she's look'in good David ;)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Cabins now installed on the deck; cranes and detail installed near the stern.
Regards,
David
David Robinson
Boston, MA area
Completed:  Constructo J.S. Elcano, Artesinia Latina Sanson, Dumas Mt. Washington, Bluejacket Nantucket, Amati Revenge, Artesania Latina  King of the Mississippi,
Amati Grand Banks Heritage 46, Amati HMS Fly, Amati Titanic, Dumas Chris Craft Commuter, Mantua Cutty Sark, Mantua Bruma, Kolderstok Batavia, Vanguard Models HM Cutter Alert, Caldercraft HMS Victory, Dumas USCG Fast Response Cutter, Amati Bismarck, Occre Jupiter Locomotive, Caldercraft Brannaren
Currently Building:  Mantua/Panart Amerigo Verspucci
she coming along nicely............very well done!  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
More detail installed on the deck.
Regards,
David
Edited by drobinson02199
David Robinson
Boston, MA area
Dave,
Wow, what an impressive ship!
This model is quickly finding it's way to my stash.
Seems to be a quality kit, with some repairable hiccups.
All the deck details, are those part of the kit or a separate "detail up" kit?
Thanks,
Tom E
Tom:
All of the details are part of the kit.  It's an Amati kit, and I have found their kits to be very high quality.
Regards,
David
David Robinson
Boston, MA area
I hope everyone is having a great holiday period.
I used some of the spare time to work on the funnels, and they are now all up.  She's beginning to look like a real steamship now.
The stays won't go up until some of the deck detail is finished, as they would be in the way.
Regards,
David
David Robinson
Boston, MA area
looks great David :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
„She was the larges craft afloat and the greatest of the works of man.“ Futility
written 1898 and telling the Titanic story including the collision with this iceberg at forced speed.
Your build is wonderful and you get the most out of the kit.
Please remember the massiv riviting on the hull plating. Good plans can be found here: http://www.titanic-plan.com/i_HW_plans_e.html
Hope this helps.
Edited by Heinrich der Seefahrer
Pictures added
"Let's add every day 1/2 hour of
modelship building to our
projects' progress..."
Take care!
Christian Heinrich
simple, true and inpretentious motto of ROYAL LOUIS, 1668
Sunking's mediter. flagship most decorated ocean-going ship
Ships on build:
SAINT PHILIPPE, 1693:
1st rang French 90-gun ship - Lavente flagship (based on Heller SR - 1/92 & scratch in 1/64)
TONNANT, 1693:
1st rang French 90-gun ship - sister of SAINT PHILIPPE (mock-up/test-object for S.P. - scratch in 1/64)
Projects in planing:
L'AURORE, 1766:
French Pleasure Corvette (after Ancre plans - scatch in 1/64)
Some Spantaneous Short Term Projects
Heinrich:
Thank you -- the pictures and plans are very interesting.  I see the rivets, but I fear that I'll never have the patience to get that much tiny detail into my model.  🤪
Regards,
David
David Robinson
Boston, MA area
Perchance the scale isn't worth it...
But noew you have got the plans enlarge them up to 1:48 and the riveting will make your day 😋...
Take care!
Christian Heinrich
Ships on build:
TONNANT, 1693:
L'AURORE, 1766:
Finished the stern poop deck.
Regards,
David
David Robinson
Boston, MA area
Bow detail finished.
It's New Year's Eve here, but Happy New Year to all and especially to our Australia/New Zealand friends who are already into 2019.
Regards,
David
David Robinson
Boston, MA area
I've installed the stanchions on the upper decks -- a couple of pics here.
A sequence issue:  I had to install two small lifeboats now (see pics), because the funnel stays would be in the way if I did those first,  But then I have to do the stays next, because the davits for the rest of the lifeboats would make deck attachment really difficult.  Then I'll install the lifeboats.
Speaking of the lifeboats -- I think way back in this log someone commented that they thought the use of plastic boats was inappropriate for a kit of this quality -- but as I have painted them I've found that they look nicer than some metal boats I've painted, and hold very fine detail as you can see.
Regards,
David
David Robinson
Boston, MA area
at least you have clinker hulled life boats.........some folks with that thought in mind can't find them,  let alone easily make them.  look at how many there are!.......    you said the magic word.......paint.   a flat paint will cover over plastic nicely and give realistic results.  try doing that with metal......especially that Britannia metal.   the boats can be stained too,  with the use of washes and clear coat.....flat.
how larger are they?   so far,  I'm on my third order to find clinker boats for my 1:124 Thermopylae......none have suited my fancy so far.   if I keep this up,  I won't need life boats for quite a long time  :D
very nice work BTW!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye:
The lifeboats are 38mm long.  If that fits, I would expect that Ages of Sail could order some from Amati for you.
Regards,
David
David Robinson
Boston, MA area
I've gotten a couple of orders from Cornwall.....ordered a pair from Billings to see if I'd get lucky,  but that was a lost cause :rolleyes:  I looked in Ages,  but I didn't see anything.........I'll peak in again,  maybe I missed something.  thanks!
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye:
I wasn't thinking about what Ages of Sail normally shows -- if the Titanic lifeboats work for you, my thought was that you'd have Ages of Sail order 1 or 2 plastic sets of the Titanic ones like you saw in my picture.  They are Amati's US distributor, so they might be able to do that.
Each "set" comes with 7 of the 38mm lifeboats, and two smaller ones that are 33mm, plus a tenth item that is Titanic-specific.
Hope this helps.
Regards,
David
David Robinson
Boston, MA area
Here's one of the lifeboat davits not yet painted and dry-fitted on the deck.  This is a five piece brass assembly with a lot of bending, but it's not too difficult.  I think these will add some real detail.
Also a pic of the funnel stays, which are now finished.
Next steps are to finish all the davits and paint them, then add eyebolts to the lifeboats, and then mount and rig them.
Regards,
David
David Robinson
Boston, MA area
Before going into mass production on the lifeboat davits, I wanted to make sure I understood how it all comes together, so I did two davits and one lifeboat and mounted them.  Result below.
The stern lifeboats (like this one) hang partly out from the deck.  The bow lifeboats mount flush to the edge of the deck.
Regards,
David
David Robinson
Boston, MA area
Finished the lifeboats on the starboard side.  I'm pushing to finish the boat, because I go away at the end of this week for 5 weeks and want to have it done before I go.
Regards,
David
David Robinson
Boston, MA area
the life boats look great!  you also gave me an idea about the guy wires to the funnels.  I have the Academy kit......the wire pass through the holes in the deck and come back up to run the next one.  what is happening,  is when I start to fit the deck in place {all this is done off the model},  the  wires either go limp or a few of them are pulling out of the holes....the glue isn't holding them.   it will mean that I may have some reconstruction to do,  but I will use eye bolts instead.........don't know why I didn't think of that before :default_wallbash:
I like the way you think!  ;)    do the sprues have part numbers?  thanks for the tips here......it may just bring her back to the table  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye:
Thanks for the comments.  You asked "Do the sprues have part numbers?"  What's a sprue?
Thanks,
David
David Robinson
Boston, MA area
:D  :D  :D  the sprue is what the boats were molded to.   injection molding.........either the sprue has a part number,  or there is a number in the instructions.   do the instructions show the diagrams of the sheets {wood and plastic} and detail the part numbers?
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Popeye:
OK, got it.  I gave you measurements for two boats.  The larger one is 2960, and the smaller one is 2961 (they are called "dingy" and "cutter" respectively in the English instructions.  These part numbers are unique to the Titanic kit.
If you call Ages of Sail, ask for James.  He's really good, and sometimes they keep an open kit around to cannibalize for missing parts.  You might be able to persuade him to sell you a "sprue" from that vs. ordering from Amati.  Two "sprues" come with the kit.
Regards,
David
David Robinson
Boston, MA area
will do........thanks for the heads up  :)
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
TITANIC IS FINALLY FINISHED!
I have posted completion pictures in the Gallery of completed kit ships, but I couldn't resist this one that shows the "place of honor" for this model in my office.  Ensures that I will look at it multiple times each day.  😁
A few final construction notes.  Some of these you'll see better in the Gallery pictures:
  1. The kit instructions use a plain wood dowel painted brown for the masts.  Couldn't stand that idea so I found a walnut dowel of the same size and used that.
  2. I bought a finished walnut base.  The kit includes a MDF base, but I've never figured out how to make one of those look like wood, and I didn't want a black base under this one.
  3. You'll see a yellow stripe down the side between the white and black parts of the structure.  This is in the box picture, but not in the instructions.  I did it by using the planking strips, which were perfectly sized, and pre-painting them.
  4. Even conserving the supplied rigging thread, I ran out after rigging the Marconi antenna and didn't have enough for the leads down to the ship, so I used some spare from another kit.
I wanted to get this done this week as we are headed off for 5-6 weeks for a long Asia trip.  When back and time adjusted, I'm going to do the Dumas Chris Craft Commuter next.  Should be a different challenge to get the finish right.
Thanks to all who have followed this build -- for your encouragement and help.
Regards,
David
David Robinson
Boston, MA area
