THX for the likes...still fiddling with lil bits...made the ships bell, chucked a piece of styrene sprue in the drill and shaped with files
IMG-0034.JPG.f10ad1dee5dd7eef65a8242aaeccd459.JPGIMG-0051.JPG.80d8b4304e5b73eaac10c4cfb2da7323.JPGdrill and attached to a pin, ready for the belfry, course it needs painted but that will have to wait...got none of my enamels with me, roughing it :rolleyes:
Edited by jct
sppeling
Still working on the little things
IMG-0064.JPG.a64342560f0087237c742e143d782011.JPGthe belfry
IMG-0066.JPG.f81df40192229d97f92c5c1fa599c723.JPGset of steps
1500192442_IMG-0069(1).JPG.e897adc64ac2778130ca4d669b46525e.JPGwow fuzzy...
IMG-0067.thumb.JPG.dc0f5a8960d5d04644e45829d035fa47.JPGguns
IMG-0068.JPG.57210a75b10afd8016be395bb8a523d7.JPGnew front placement
question...anyone know where the anchor lines would run coming off the windless...wondering if that's what the forward hatches are for??
Thanks for the likes
last post of the week...finished most of the major deck furniture and got it all placed and pined down
made pumps and the CN
and placed all but the guns...they are just set in place for now
IMG_0074.JPG.fcb61e746f2e06c03dafb7ff0bbdf157.JPGIMG_0075.JPG.72575f21fa7d4a211b733fbe839e7095.JPGIMG_0073.JPG.1147ec24e86119a1c0ced985ce2e47bb.JPG
Really starting to fill out jc.
Looking forward to next week.
Lou
Currant builds:
Schooner USS Lanikai/Hermes
Non ship build log:
1/35th UH-1H Huey
Got all the mast and booms tapered, mast tops squared, chain plates are made and mounted... sorry can’t post pics... no internet at all this week.  Hopefully latter, and as always thx for the likes
worked on the swivel guns
started with some rolled paper...added some pva to hold the tube together and added bent wire to represent the stock
tied on some light line to represent the strengthening rings and added them to the prepared stanchions
and added paint
stanchions need painted...not yet sure what color though
today's update...
mounted the swivel guns
the bits of tape you see in the photos are holding the outside edge of each respective chain plate in position so they don]t get mixed up until I can get them mounted...probably next week
I decided to mount the main guns...I originally rigged them with blocks but the smallest I had was 2 mm which looked way out of scale, so I stripped then off and just went with the run out tackle and holding lines, may add a few dark spots to simulate blocks...not sure yet
rope coils for gun tackle
rigged guns. you can start to see some of the light weathering I'm applying as I go in the second shot
overall shot of all the deck furniture to this pointIMG_9980.JPG.9619fe86eace41bd4bc24c61095bbf8d.JPG
the for all the likes later
An update of sorts...I'll be away from the table for a week or so, home for fathers day an our anniversary.
   It wasn't till I posted the pic below in the last update that I noticed the sacrificial anchor rub boards (not sure of the exact nomenclature) were facing the wrong direction...the sweep should face fore not aft...so they have been removed and will be reinstalled going the right direction.  I may take the opportunity to weather them a bit prior to the reinstall too.
That's it for now...
I think they are also painted black sometimes like the wales often are.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Black it is, but they will be slightly abused😁
Kind of like me?
No, in reality I think by their very nature and purpose in life "abused" would be a bit of an understatement. I don't think I would want a one or two ton anchor bumping up against me even once! :wacko::(
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Thanks for the likes...
This weeks update, still working on little odds and ends
First I reattached the billboards
the ships boat was cut down and a new stern fashioned...it was way too long, a rudder was constructed and a cradle fashioned for mounting on the deck
IMG_9983.JPG.f02b58e14b8a0f16b1682d93fcfcdb9c.JPGIMG_9988.JPG.1d9805bb21e3df6c946a54d1aaa52354.JPGIMG_9992.JPG.3b4d6c43964a52a65653a66996c0c9e2.JPG
all painted out and test fit
lines will be added to secure it to the deck later
Started scratching out the anchors
for the arms I first cut small pieces from some curved stock I had in the spares box...not sure of the species
and added pins for the shank and shaped them a bit
the shanks were made by chucking square walnut in a dremel and turning against sandpaper, I left the top square to mount the stock
the stocks are shaped pieces of basswood
and the flukes were cut from heavy watercolor paper
still have a bit of shaping and sanding to do...
also worked on the lower deadeyes for the shrouds
this "fixture" allows the deadeye to be held in place with a couple pins while blacked wire is wrapped around it and the pins
the pins leave spaces so they can be tacked to the hull when installed
Well that's all for now, thanks for looking in
Hi all, thanks for the likes...another installment
Spent the last couple days focusing on the chainplates and the anchors
IMG_0011.JPG.e1c4a14874813a3ed9982ba8b5044ef6.JPGIMG_0010.JPG.3233be116adc71cfd309809982db9316.JPG
also finished mounting the ship's boat
added some strips to the anchor stocks to simulate banding
then painted them out and added rings
the ring alone was too thin so some puddening was called for
IMG_0013.JPG.5bb9f8eccef96641c51b0d26fb3f8ff3.JPGIMG_0012.JPG.3c75caffb6960374394df234f2cd1566.JPG
just wrapping in black cotton thread and reinstalled
still need to touch-up the paint
thanks for looking in that's all for today
thx for the many likes...last update of the week
started workings on the anchor buoys...
chucked some basswood in the drill and spun against sandpaper and files
once the desired shape was achieved they were parted off, drilled and had eye-hooks attached with ca
IMG_0018.JPG.4890db9b98d100e852e3146c7c311d24.JPGIMG_0019.JPG.d1b274feb031d11cf6040b9923b5ff0a.JPG
still have to rig the harnesses for them.
Turned my attention to the anchor rigging and getting the cat heads set up
IMG_0016.JPG.a4e4aa2fddad28b2eb3a429031d72996.JPGIMG_0020.JPG.d4e2894806d63b7cd0aaac42d12000de.JPGIMG_0021.JPG.d76beeb2b4d149a36c9fe3086aeb6cb2.JPGIMG_0022.JPG.83863e5ec0a05ef4b38d0867d01d67b4.JPG
still needs a little fine tuning to get the droop right
and started working on the stock that will yield the mast cleatsIMG_0023.JPG.d2c2ebc5b9a63855e7bcd9a4355d0c9d.JPG
that's all for now...see you next week
Hey Sam, good to hear from you again,  the cleat technique is one I used back on my a Half Moon build, worked ok, I’m gonna look into your log, who knows yours may be better.   Definitely let u know
Edited by jct
sppeling
Had to make more small cleats and some shroud cleats,
To make the regular style cleat I start by taking half circle cuts out of a piece of stock the correct height and width as the finished cleat.  In this pic I'm using a screw punch to remove the unwanted material but a Dremel will work just as well
IMG_0029.JPG.50189effd90f1f770592fab3a6fedac1.JPGIMG_0032.JPG.d08808e6326ed99e7eba849e6b02aeae.JPG
these cuts establish the "wings" of the cleat
once this is complete, drill the base of the to be cleats to accept a pin
I'm working in basswood here, so it has been hardened with ca. but there is still some breakage as you can see
next the pins are set in ca
and trimmed when dry
the cleats can then be separated and sanded to shape, I use small diamond files for this step
IMG_0037.JPG.cdde31ba39fc38b80806d4d83528fd28.JPGIMG_0039.JPG.39aa1fbfb6213b5a964cab3bf415d400.JPG
I've used this technique successfully for different size deck/mast/boom cleats.
This is the first build I've done that required shroud cleats...so this technique wasn't proven, but it turned out pretty well
walnut from the spares box, the correct height, was marked up with the lengths and thirds of each cleat IMG_0024.JPG.4633e74a1b0aee33e5536a3bafa96562.JPG
holes were drilled at the intersections and the cleats cut to length
next to remove the shaded sections, accomplished with new #11 scalpels
at this point every one of these split in two right along the shroud line...so the centers were drilled and pinned using ca.  once the wedges were remove you should have something like this
all ready for sanding and finish shaping
Edited by jct
sppeling
Seems like you are working with PE made from wood J.
Great job.
Lou
Currant builds:
Non ship build log:
1/35th UH-1H Huey
Thanks for the comments and hitting the like button...another update
Spent more time on the little details, harnessed and rigged the anchor buoys
IMG_0043.JPG.ccb0a4a63931b2a376dd7f379968a179.JPGIMG_0044.JPG.2b77e716a7a873e97d95135d49586b08.JPG
and lashed them to the anchors
IMG_0045.JPG.d9e5f3b5e9e1da34bf7a3b58a0181d56.JPGIMG_0046.JPG.ac7ee997356d2e8f099c1e89fb6fda90.JPG
line still needs attached to the free ends, all the excess line will be coiled when the anchors are fixed.
Made a couple mast tables for the mast booms
and sail rings
the boom rests are basswood and the rings are paper stock shaped around the knife handle and glued with pva...these were dipped in poly to stiffen them once they dried.
Mounted the boom tables and fitted the cleats, made last week, to the masts
and that's it for today...think I'll start detailing the booms and yards next...I've got to decide how I want to rig this build...as a pure schooner or as a top sail schooner, seems either could be correct, leaning toward the former, we'll see...
Thanks for the likes...last update of the week...prepped the booms an gaffs for paint IMG_0053.JPG.62f89c1d16dd3a8ec9c933eb4c346e62.JPGIMG_0052.JPG.f6e412f41ff16132fbe46f49ccfb9cfc.JPG
scratched a block for the bow sprite and jib boom
IMG_0049.JPG.25bee8d77fbd520a816020a0f1dfea5e.JPGIMG_0051.JPG.6e7c16ac5f030e2f9714307565c3e125.JPG
tried my hand at making hearts...open and closed
IMG_0058.JPG.bec54018fb5f842c9c94a61f9983e300.JPGIMG_0059.JPG.59175f698fd305530d14206a2b0b142b.JPGIMG_0055.JPG.397187c5383c9806a03a5989ca70cb22.JPGIMG_0056.JPG.b089a35506e013ebe1430947130f7ff9.JPG
may have to work up more these are a little rough
and finally reworked the masts...I was gonna build this with top sails but decided to go with gaff rigging IMG_0062.JPG.bc481a4b74708036fc90034fc98c2e4f.JPGIMG_0063.JPG.f2390e99a47a098c4f4aa2e9d36e408c.JPG
