I hate making tree-nails. To me it is the most tedious job there is, but they look so good that I tree-nail everything. I tried using thorns from a locust tree but I did not think they looked as good. So I will sit today watching sports and pulling little pieces of bamboo through my draw plate. Making blocks or pieces for gun carriages can be repetitive, but in the end you get something to look at other than a thin piece of wood that is just skinnier than when you started. Oh well, the game is coming on so it is back to my draw plate. Thanks for listening. What do you hate?
Then you are making them wrong.
A couple years ago when I was more active in my local club, I would help man the ship modeling both at the County Faire.  One of my mates would demonstrate making treenails with a drawplate, making his length of 'nails' increasingly smaller.  As he got down to about 1MM and showed everybody his creation (ooooo ahhhhhh) I would chuck up a inch or 2 of bamboo in the ol' Dremel and whip at an inch of 1MM treenail in under  a minute with a piece of fine sand paper.:P
Good quality bamboo is strong for is size.  I use BBQ skewers, but you have to make sure you get good ones.  It takes some practice and is prone to burnngfingers if not careful, but they are great.  I use hem to affix small furniture items to the deck.
Edited by Chuck Seiler
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Now that is something I had not considered. MUCH better than metal pins in my opinion.
Thanks for the tip Chuck
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
There's a couple of other ways for mass producing them. It all depends on scale of the ship and how visible you want then,
1) One way I'm seeing is to drill the holes and then fill the hole with wood putty of the color you want to use, matching or contrasting.  Let dry and then sand.
2) Another way is toothpicks.  stick them in the hole with small bit of glue.  When dry, cut the toothpick as close to the hull as you can get.  A light sanding is next.
3) Some just mark them on the plank with a pencil.
4) Have a look here also shows a different method for mass producing using a mill or drill press.
1 mm is easy with Byrnes draw plate but I have found that for a 1:64 scale model, 0.5 mm is more to scale. When drawing bamboo down to this size it I have found it does get tedious and fiddly.
Hornet
             Current Build: - USRC Harriet Lane - Model Expo.
             Completed Ship Builds:   Vanguard - HMS Adder, OcCre - Shackleton’s Endurance
             Caldercraft - HM Bark EndeavourHMAV Bounty HM Brig Supply
             Aeropiccola - Golden Hind, Constitution
              Scientific -  Clipper Seawitch.     Corel - Victory
              Modeller's Shipyard - A Schooner of Port JacksonBrig `Perseverance'    Cutter `Mermaid'
               Sirius Longboat (bashed Sloop Norfolk
I use a Byrnes draw plate. I work in 1/48 scale and go down to a 28 or 26 on the plate which I like the look of. I use a #72 drill bit and this is about .4mm. I don't think a Dremel would work for me at this scale since getting them uniform without breaking would be tough. I like wood tree-nails over the alternatives some of which I've tried. My comment was written with humor in mind. I've done thousands of tree-nails and knocked out a bunch today. It's just that when you are on your 10th or 11th piece, you have to be saying to yourself, "I hate tree-nails".
For light-colored treenails, I use the straws from a household corn broom available at most home goods stores.  I purchased a hand-held type at a dollar store and got enough straws to last a lifetime.  Each one is about 10 inches long and there are various diameters.  I pull them through a draw plate to get the exact size I need.  A couple of minutes work gives me about 20 or 25 10 inch lengths.
For dark treenails, I use the bristles from a palmyra brush or stable broom.  Same deal except the lengths are a lot shorter.
Both types give very strong, uniform treenails.
I dip in diluted white glue then cut them almost flush with little snips.  A bit of sanding when dry and it's done.
Terry
Long time ago I used mesquite thorns, which I got from a friend who had a ranch with thousands of those trees. The beauty of them is that they would fit the thinniest hole. I can't get them anymore, though. :(
There aren't but two options: do it FAST, or do it RIGHT.
Current Project Build Log: Soleil Royal in 1/72. Kit by Artesania Latina.
Last finished projectsRoyal Ship Vasa 1628; French Vessel Royal Louis 1780. 1/90 Scale by Mamoli. 120 Cannons
Future projects already in my stash: Panart: San Felipe 1/75; OcCre: Santísima Trinidad 1/90;
Wish List: 1/64 Amati Victory, HMS Enterprise in 1/48 by CAF models.
So much to build, so little time!
