I am wanting to scratch build a pinnace and longboat for my Pegasus.
I like the Pinnace from Model Shipways that Blue Ensign built for his Pegasus and would like to make one myself along with a Model Shipways longboat (both a a reduced scale).
The question I have is: is it possible to purchase just the plans for them? as i will need to reduce the scale to suit Pegasus.
Thanks Guys
Caroline
First Completed Build: San Francisco (Original Version)
Current build: Victory Models HMS Pegasus
Cross Stitch Project (Finished): Battle Of Agamemnon and Ca Ira
Cross Stitch Project : Victory & Temeraire
The AOTS Diana book has plans for all the boats that you could copy and change to the scale you need
Regards
Paul
The clerk of the cheque's yacht of sheerness
Current build HMS Sirius (1797) 1:48 scratch POF from NMM plans
HMS Winchelsea by chuck 1:48
Cutter cheerful by chuck 1:48
Previous builds-
Elidir - Thames steam barge
Cutty Sark-Billings boats
Wasa - billings boats
Among others 😁
Hi Caroline
Assuming you are building the 16 gun sloop of Pegasus 1776, according to what I can find in W.E. May's Boats of War, she would have carried a 19 foot longboat and 26 foot pinnace, although in 1777, 16's of more than 300 tons were given an extra 18 foot four oared cutter.  Does this sound right for your model?   Please keep in mind that you cannot necessarily just change the scale of a drawing to the size  that you need without making alterations.  For example, if the drawing you use is a 28 foot 16 oared longboat, when scaling to a 19 foot long boat, the number or size of the benches. number of oars, and other parts are not necessarily to be scaled.  Even the shape is likely to be wrong when just scaling as the proportions of breadth to length vary for shorter or longer boats.  For example, the proportion of length to breadth of a 32 long boat of about 1800 is 3.36 while for a 19 foot long boat the proportion is only 2.68.   They are similar but slightly larger proportions given in Mays for 1745 as well, 3.45 for a 32' long boat for example.
Cheers
Allan
Thanks for the replies guys. I have some plans now.
6 hours ago, allanyed said:
Hi Caroline
Cheers
Allan
Yes, that is more or less what I am aiming for, a 19 Foot longboat and 25 foot pinnace. Just need to get started now!
Look on the site:
https://collections.rmg.co.uk/collections.html#!cbrowse
then search '26 foot pinnace plan' and '19 foot longboat plan'.
You can download the plan, then re-size it using the scale on the plan to fit your scale.
On 10/14/2019 at 11:04 PM, druxey said:
Look on the site:
Thanks Druxey, I will bookmark that site.
good morning Druxey
I picked your link, copy and pasted each search and hit enter and got nothing.
There must be an extra step.
help?
Alan
Alan O'Neill
Same problem.  However, simply typing pinnace, the first item is a 28 ft. pinnace and by typing longboat, a 20 ft. longboat is halfway down the page.
Toni
Member IPMS
                           Utrecht-1742
This should narrow it down a bit:
Pinnace plans
If you don't type in a precise match, you can get a lot of extra clutter or nothing at all..
Edited by Gregory
― Jimmy Buffett
Slow crawl:    Rattlesnake
ah
it works
also seems you shouldn't copy and paste
Alan O'Neill
