little artistic license  and have a go at lightening the bottom area that would have been in the sea more than above esp, when not submerged,   firstly I masked off an area on both sides then I hand painted with some admiralty medium sea grey, then when dry i rubbed the paint slightly to blend it in,  after I will dry brush slightly to blend the two colors better.
Next off will be a bit of weathering with some green to simulate algea.
OC.
Current builds
Completed works.
Revell  1/48  Mosquito  B IV
Eduard  1/48  Spitfire IX
Algae is an interesting idea OC
I kind of wonder if these ships are prone to stuff like that? First I am almost certain that they use a paint that has some anti fouling properties and secondly they never stop moving while at sea. You know, the "Rolling stone gathers no moss" Theory.
Still and interesting concept though.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Still and interesting concept though. d her
Have a look at the photo of her in dry dock lou,  it shows the weathering including what looks like algea around her bow and along her waterline, and a fading affect lower down.
OC.
Current builds
Completed works.
I was a little concerned about your method........there were some paint scratches that went a little too deep.   in light of what you've done here......she looks pretty darn good now  :)   I wonder what those green areas are all about?!?!....part of that plating perhaps?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Thank you denis,   its always more difficult hand painting a smooth surface with no details to break the flow of paint up,  and no matter how good my brush tech  might be over the years, I just cant get the finish how I want it,  so - as I dont want to start it all over again and have to invest in a few rattle cans,  I have decided it will have to be a gap filler and be a bit rough round the edges.
OC.
Current builds
Completed works.
Those areas were so uniform that I suppose I just mentally wrote them up as a green primer. I suppose you are right and they are just areas of the lower hull that have not been cleaned as thoroughly as the rest of the hull yet.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Hello all,   I have stalled with my sub as I have decided a change of plan,    I am going to re do the whole paint scheme,   I will have to wait till I can order some Tamiya Acrylic Nato Black in spray can form.
I think that will be the better option all round, as Naoto Black is a kind of bleached blue grey shade of black, also with it being aprayed it will give a Much much smoother finish.
Just need to wait till I can get the paint, then It will be back on (mind you I can put the few odds and sods on it first after I have given it a good rub down with soapy water)
OC.
Current builds
Completed works.
7 minutes ago, cog said:
Gawd, that sub must be the cleanest in the fleet OC ... and spoiled rooten for all the rubbin' she's gotten so far!!
Im just not happy with the brush painting way she has turned out,   some times you just cant get without needing to use a rattle can.:huh:
OC.
Current builds
Completed works.
I dunno.......I think you should stick with it.  we haven't seen the full treatment yet ;)    you may have hit onto something by water lining her.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
1 hour ago, GrandpaPhil said:
The last time I painted a sub, I base coated it with Ceramcoat black and then dry brushed a thin coat of a dark charcoal gray, also Ceramcoat.
Thank you for that,   not the easiest of things to paint (by hand)
OC.
Current builds
Completed works.
Perhaps,   just not sure to be honest.
OC.
Current builds
Completed works.
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
OC,
i have been looking for a decent photo, this is perhaps the best i have seen, (NOT MY PHOT) taken from a FB page, perhaps best that i deface the mooning
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
6 hours ago, Kevin said:
OC,
Thank you for finding those for me kevin.
OC.
Current builds
Completed works.
I have ordered my paint  - Tamiya Acrylic rattle can.
Also we had a day in the sun on the patio, so I brought my HMS Greyhound out for a swim.
Thank You sincerley for all the comments and likes - it sure makes building this tube  more enjoyable.
OC.
Current builds
Completed works.
Nice looking frigate as well but shouldn't she have a little more ocean?
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
She was on sea trials lou,  thought I better try something shallow incase she sank,  all the crew are still on shore leave  and quite drunk  too much rum.
OC.
Current builds
Completed works.
When I tried to put my 18th Century Longboat thru sea trials, the glue dissolved and almost all of the planks popped off the frames  !
Nice looking frigate, OC, glad she passed the first phase of her sea trials unscathed. ;)
Jack
Current buildUS Constellation
Thanks jack.
OC.
Current builds
Completed works.
15 hours ago, cog said:
Turning HMS Greyhound into a sub?
That might be an idea,  not sure how watertight it would be though.
OC.
Current builds
Completed works.
Look what turned up in the post today - funny thing is  I never ordered it (must have a farther god mother):dancetl6:
OC.
Current builds
Completed works.
I gave her a rub down with some fine wet and dry  and running water,  I just need to fit the rear horiz stabs and a few bits on the hull, then the PE  I received,   all in preperation for the rattle can I am expecting in the post.
OC.
Current builds
Completed works.
Hi OC
Other than around the bow, isn't this the look you were trying to achieve? The streaked multi color more worn sides? Just wondering.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
29 minutes ago, lmagna said:
Hi OC
I decided to give her a  "out of refit" condition with some slight weathering but a general overall color condition.
The Nato Black  have ordered is a Grey-Black color so it should look a lot better, and a rattle can to give a nice smooth finish.
OC.
Current builds
Completed works.
More progress today  -  I seperated some of the pe parts and managed to loose one of them (as you do)  these were the hatches,  so I managed to fix in place two hatches and two accessnt  hatches,  these needed a slight bend to fit them to the profile of the top/side of the hull,  I also fitted the top  device infrot of the sail (not sute what it does),   then two side hull covers were fitted - these have a slight opening at the rear.
After finishing off the hull details  I worked on the rear section containing the Stern Planes, water propeller  system and cover.
After fitting these components I gave the inside of the cover and prop blades a coat of brass paint.
So this is the stage I am at sofar - next will be to crate a handle(stick) to hold the sub while I giver her and overall spray as my Nato Black has arrived.
Thank you for all the views/likes and of course everyones imput.:cheers:
OC.
Current builds
Completed works.
