Hi
If I build a huge kit, example Danmark from Billing boats, and after five years I want to rebuild it because I then think I could build it better.
How much of the material could I reuse if I tear it down?
And how much would the new material cost, approx?
My idea
I have this problem with every model that I build. Once it is finisht, errors pop up. :blush: I learn from my mistakes and try not to do them anymore in the next model.
That depends on how much you want to change.
Dont now, but buying a new kit and starting over is probably the cheapest, I think.
I add that I have tools to cut plywood etc. I don't have to buy readymade list etc.
I think that the wood material would cost 100 usd?
Interesting concept though I suspect you would damage a lot of the wood taking it apart.
I think you would have more success  with a second model and using the first to improve skills. Or go and scratch build where you can re-make the same part ten times until you are happy.
I also nitpick my own work heavily.
I have learned over the years that dismantling a model and rebuilding it usually doesn’t have a happy ending.
If you want the same vessel, you would likely be better off buying a second kit.
I typically add mistakes to my lessons learned file and apply those lessons to my next build.
Building:
I am with Matrim on this.  If you try to tear it down you will inevitably damage some parts ,and taking the planking off would be very difficult.
However I would also recommend you continue building this one first so that you get further practice and identify any further issues/problems etc you may encounter wirth building the full model (parts you have not yet done).  That way you won't run into the problem of rebuilding the hull to a much better standard, and then potentially be unhappy with the masting and rigging as that will be the first attempt at that on your new model (hull).  I am assuming that you have completed the hul and not the masting and rigging?
cheers
Pat
As the others said, it's probably possible, but you might as well build a new one again. Then, all you have to do it  put it together. No need to take it apart first. Taking one apart and rebuilding it is sort of like re-marrying your ex-wife, don't you think? :D
Besides, blowing up old models you don't like anymore is why God made cherry bombs and M-80's! :D
Edited by Bob Cleek
I concur with the above -"you do not really want to this"  advice.   To quote Chris Rock: "sure you can do it, but that don't make it is a good idea."
With such seeming ambition, you might consider further what Matrim suggested.  Come over to the dark side and scratch build.
Are there not close to home plans sources in Sweden and Denmark for locally significant vessels that have never been modeled or
at least not done to death?
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
I'm currently restoring a (scratch) model I made when I was 17, started to change, and then left to deteriorate for 40 years. Because I wanted to change the hull shape (the stern was too wide) it ended up more as a rebuild. I'm a fair way through it and I intend to complete it come what may, but I really wouldn't recommend it, from grim personal experience. The only reason I'm doing it is that I feel it deserves to be finished after all this time.
If you're not happy with the result of your kit and you want to make it better, I'd recommend you buy a new one rather than pull it apart and rebuild.
Steven
