Oliver,
On the models I have made with sails, I sewed the bolt ropes on the sails so glue was not necessary.
If you are going to use glue, I would avoid CA as it could leave a stain around the edge of the sail and will leave the edge of the sail brittle.
Allan
I just use a hand stitch with needle and thread. I stick the needle thru the rope going between one strand, then into the sail, loop around bottom edge of sail and back up thru the rope.
Jack
Current buildUS Constellation
See this Post.  The bolt rope goes along the entire edge of the sail.
Jack
Generally, on other than some storm sails, the leech of sails is not roped. The rope is brought round the corner of the sail for a distance sufficient to reinforce the sail's corner at the cringle and then tapered to a "rat tail" which is sewn onto the leech for that distance alone.
Edited by Bob Cleek
I wouldn't use a PVA glue, myself.   All fabric shops sell cloth glue that remains pliable after it dries.
Be careful using super glue on cloth or cords! It releases a lot of heat when it cures. I once used it to treat the unravelled ends of 1/8" drawstrings on a sleeping bag - mistake! They soaked up a lot of glue. After a minute or so the cords became very hot and started to smoke.  I dunked them into a glass of water to avoid a fire.
Phil
Current build: USS Cape MSI-2
