Thanks, Glenn.  Yes, they are tricky.  I think this would be some of the things Chuck refers to as "fiddly bits".  And I agree.  I've actually been working on these railings for months, but in really small time increments.  That has given me a lot of time to think about what I was doing, which helped me do a better job on them.
HMS Winchelsea 1:48 (Group Project)
Completed Builds:
Virginia 1819 Artesania Latina - 1:41
I then proceeded to knock one off while doing fenders. Fortunately it was PVA glue that gave and not the wood, so it was an easy fix.
Regards,
Glenn
Current Build: HM Flirt
I know what you mean, Frank.  My kids are in high school sports, so I spend a lot of time at games and meets. And I’ve been traveling for work way too much this year.  I’ve got a long trip to the UK coming up this fall and I’m hoping to visit the National Maritime Museum while I’m there.  Don’t get me wrong: I love going to my kids events and I know this time is fleeting.  I also love what I do for work and I’m getting a lot of time with customers this year.  But I have a place picked out to display Winnie, and instead she’s on the bench being neglected.
Completed Builds:
I can’t tell you the last time I made any progress on my Winchelsea.  And it’s not getting better soon.  I’m in the UK for work for three weeks this month and coming back late next month for four more.  Today was my first day off since I arrived, so I went down to Greenwich to visit the NMM.  Unfortunately, they’re renovating it and a lot of models are off display.  Here are a few pictures of what I saw.
Completed Builds:
It seems you and I are in an competition now to see who can put off working on their Winnie the longest😂
Great photos of the NMM, post more when you can, I’m curious about some of those two deckers. Enjoy your trip.
Hi Matt
The Science Museum in London used to have a wonderful collection of model ships. I believe that collection and much of what was on display at Greenwich has now been moved to the Royal Navy historic dockyard at Chatham (east of London but not a long journey from there) - which is apparently well worth a visit. Its on my list of places I'd like to go but my home in Cornwall is the other end of the country. If you are coming to the UK London area then it will be worth checking the website and perhaps planning a visit.
Best wishes
Fred
  • 6 months later...
Hi Frank. I’ve make a little progress, but nothing ready for pictures. I have the chain plates assembled (chapter 11) but not installed. I also finally finished the last of the gun deck cannon. I was short by six for the past two years. I should be done traveling for work. But life is getting in the way of hobbies right now.
Completed Builds:
I’m still making slow progress on my HMS Winchelsea. I have a milestone to report: I’ve finished chapter six! I was short by eight cannon and found time to finish them. It was a concerted effort as it started to bother me. One consequence of dragging my feet was that I could not use the belaying pins from The Crafty Sailor for the last few.  I ran out and they closed shop. So I broke down and did it the way Chuck said to do it: I turned them in my Dremel.
I’ve also started chapter eleven. I assembled all of the chainplates as prescribed. I’ve mounted one as you can see in my pictures. I was very nervous about removing the molding, but it wasn’t really that hard. I just took my time on the cuts and loosened them with CA Un-Cure.  I’m using the new 3D printed deadeyes in Swiss Pear. They look fantastic. There’s a ton of work to do in chapter 11 so I’m sure it will take me a while to finish it.
Moldings removed to make room for the chain plate
Ship’s Wheel and binacle set in place
Chapter six complete!  Kind of - they aren’t fixed in place yet.
Port side foremast chain plate in place. I had to see how a deadeye looks in place. It looks surprised!
Edited by Matt D
Photo comments
Completed Builds:
I can’t believe the dumb mistake I just discovered. Way back in chapter two, I put the anchor shield in the wrong spot. Now I’m faced with a dilemma and I’d love to get some opinions. As I see it, I have a few options. 1: leave it as is and install the billboard above it, also in the wrong place. 2: try to remove it and install it in the right place. As I see it, this is very risky. I’m not sure if I used CA or PVA to attach it. Regardless, taking it off could cause a lot of damage. 3: leave that one there and install a replacement in the right place. 4: leave it where it is and install the billboard in the correct location. What do you think?
Edited by Matt D
Completed Builds:
Just block sand it completely off that way you slowly remove it without chipping or scraping away at it. Then just refinish the wale.
I did exactly the same thing. I was able to prise the offending part away with a sharp blade without causing any damage - or at least any damage that was not easily repaired. I had glued the part with CA onto a previously painted surface so I guess there was more limited adhesion than might have been the case had I glued to unpainted wood. I don't think you can leave it in the wrong place - it will surely always bug you and, I suspect, cause more problems down the line. Good luck whatever choice you make.
This is the way I would go...
Definitely wouldn’t leave it as is, it would always bother you.  I’d either up removing it and repairing any damage, something I’ve done more than I like. The sanding, heavily taping above and below the wale, seems like a good option as well.
Regards,
Glenn
I have sanded them off and started the new installation. But it still looks awful. I’m busy with my kids’ sports right now and haven’t spent any time in the shipyard since early March. Lacrosse and track will be done in a couple of weeks, but by then it will be 1:1 scale boat season.
Completed Builds:
